Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
| ICD2 question |
Posted: Fri May 23, 2003 3:30 pm |
When trying to debug, how do you fix this error:
"Target not in debug mode, unable to perform operation"
I don't understand why MPLAB 6.2 won't set the debug fuse for me. Anyone else have this problem?
I couldn't find a good answer on the MCHIP forums.
___________________________
Original Post ID: 144514714 _________________ I came, I saw, I compiled. |
Wedilo Guest
| Re: ICD2 question |
Posted: Wed May 28, 2003 12:52 am |
Hi Darran,
I remember that I had have the same problem some month ago.
I solved the problem quick and dirty by adding the following
line of code in each program:
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
You see, I set the fuses every time. Look in the manual for your personal adaptation. I still hope helping you...
73 Sven
:=When trying to debug, how do you fix this error:
:="Target not in debug mode, unable to perform operation"
:=I don't understand why MPLAB 6.2 won't set the debug fuse for me. Anyone else have this problem?
:=I couldn't find a good answer on the MCHIP forums.
Original Post ID: 144514803 |
