problem in 4*4 matrix keyboard interfacing with pic18f4550
PRITEE NIKAM
PostPosted: Tue Oct 01, 2013 4:50 am     Reply with quote
#include "ex_usb_common.h"
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
//#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)//RS232
#if __USB_PIC_PERIF__
 #if defined(__PCM__)
  #include <pic_usb.h>   //Microchip PIC16C765 hardware layer for usb.c
 #elif defined(__PCH__)
  #include <pic18_usb.h>   //Microchip PIC18Fxx5x hardware layer for usb.c
 #elif defined(__PCD__)
  #include <pic24_usb.h>   //Microchip PIC18Fxx5x hardware layer for usb.c
 #endif
#else
 #include <usbn960x.h>   //National 960x hardware layer for usb.c
#endif
#include "usb_desc_keyboard.h"    //USB Configuration and Device descriptors for this UBS device
#include "usb.c"        //handles usb setup tokens and get descriptor reports
#define row1_low output_low(PIN_B0)//ROWS
#define row1_high output_high(PIN_B0)//ROWS
#define row2_low output_low(PIN_B1)
#define row2_high output_high(PIN_B1)
#define row3_high  output_high(PIN_B2)
#define row3_low  output_low(PIN_B2)
#define row4_high  output_high(PIN_B3)
#define row4_low   output_low(PIN_B3)
#define read_col1 input(PIN_B4) // COLUMN
#define read_col2 input(PIN_B5)
#define read_col3 input(PIN_B6)
#define read_col4 input(PIN_B7)
int8 value;
int8 key;
char key_value;
void read_key1(void);
void read_key2(void);
void read_key3(void);
void read_key4(void);
void usb_keyboard_task(void);
void usb_debug_task(void)
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   if (new_connected)
      LED_ON(LED2);
      LED_OFF(LED2);
   if (new_enumerated)
      LED_ON(LED3);
      LED_OFF(LED3);
   if (new_connected && !last_connected)
      printf("\r\n\nUSB connected, waiting for enumaration...");
   if (!new_connected && last_connected)
      printf("\r\n\nUSB disconnected, waiting for connection...");
   if (new_enumerated && !last_enumerated)
      printf("\r\n\nUSB enumerated by PC/HOST");
   if (!new_enumerated && last_enumerated)
      printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
  key=0;
  key_value=0;
  printf("\r\n welcome");
   HW_INIT();
//   LED_ON(LED1);
 //  LED_OFF(LED2);
//   LED_OFF(LED3);
   printf("\r\n\nCCS HID Keyboard Demo");
   printf("\r\nCharacters received over serial get sent as a HID keyboard");
  #ifdef __PCH__
   printf("\r\nPCH: v");
   printf(__PCH__);
   printf("\r\nPCD: v");
   printf(__PCD__);
  #else
   printf("\r\nPCM: v");
   printf(__PCM__);
  #endif
   usb_init_cs();
  #if !(__USB_PIC_PERIF__)
   printf("\r\nUSBN: 0x%X", usbn_get_version());
  #endif
   printf("\r\n");
     unsigned int8 tx_msg[7];
     usb_task();
     usb_debug_task();
     delay_ms(20);
     if (usb_enumerated())
           if (usb_tbe(1))
              read_key1();
              memset(tx_msg, 0x00, sizeof(tx_msg));
              tx_msg[2] = key_value;
           usb_put_packet(1, tx_msg, sizeof(tx_msg), USB_DTS_TOGGLE);
    key_value = 0;
//-------------------------- READ MUX KEY PAD ----------------------------------
   row1_high;
   row2_high;
   row3_high;
   row4_high;
   row1_low;
   row2_high;
   row3_high;
   row4_high;
   delay_ms(5);
   key=input_b();
   key=(key & 0xF0);
   if(key==0xE0)
      key_value=0x09;
      output_low(PIN_C1);
      goto exit_key;
    if(key==0xD0)
      key_value=0x05;
        goto exit_key;
   if(key==0xB0)
      key_value=0x24;
         goto exit_key;
    if(key==0x70)
      key_value=0x20;
         goto exit_key;
     } [/b]
   row1_high;
   row2_low;
   row3_high;
   row4_high;
   delay_ms(5);
   key=input_b();
   key=(key & 0xF0);
   if(key==0xE0)
      key_value=0x08;
         goto exit_key;
   if(key==0xD0)
      key_value=0x04;
       goto exit_key;
   if(key==0xB0)
      key_value=0x23;
         goto exit_key;
  if(key==0x70)
      key_value=0x1F;
         goto exit_key;
   row1_high;
   row2_high;
   row3_low;
   row4_high;
   delay_ms(5);
   key=input_b();
   key=(key & 0xF0);
   if(key==0xE0)
      key_value=0x07;
         goto exit_key;
   if(key==0xD0)
      key_value=0x26;
       goto exit_key;
   if(key==0xB0)
      key_value=0x22;
         goto exit_key;
  if(key==0x70)
      key_value=0x1E;
         goto exit_key;
   row1_high;
   row2_high;
   row3_high;
   row4_low;
   delay_ms(5);
   key=input_b();
   key=(key & 0xF0);
   if(key==0xE0)
      key_value=0x06;
         goto exit_key;
   if(key==0xD0)
      key_value=0x25;
       goto exit_key;
   if(key==0xB0)
      key_value=0x21;
         goto exit_key;
  if(key==0x70)
      key_value=0x27;
         goto exit_key;
     exit_key:;
delay_ms(20);
This is my 4*4 matrix keypad code. I want USB output. This code is partially working. First row is not working.
If i run same code for rs232 output by changing only display function its working properly. But same code when i integrate for USB then its creating problem.
please help me...
thnx
PostPosted: Tue Oct 01, 2013 5:29 am     Reply with quote
debugging101...
Since you say the KPD code works using RS-232 then hardware and KPD driver should be OK.
Since row1 doesn't work, look for something 'common' or used by both KPD row1 code and the USB drivers.
I suspect the USB code test LEDs( LED2, LED3). One might be connected to B0. I can't check the code( on wrong computer), but that's the first place I'd look.
hth
jay
PRITEE NIKAM
PostPosted: Tue Oct 01, 2013 9:55 pm     Reply with quote
I have checked all port pins but here I'm facing different problem..
when i write routine for row1 first in main program, row1 is not working. If i interchange other row routine (row2 or row3 or row4) with row1 then that particular row is not working...
I guess there is problem in my usb code but I'm not getting it exactly...
PRITEE NIKAM
PostPosted: Wed Oct 02, 2013 1:44 am     Reply with quote
in this code i want to send 3 key_values(hid codes) at one keypress..
eg.- if i press one key it should send hid code of a,b,c (0x04,0x05,0x06)
how can i send???
please help me
i need it urgently.
