LCD : change DDRAM to the second character set
PostPosted: Sun Mar 30, 2008 4:08 am     Reply with quote
hello,
I am using Flex LCD driver by PCM Programmer for controlling 16x2 LCD.
According to HD44780 data sheet, there are 2 possible character sets which vary in address of DDRAM.
My question therefore is how to employ the second set instead of the first one.
I guess the modification of the following is to be done, but dont have a clue what exactly:
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
thanks in advance,
regards M.
PostPosted: Sun Mar 30, 2008 2:11 pm     Reply with quote
or am I wrong? I allege that based on Table 4 in HD44780 datasheet. There are 2 ROM Codes - A00, A02
Can it be switched between them or is it factory programmed?
cheers
PostPosted: Sun Mar 30, 2008 2:38 pm     Reply with quote
You have to buy the LCD with the specific character set that you want.
Look at this section in the HD44780 data sheet:
Ordering Information
It shows the different ordering options. One part number has character
set A00, another p/n is for character set A02, etc.
PostPosted: Mon Mar 31, 2008 3:56 am     Reply with quote
thanks for clarifying
aruna1
PostPosted: Wed Oct 02, 2013 1:32 am     Reply with quote
Hi
sorry for reviving this old post. but my question is related to this.
@PCM programmer,
How can we know which chip is used in the lcd module we have?
I have some 16x2 lcd modules but their chips are sealed. is there anyway we can find which ROM address chips have?
PostPosted: Wed Oct 02, 2013 1:53 am     Reply with quote
Display the characters....
aruna1
PostPosted: Wed Oct 02, 2013 1:55 am     Reply with quote
that is what i thought. I was looking for more lazy way Very Happy
thanks Ttelmah
PostPosted: Wed Oct 02, 2013 3:53 am     Reply with quote
Realistically if this is not marked on the unit, it is going to have to be powered up, so just displaying characters is as easy as any other way....
However it normally is part of the part number on the unit.
