Dave Yeatman Guest
| A/D Operations in 3.158 |
Posted: Sat May 24, 2003 7:21 pm |
Am I missing something here? I have included the LST lines for READ_ADC operations I am doing in a CASE statement. It appears that it sometimes accesses the wronmg registers, sometimes sets the GO bit and sometimes test the DONE bit but not every time.
Anyone seen this? I sent this to CCS also....
018A: INCF 43,F
.................... switch (sensor_select)
018B: MOVF 42,W
018C: ADDLW FB
018D: BTFSC 03.0
018E: GOTO 22F
018F: ADDLW 05
0190: GOTO 2E6
.................... case 0: {// read the
.................... Light_lvl_In=read_adc(0);
0191: CLRF 7A
0192: MOVWF 53
0193: MOVF 7A,W
0194: MOVWF 54
.................... // we have to convert the voltage value here
.................... break;
0195: GOTO 22F
.................... case 1: {
.................... Humidity_In= read_adc(1);
0196: BSF 1F.2
0197: CLRF 7A
0198: MOVWF 4F
0199: MOVF 7A,W
019A: MOVWF 50
019B: GOTO 22F
.................... case 2: {
.................... Moisture_In= read_adc(2);
019C: BTFSC 1F.2
019D: GOTO 19C
019E: CLRF 7A
019F: MOVWF 51
01A0: MOVF 7A,W
01A1: MOVWF 52
01A2: GOTO 22F
.................... case 3: {
.................... temp1= read_adc(3);
01A3: BSF 1F.2
01A4: BTFSC 1F.2
01A5: GOTO 1A4
01A6: MOVWF 2B
.................... // we will have to convert the voltage input to N,S,E,W etc. (256/16 pts = 16 counts per point)
.................... if ((temp1 > 248) || (temp1 < 8)) // equate voltage to direction
01A7: MOVF 2B,W
01A8: SUBLW F8
01A9: BTFSS 03.0
01AA: GOTO 1AF
01AB: MOVF 2B,W
01AC: SUBLW 07
01AD: BTFSS 03.0
01AE: GOTO 1B3
.................... wind_dir=1; // this is NORTH
01AF: CLRF 4E
01B0: MOVLW 01
01B1: MOVWF 4D
.................... else
01B2: GOTO 22A
.................... if (temp1 > 232)
01B3: MOVF 2B,W
01B4: SUBLW E8
01B5: BTFSC 03.0
01B6: GOTO 1BB
.................... wind_dir=16; // this is NNW
01B7: CLRF 4E
01B8: MOVLW 10
01B9: MOVWF 4D
01BA: GOTO 22A
.................... if (temp1 > 216)
01BB: MOVF 2B,W
01BC: SUBLW D8
01BD: BTFSC 03.0
01BE: GOTO 1C3
.................... wind_dir=15; // this must be NW
01BF: CLRF 4E
01C0: MOVLW 0F
01C1: MOVWF 4D
01C2: GOTO 22A
.................... if (temp1 > 200)
01C3: MOVF 2B,W
01C4: SUBLW C8
01C5: BTFSC 03.0
01C6: GOTO 1CB
.................... wind_dir=14; // this must be WNW
01C7: CLRF 4E
01C8: MOVLW 0E
01C9: MOVWF 4D
01CA: GOTO 22A
.................... if (temp1 > 184)
01CB: MOVF 2B,W
01CC: SUBLW B8
01CD: BTFSC 03.0
01CE: GOTO 1D3
.................... wind_dir=13; // this must be West
01CF: CLRF 4E
01D0: MOVLW 0D
01D1: MOVWF 4D
01D2: GOTO 22A
.................... if (temp1 > 168)
01D3: MOVF 2B,W
01D4: SUBLW A8
01D5: BTFSC 03.0
01D6: GOTO 1DB
.................... wind_dir=12; // this must be WSW
01D7: CLRF 4E
01D8: MOVLW 0C
01D9: MOVWF 4D
01DA: GOTO 22A
.................... if (temp1 > 152)
01DB: MOVF 2B,W
01DC: SUBLW 98
01DD: BTFSC 03.0
01DE: GOTO 1E3
.................... wind_dir=11; // this must be SW
01DF: CLRF 4E
01E0: MOVLW 0B
01E1: MOVWF 4D
01E2: GOTO 22A
.................... if (temp1 > 136)
01E3: MOVF 2B,W
01E4: SUBLW 88
01E5: BTFSC 03.0
01E6: GOTO 1EB
.................... wind_dir=10; // this must be SSW
01E7: CLRF 4E
01E8: MOVLW 0A
01E9: MOVWF 4D
01EA: GOTO 22A
.................... if (temp1 > 120)
01EB: MOVF 2B,W
01EC: SUBLW 78
01ED: BTFSC 03.0
01EE: GOTO 1F3
.................... wind_dir=9; // this must be South
01EF: CLRF 4E
01F0: MOVLW 09
01F1: MOVWF 4D
01F2: GOTO 22A
.................... if (temp1 > 104)
01F3: MOVF 2B,W
01F4: SUBLW 68
01F5: BTFSC 03.0
01F6: GOTO 1FB
.................... wind_dir=8; // this must be SSE
01F7: CLRF 4E
01F8: MOVLW 08
01F9: MOVWF 4D
01FA: GOTO 22A
.................... if (temp1 > 88)
01FB: MOVF 2B,W
01FC: SUBLW 58
01FD: BTFSC 03.0
01FE: GOTO 203
.................... wind_dir=7; // this must be SE
01FF: CLRF 4E
0200: MOVLW 07
0201: MOVWF 4D
0202: GOTO 22A
.................... if (temp1 > 72)
0203: MOVF 2B,W
0204: SUBLW 48
0205: BTFSC 03.0
0206: GOTO 20B
.................... wind_dir=6; // this must be ESE
0207: CLRF 4E
0208: MOVLW 06
0209: MOVWF 4D
020A: GOTO 22A
.................... if (temp1 > 56)
020B: MOVF 2B,W
020C: SUBLW 38
020D: BTFSC 03.0
020E: GOTO 213
.................... wind_dir=5; // this must be East
020F: CLRF 4E
0210: MOVLW 05
0211: MOVWF 4D
0212: GOTO 22A
.................... if (temp1 > 40)
0213: MOVF 2B,W
0214: SUBLW 28
0215: BTFSC 03.0
0216: GOTO 21B
.................... wind_dir=4; // this must be ENE
0217: CLRF 4E
0218: MOVLW 04
0219: MOVWF 4D
021A: GOTO 22A
.................... if (temp1 > 24)
021B: MOVF 2B,W
021C: SUBLW 18
021D: BTFSC 03.0
021E: GOTO 223
.................... wind_dir=3; // this must be NE
021F: CLRF 4E
0220: MOVLW 03
0221: MOVWF 4D
0222: GOTO 22A
.................... if (temp1 > 8)
0223: MOVF 2B,W
0224: SUBLW 08
0225: BTFSC 03.0
0226: GOTO 22A
.................... wind_dir=2; // this must be NNE
0227: CLRF 4E
0228: MOVLW 02
0229: MOVWF 4D
.................... // ************ End of Wind conversion test ************
.................... break; // end of case 3
022A: GOTO 22F
.................... case 4: {
.................... Pressure_In= read_adc(4);
022B: MOVF 1E,W
022C: CLRF 4C
022D: MOVWF 4B
.................... // update_sensors=false; // last one so kill update flag till next minute
022E: GOTO 22F
.................... // default:
.................... // sensor_select=0;
___________________________
Original Post ID: 144514739 |
| Re: A/D Operations in 3.158 |
Posted: Sat May 24, 2003 10:27 pm |
:=.................... case 0: {
:=.................... Light_lvl_In=read_adc(0);
:=.................... case 1: {
:=.................... Humidity_In= read_adc(1);
:=.................... case 2: {
:=.................... Moisture_In= read_adc(2);
:=.................... temp1= read_adc(3);
In the numbers 0,1,2,3 above, are you trying to set the A/D
channel ? That is done with the set_adc_channel(n) function.
The parameter for read_adc(n) is for the mode, which can be
one of these three settings:
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ 7 // This is the default if nothing is specified
#define ADC_START_ONLY 1
#define ADC_READ_ONLY 6
(This is from 16F877.h)
Original Post ID: 144514740 |
Dave Yeatman Guest
Posted: Sun May 25, 2003 7:55 am |
:=:=.................... case 0: {
:=:=.................... Light_lvl_In=read_adc(0);
:=:=.................... case 1: {
:=:=.................... Humidity_In= read_adc(1);
:=:=.................... case 2: {
:=:=.................... Moisture_In= read_adc(2);
:=:=.................... temp1= read_adc(3);
:=In the numbers 0,1,2,3 above, are you trying to set the A/D
:=channel ? That is done with the set_adc_channel(n) function.
:=The parameter for read_adc(n) is for the mode, which can be
:=one of these three settings:
:=// Constants used in READ_ADC() are:
:=#define ADC_START_AND_READ 7 // This is the default if nothing is specified
:=#define ADC_START_ONLY 1
:=#define ADC_READ_ONLY 6
:=(This is from 16F877.h)
Yes, I set the channel in another routine to make sure I have plenty of time for it to settle. The Read_ADC parameter was a stupid oversight on my part, that may fix things...Thanks!
Original Post ID: 144514744 |
