billy
| Internal Oscillator 12F615 |
Posted: Sun Aug 18, 2013 11:13 pm |
Good day,
I am new with the software and a student. I need some advice on the setup of the internal oscillator. How do I know if the internal oscillator are running when using the PIC12F615? I have done the setup, but it seems that my processor is not running.
See my code:
#include <12F615.h>
#device adc=10
#FUSES IOSC8 //INTOSC speed 8 MHz
#use delay(clock=8000000)
setup_adc_ports(sAN3|VSS_Vref);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,255,1);
Hope somebody can assist me.
Billy. |
stinky
Joined: 05 Mar 2012 Posts: 99 Location: Central Illinois
Posted: Sun Aug 18, 2013 11:46 pm |
| How do you know it's not working? |
billy
Posted: Mon Aug 19, 2013 12:44 am |
Stinky,
My code is quite simple. made an output high for LED. After programming the pic, put in my development board. LED is not on when powering up.
If I simulate the program in proteus, the program is working. |
Posted: Mon Aug 19, 2013 1:12 am |
The point is that what you post does not show the LED code.
Anyway some comments inline:
#include <12F615.h>
#device adc=10
#define LED PIN_xx //Select to suit your LED
//Read the data sheet. Is this a legal ADC clock at this CPU clock....
do
output_toggle(LED);
} while (TRUE);
//This shows flashing an LED
//Things that would stop it working:
//1) Choosing pin A3 for the LED - this is _input only_.
//2) Not having a suitable current limiting resistor on the LED
//If the LED is wired directly, it'll short out the PIC, odds are it'll reset
//and nothing will apparently happen.
//3) Choosing pin A4 for the LED. This is AN3, which you are setting
//as an analog input.
Read the inline comments.
