		| Author | Message |
		| Electronguru
				| PIC18f4523 code |
				|  Posted: Mon May 27, 2013 12:03 am |   |
				| Hi ,
 I am trying to run this code on 18F4523 , but can't seem to get anything out of it. It programs correctly using PICkit2. I don't get any clock output on pin RA6, or pin 25 (TX), or pin 18 which is SCL output ??? I am trying to use internal oscillator, since there is not external oscillator connected.
 Here's the code:
  	  | Code: |  	  | #include <18F4523.h>                             // PICF4523 header file
 #device ADC=12                                   // 12 bits ADC
 #use delay(clock=4000000)                        // for 4Mhz crystal
 #fuses NOWDT, NOPROTECT, NOLVP                   // for debug mode
 #FUSES INTRC                                     //Internal Osc
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, Parity=N, Bits=8, ERRORS)
 #use i2c(Master, sda=PIN_C4, scl=PIN_C3)
 int d;
 int8 data[8] = {0x1A,0x1B,0x2C,0x3D,0x4E,0x5F};
 i2c_start();
 i2c_write(0xA1);
 i2c_write(0xA2);
 i2c_write(0xB1);
 i2c_write(0xC1);
 i2c_write(0xF1);
 data[0] = i2c_read();
 data[1] = i2c_read();
 data[2] = i2c_read();
 data[3] = i2c_read();
 data[4] = i2c_read();
 data[5] = i2c_read(0);
 i2c_stop();
 delay_ms(10);
 // JUST FOR TESTING
 i2c_start();
 i2c_write(0xA1);
 i2c_write(0xA2);
 i2c_write(0xB1);
 i2c_write(0xC1);
 i2c_write(0xF1);
 putc(data[0]);
 putc(data[1]);
 putc(data[2]);
 putc(data[3]);
 putc(data[4]);
 putc(data[5]);
 printf("%x\n",data[0]);
 printf("%x\n",data[1]);
 printf("%x\n",data[2]);
 printf("%x\n",data[3]);
 printf("%x\n",data[4]);
 printf("<<18F4523 is ready>>\n");
 delay_ms(10);
		| PCM programmer
				|  Posted: Mon May 27, 2013 12:11 am |   |
				|  	  | Quote: |  	  | I don't get any clock output on pin RA6, or pin 25 (TX), or pin 18 which is SCL output ? |
 That's what would happen if you were missing the 10K pullup resistor on the MCLR pin.
		| Electronguru
				|  Posted: Mon May 27, 2013 1:08 am |   |
				|  	  | PCM programmer wrote: |  	  |  	  | Quote: |  	  | I don't get any clock output on pin RA6, or pin 25 (TX), or pin 18 which is SCL output ? |
 Thanks for the tip, there was a 10K resistor but I was leaving the MCLR pin connected to PICkit2 and it was pulling it down. Now I do see clock output at RA6.
 But no RS232 signals at pin 25 or I2c clk on pin 18 ??
 Although this code simulated as expected in Proteus.
		| asmboy
				|  Posted: Mon May 27, 2013 10:37 am |   |
 work better ???
 at least for clock out
 also consider using
 setup_oscillator()  per the header file
 and
 BTW you might want to specify a few more
 #fuses
 based on what you want to accomplish
		| PCM programmer
				|  Posted: Mon May 27, 2013 12:19 pm |   |
				|  	  | asmboy wrote: |  	  |
 work better ???
 INTRC is the correct fuse  to get a Fosc/4 clock signal on pin A6.
 If you use INTRC_IO, the two oscillator pins (A6 and A7) are i/o pins.
 If you have the CCS IDE, the fuses.txt file has this:
  	  | Quote: |  	  | INTRC Internal RC Osc INTRC_IO Internal RC Osc, no CLKOUT
		| PCM programmer
				|  Posted: Mon May 27, 2013 12:58 pm |   |
				|  	  | Quote: |  	  | But no RS232 signals at pin 25 or I2c clk on pin 18 ??
 Do you have pull-up resistors on the SDA and SCL lines ?
 If you don't have pull-ups, the i2c_write() function will probably lock-up.
 That's because i2c_write() polls the SCL line and if it's low (ie., checking
 for clock stretching from the slave), the code will wait in a loop until it
 goes high.  If there are no pull-ups it will never go high - it will "hang" the
 program.  This is also true for i2c_read().
 Because you have all these i2c lines before your printf statements, I
 strongly suspect that you are missing the pull-ups and the program
 never gets to the printfs.
  	  | Quote: |  	  | Although this code simulated as expected in Proteus. |
 Proteus doesn't care about many hardware issues.  Because of this,
 many things may work in Proteus but they don't work on a real board.
 On a real board, you have to make everything correct.
		| Electronguru
				|  Posted: Tue May 28, 2013 1:12 am |   |
				| Hi,
 PCM Programmer, yes you right to point out, I don't have pull ups on I2C. I will put the pull ups now and see if both I2C and RS232 work.
 Regards
 | You cannot post new topics in this forum You cannot reply to topics in this forum
