Zloi
| 18LF4620 hardware SPI bus problem |
Posted: Wed May 22, 2013 1:01 pm |
I have a weird spi problem when i try to communicate width cc2530znp chip. My mcu is pic18f4620, hardware spi (tried software SPI, it works but not on SPI pin RC4/SDI, tried pull up, poll down, put the serial resistor in line MI, change mcu to 18f45k22, the problem remains).
I'm trying to initialize cc2530 by hardware reseting it an then reading the poll msg from it, chip responds with chaotic data, like it is tree stating MI data line.
Sometimes initialization process goes well, I configure the cc2530znp, and can send and receive over the air msg, but this is in a very rare case..
Attached are scope traces.
First spi byte ok
First spi byte error
any suggestions what to do?
Is this problem related to, Rev. B5 Silicon Errata
http://ww1.microchip.com/downloads/en/DeviceDoc/80364a.pdf
or I'm incorrectly Initializing SPI port.
C compiler version 4.134
#include <18LF4620.h>
#fuses INTRC,NOWDT,NOPROTECT,NOLVP,PUT
//#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
//#use delay(crystal=10Mhz)
#use delay (clock=40Mhz,crystal=10Mhz ) //x4 PLL, CPU runs at 40Mhz,
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, ERRORS)
#define DEVID1_ADDR 0x3FFFFE
#define DEVID2_ADDR 0x3FFFFF
#define SPI_MODE_0_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H) //SPI Mode 0
#define SPI_MODE_0_1 (SPI_L_TO_H) //SPI Mode 1
#define SPI_MODE_1_0 (SPI_H_TO_L) //SPI Mode 2
#define SPI_MODE_1_1 (SPI_H_TO_L | SPI_XMIT_L_TO_H) //SPI Mode 3
#define RESET_ZNP PIN_C2 //Reset CC2530
#define MRDY_ZNP PIN_C0
#define SRDY_ZNP PIN_B0
//#define SS_ZNP PIN_C0 //ZNP SS, Slave select
//#define MI PIN_C4
//#define MO PIN_C5
//#define CS PIN_C2 //MAX7219
//#define CLK PIN_C3
void SystemInit(){
printf("System Power up\n\r");
disable_interrupts(GLOBAL);
output_high(MRDY_ZNP);
setup_adc(ADC_OFF);
// setup_vref(FALSE);
setup_psp(PSP_DISABLED);
// setup_wdt(WDT_OFF);
// setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8|T0_8_BIT); //
// setup_ccp1(CCP_PWM); // PWM period = [(PR2)+ 1] • 4 • 1/TOSC • TMR2 prescale value
// setup_timer_2(T2_DIV_BY_4,0xFF,2); // PWM period = [(99)+ 1] • 4 • 1/4E6 • 1 = 0,0001
// PWM frequency is = 1/0,0001 = 10000Hz = 10Khz
// setup_timer_3(T3_INTERNAL|T3_DIV_BY_8); //
// setup_timer_3(T3_EXTERNAL_SYNC|T3_DIV_BY_1); // TIMER3 korišten kao brojač, RC0 Ulaz za TIMER/COUNTER3,
// setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //Timer1 generira signal za CCP2 Compare modul
// setup_spi(SPI_DISABLED );
setup_spi(SPI_MASTER,SPI_CLK_DIV_16,SPI_SS_DISABLED,SPI_MODE_0_0)
//#use spi(MASTER,DI=PIN_B1,DO=PIN_C5,CLK=PIN_C3,BITS=8,MODE=0)
// soft works ok, but on DI PIN_B1
// cc2530 poll spi poll command
void ZNP_Poll(void){
// output_toggle(PIN_A1);
while(input(SRDY_ZNP)){};
output_low(MRDY_ZNP); //Select ZNP
// delay_cycles (6);
spi_xfer(0);
spi_xfer(0);
spi_xfer(0);
while(!input(SRDY_ZNP)){
// delay_cycles(5);
Data[0]=spi_xfer(0);
Data[1]=spi_xfer(0);
Data[2]=spi_xfer(0);
for(i=0;i<=Data[0];i++){
Data[i+3]=spi_xfer(0);
ZNP_SetDataReady();
output_high(MRDY_ZNP); //DeSelect ZNP
void main( void ){
// setup_oscillator(OSC_32MHZ);
SystemInit();
VariableInit();
int i;
for(i=0;i<6;i++){
output_toggle(PIN_A0);
delay_ms(200);
char devid1, devid2;
devid1 = read_program_eeprom(DEVID1_ADDR);
devid2 = read_program_eeprom(DEVID2_ADDR);
printf("dev ID 1 = %x\n\r", devid1);
printf("dev ID 2 = %x\n\r", devid2);
while (TRUE ){
ZNP_Poll();
//znp methods
ZNP_Decode_Data()...
or am I stuck with using soft spi ? |
Posted: Wed May 22, 2013 1:25 pm |
| Code: | | setup_spi(SPI_MASTER,SPI_CLK_DIV_16,SPI_SS_DISABLED,SPI_MODE_0_0) |
You're not really testing this, because this line doesn't compile. The
syntax for setup_spi() is to use the bitwise OR operator '|' to combine the
parameters, not commas. Also, SPI_SS_DISABLED is not used with
an SPI master. It's only used with a PIC SPI slave. |
Posted: Wed May 22, 2013 1:39 pm |
| Code: | #fuses INTRC,NOWDT,NOPROTECT,NOLVP,PUT
#use delay (clock=40Mhz,crystal=10Mhz ) //x4 PLL, CPU runs at 40Mhz, | First, get your clock setup fixed!
With INTRC you can never be running at 40MHz, most likely you are running at 32MHz.
I don't know where your printf output is going to but if it is any kind of UART output I'm surprised you get readable text.
Also note that the internal oscillator is not well suited for RS232 communications. RS232 requires a clock with 3% maximum tolerance and that is best achieved with a crystal clock.
| Code: | | setup_spi(SPI_MASTER,SPI_CLK_DIV_16,SPI_SS_DISABLED,SPI_MODE_0_0) | setup_spi accepts only 1 parameter. All options have to be or'ed together, just like you do in the setup_timer functions.
Also note that the SPI_SS_DISABLED parameter is for the slave only, on the master it generates an invalid configuration.
The CC2530 accepts a maximum SPI clock frequency of 4MHz, so with your PIC running at 32MHz / 40MHz you can try with the following setup: | Code: | | setup_spi(SPI_MASTER | SPI_CLK_DIV_16 | SPI_MODE_0_0) |
I checked the datasheet and SPI mode 0 is correct. |
Zloi
Posted: Wed May 22, 2013 2:02 pm |
| ckielstra wrote: | | Code: | #fuses INTRC,NOWDT,NOPROTECT,NOLVP,PUT
I'm experimenting with various clock settings, because of that the settings
are stated/noted.
I'm using printf just for debugging purpose, it's directed to rs232 PC serial port.
here is sample of returned data...
System Power up
dev ID 1 = 07
dev ID 2 = 0c
Resetting ZNP1
Decode Znp Data
ZNP -> 060000010200020501 //junk data
Unknown State
Resetting ZNP1
Decode Znp Data
ZNP -> 0201800102 //junk data
Unknown State
Resetting ZNP1
Decode Znp Data
ZNP -> 064180000200020001 //Data OK
PIC -> ZNP Clear Device on Reset
Decode Znp Data
ZNP -> 000000 //junk data
| Quote: |
more parameters separated by a comma is my fault when I was preparing the code for the forum post, in the source code, all parameters are or'ed together...
Did you perhaps view the attached images of scope traces ? |
Zloi
Posted: Wed May 22, 2013 2:05 pm |
| PCM programmer wrote: | | Code: | | setup_spi(SPI_MASTER,SPI_CLK_DIV_16,SPI_SS_DISABLED,SPI_MODE_0_0) |
I tried setup_spi() with and without this parameter, SPI_SS_DISABLED, |
