pavelustinov
| Convert from hex to int |
Posted: Fri Apr 12, 2013 6:17 am |
Hello everybody!
I store data "23" in EEPROM like this
| Code: | write_eeprom(1, 0x32);// save 2
write_eeprom(2, 0x33);// save 3
first = read_eeprom(1);
second = read_eeprom(2);
How can I convert to int and make
first*10 + second = 23
2*10 + 3=23 |
Posted: Fri Apr 12, 2013 8:42 am |
Start with the simple thing that the computer does not store hex. It works just in binary, which can then be represented by hex, octal, decimal etc..
So you have one cell containing the number 50, and one containing the number 51. These are the ASCII codes commonly used for the digits '2' and '3'.
Simplest way is just to subtract the offset between these values and the numbers they represent (48 - this is ASCII '0'), multiply and add.
So:
int8 val;
#define VALUE_OF(x) x-'0'
val=(VALUE_OF(first)*10)+VALUE_OF(second);
There is a generic conversion routine that can do this, but to use it, you would have to transfer the bytes into a character array, add a terminating '\0', and then call the routine. More work than just doing it manually.
pavelustinov
Posted: Fri Apr 12, 2013 2:11 pm |
| Ttelmah wrote: | Start with the simple thing that the computer does not store hex. It works just in binary, which can then be represented by hex, octal, decimal etc..
So:
int8 val;
I try this
write_eeprom(2, 0x30);
lcd_putc(val); |
But LCD doesn't display anything. Am I use this code correctly? |
Posted: Fri Apr 12, 2013 3:07 pm |
No.
You now have a variable called 'val' containing the number 20. You send this to the display. The number 20, is the character ' '. A space. So you will see nothing.....
You need to get a basic C textbook and understand the difference between the textual representation of a number, and the number itself. Given the original two characters _were_ the textual representation, why not just print these?. You have taken the text, converted it into the numeric representation, to print this, you need to format it as text (read up on what printf does). |
