TLC5940 16 Channel 12-Bit PWM Driver (Simple)
sshahryiar
PostPosted: Tue Apr 09, 2013 4:40 am     Reply with quote
TLC5940.c
#define VPRG               pin_B0
#define SIN                pin_B1
#define SCLK               pin_B2
#define XLAT               pin_B3
#define BLANK              pin_B4
#define DCPRG              pin_B5
#define GSCLK              pin_B6
#byte PORTB = 0xF81
unsigned char dcData[96] =
                  1, 1, 1, 1, 1, 1, // Ch 15
                  1, 1, 1, 1, 1, 1, // Ch 14
                  1, 1, 1, 1, 1, 1, // Ch 13
                  1, 1, 1, 1, 1, 1, // Ch 12
                  1, 1, 1, 1, 1, 1, // Ch 11
                  1, 1, 1, 1, 1, 1, // Ch 10
                  1, 1, 1, 1, 1, 1, // Ch 9
                  1, 1, 1, 1, 1, 1, // Ch 8
                  1, 1, 1, 1, 1, 1, // Ch 7
                  1, 1, 1, 1, 1, 1, // Ch 6
                  1, 1, 1, 1, 1, 1, // Ch 5
                  1, 1, 1, 1, 1, 1, // Ch 4
                  1, 1, 1, 1, 1, 1, // Ch 3
                  1, 1, 1, 1, 1, 1, // Ch 2
                  1, 1, 1, 1, 1, 1, // Ch 0
unsigned char gsData[192];
void TLC5940_Init();
void TLC5940_ClockInDC();
void TLC5940_SetGS_And_GS_PWM();
void changeGS(unsigned char channel, unsigned long dc);
void TLC5940_Init()
         output_low(GSCLK);
         output_low(SCLK);
         output_low(DCPRG);
         output_high(VPRG);
         output_low(XLAT);
         output_high(BLANK);
         memset(gsData, 0x00, sizeof(gsData));
           unsigned long cnt = 0;
           output_high(DCPRG);
           output_high(VPRG);
                             if(cnt > 95)
                                      output_high(XLAT);
                                      output_low(XLAT);
                                      if(dcData[cnt])
                                               output_high(SIN);
                                               output_low(SIN);
                                      output_high(SCLK);
                                      output_low(SCLK);
                                      cnt++;
         short firstCycle = FALSE;
         unsigned char Data_Cnt = 0;
         unsigned long GSCLK_Cnt = 0;
         if(bit_test(PORTB, 0))
                  output_low(VPRG);
                  firstCycle = TRUE;
         output_low(BLANK);
                  if(GSCLK_cnt > 4095)
                           output_high(BLANK);
                           output_high(XLAT);
                           output_low(XLAT);
                           if(firstCycle)
                                    output_high(SCLK);
                                    output_low(SCLK);
                                    firstCycle = FALSE;
                           if(!(Data_Cnt > 191))
                                    if(gsData[Data_cnt])
                                             output_high(SIN);
                                             output_low(SIN);
                                    output_high(SCLK);
                                    output_low(SCLK);
                                    Data_Cnt++;
                  output_high(GSCLK);
                  output_low(GSCLK);
                  GSCLK_cnt++;
         unsigned long start = 0;
         unsigned long stop  = 0;
         unsigned long s = 0;
         short tmp = 0;
         switch(channel)
                  case 1:
                           start = 168;
                           stop = 179;
                  case 2:
                           start = 156;
                           stop = 167;
                  case 3:
                           start = 144;
                           stop = 155;
                  case 4:
                           start = 132;
                           stop = 143;
                  case 5:
                           start = 120;
                           stop = 131;
                  case 6:
                           start = 108;
                           stop = 119;
                  case 7:
                           start = 96;
                           stop = 107;
                  case 8:
                           start = 84;
                           stop = 95;
                  case 9:
                           start = 72;
                           stop = 83;
                  case 10:
                           start = 60;
                           stop = 71;
                  case 11:
                           start = 48;
                           stop = 59;
                  case 12:
                           start = 36;
                           stop = 47;
                  case 13:
                           start = 24;
                           stop = 35;
                  case 14:
                           start = 12;
                           stop = 23;
                  case 15:
                           start = 0;
                           stop = 11;
                  default:
                           start = 180;
                           stop = 191;
         for(s = start; s <= stop; s++)
                  tmp = bit_test(dc, (stop - s));
                  gsData[s] = tmp;
Example
#include <18F252.h>
#device *= 16
#device ADC = 10
#fuses H4, NOWDT, PUT, PROTECT, NOSTVREN
#fuses NOCPB, NOWRT, NOWRTB NOEBTRB, NOEBTR
#fuses BROWNOUT, CPD, NOOSCSEN, BORV20
#fuses NOLVP, NODEBUG, NOWRTC, NOWRTD
#use delay(clock = 40MHz)
#include "TLC5940.c"
#define reload1  63035
#define reload2  40000
short update_flag = 0;
short pol = 1;
signed long d = 0;
void setup();
#int_timer1
void update()
         set_timer1(reload1);
         update_flag = 1;
#int_timer0
void update_cycle()
                  set_timer0(reload2);
                  if(pol)
                           d += 5;
                           if(d == 4095)
                                    pol = 0;
                                    d = 4095;
                           d -= 5;
                           if(d <= 0)
                                    pol = 1;
                                    d = 0;
         setup();
                  if(update_flag)
                           setup_timer_1(T1_disabled);
                           setup_timer_1(T1_internal);
                           update_flag = 0;
                  changeGS(0, d);
                  changeGS(2, d);
                  changeGS(4, d);
                  changeGS(6, d);
                  changeGS(1, (4095 - d));
                  changeGS(3, (4095 - d));
                  changeGS(5, (4095 - d));
                  changeGS(7, (4095 - d));
                  changeGS(8, d);
                  changeGS(10, d);
                  changeGS(12, d);
                  changeGS(14, d);
                  changeGS(9, (4095 - d));
                  changeGS(11, (4095 - d));
                  changeGS(13, (4095 - d));
                  changeGS(15, (4095 - d));
void setup()
   disable_interrupts(global);
   setup_WDT(WDT_off);
   setup_adc_ports(no_analogs);
   setup_adc(ADC_off);
   setup_timer_0(T0_internal);
   setup_timer_2(T2_DISABLED,255,1);
   setup_timer_3(T3_DISABLED);
   setup_CCP1(CCP_off);
   setup_CCP2(CCP_off);
   setup_SPI(SPI_DISABLED);
   set_timer2(0);
   set_timer3(0);
   enable_interrupts(global);
   enable_interrupts(int_timer1);
   enable_interrupts(int_timer0);
   TLC5940_Init();
https://www.facebook.com/MicroArena
SShahryiar
mhjccsinfo
PostPosted: Wed Sep 18, 2013 10:34 am     Reply with quote
Hello Dear Shahryar,
could you explain a little about the IC?
it was not clear from the datasheet that it's just for LED driving or for all-purpose PWM usage.
how much is this chip output_freq (by 50 percents duty_cycle)?
tnx
thanks and hope of success for you
Mohammad_Hosein
TMLtech
PostPosted: Wed Sep 25, 2013 11:39 am     Reply with quote
Thanks for sharing your code. I'll test your code for my next project.
