TLC548 8-bit SPI ADC Driver
sshahryiar
PostPosted: Tue Apr 09, 2013 4:22 am     Reply with quote
#include <16F87.h>
#device *= 16
#fuses NOWDT, INTRC, PROTECT, CPD, PUT, NOWRT
#fuses NOMCLR, BROWNOUT,  FCMEN, NOIESO, NOLVP
#define CS_pin             pin_A0
#define Data_In_pin        pin_A1
#define Clock_pin          pin_A2
#use delay (clock = 4MHz)
#use SPI(MASTER, DI = Data_In_pin, CLK = Clock_pin, BITS = 8, SAMPLE_RISE)
#include <lcd420.c>
void setup();
    register float v = 0.0;
    unsigned char adc_value = 0;
    setup();
        output_low(CS_pin);
        adc_value = spi_xfer(0);
        output_high(CS_pin);
        v = (adc_value * 5.0);
        v /= 255.0;
        lcd_gotoxy(1,1);
        printf(lcd_putc, "V: %1.2f Volt ", v);
        lcd_gotoxy(1,2);
        printf(lcd_putc, "ADC: %3u ", adc_value);
        delay_ms(200);
void setup()
    setup_oscillator(OSC_4MHZ);
    disable_interrupts(global);
    setup_WDT(WDT_off);
    setup_CCP1(CCP_off);
    setup_SPI(SPI_disabled);
    setup_timer_0(0 | 0 | 0);
    setup_timer_1(T1_disabled);
    setup_timer_2(T2_disabled, 255, 1);
    set_timer0(0);
    set_timer1(0);
    set_timer2(0);
    lcd_putc("\f");
https://www.facebook.com/MicroArena
SShahryiar
