thefloyd
| CAN bus |
Posted: Thu Mar 28, 2013 7:17 pm |
I'm undertaking a new project and I'm diving into some things I'm a bit green at. Some pointers/advice would be much appreciated..
I'm attempting to build a bridge from my vehicle's steering wheel controls to an iPod, as the car never had the option. This is a late model GM car, and as such I already know the steering wheel controls and some of the other things I may be interested in are on a low speed single wire CAN bus (speaking GMLan). I'm pretty sure I know enough about the protocol and what I'll see on the wire to make that bit work. I've also already been addressing an iPod over the 19.2k serial interface, so I've got THAT bit down.
What I'm unclear on is how to initialize and listen/speak CAN using CCS. I plan on using the TH8056 (melexis) external transceiver as that's already certified to work with GMLan setups. Any pointers/code snippets on how I can initialize the microcontroller's CAN interface at 33k (low speed CAN) and read/write from/to the bus? I explored using something like an ELM327 and speaking RS232 to CAN, but that seems silly given many PICs have a built in CAN module. A whole pile of parts (including a couple of different PICs with hardware CAN bus) will be arriving tomorrow so I'd love to try and tackle this over the weekend. Any pointers would be sincerely appreciated.
Thanks! |
thefloyd
Posted: Thu Mar 28, 2013 8:54 pm |
| Never mind.. I think I may have found what I was looking for in the examples and using the CAN configuration tool built into the PIC wizard, including the custom baud rate! |
Humberto
Posted: Mon Apr 01, 2013 12:46 pm |
thefloyd wrote:
| Quote: |
If this feature of your car it is an option, you could enable it using any GM Professional Diagnostic Scanner.
thefloyd wrote:
| Quote: |
Full details of the protocol used by GM it is not available easily. If you got such info, you must know -in detail- the protocol used by GM in
order to know each CAN frames and every CAN branches and its packet's privileges. Assuming that, you should also consider all nodes and
check the consistency of the message being received, the host system will acknowledge your mesage as consistent message, if not it will
flag as an inconsistent message in the ACK time SLOT and depending of the treatment that the ECU assign to this error, there are chances
that it would store it as an Fault Error triggering the Check Light.
I admit that it is an interesting project to play with. Another story is if you want to sniff or listen a specific packet and do something inocuous
without interfere the whole network.
regards,
Humberto |
