Pure PWM sine wave generator
mohammad3d
PostPosted: Tue Mar 26, 2013 12:14 am     Reply with quote
Hi all,
I try to write a Sine wave generator and think it must be helpful for
others.
This routine tested and work fine.
I use sine PWM at 10khz to create 50Hz sine wave.
// Pure PWM sine wave generator
// D0 ->--/\/\/\--|-- Sine output(~ 3vpp)
//        33Kohm  |
//               --- 100 nf
//               GND
#include <30F6014A.h>
#fuses XT
#use delay(clock=10M)
int16 i;
int16 PWM=0;//pwm step counter
int16 sin_table1[181];//Store 0~180 degree sine lookup table
int16 sin_table2[181];//Store 181~360 degree sine lookup table
#define PI 3.14159265
#define Step_delay 50 //micro second
#INCLUDE <math.h>
//////////////// setup PWM ///////////////////////////
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_1, 0x00fa);//PWM set to 250(0xfa)step at 10 Khz
setup_compare(1, COMPARE_PWM | COMPARE_TIMER3);//PIN 58 (PORT D0)
//////// fill sine lookup table //////////////////////
  for (i = 0; i <=180; i++)
    sin_table1[i]=125+floor(125*sin(i * PI /180));
    sin_table2[i]=250-sin_table1[i];
//////// main loop ///////////////////////////////////
 for(;;)
//////////// 0~180 degree loop ///////////////////////
   PWM=0;
   while(PWM<181)
       set_pwm_duty(1,sin_table1[PWM]);
       PWM++;
       delay_us(Step_delay);
//////////// 181~359 degree loop /////////////////////
   PWM=1;
   while(PWM<180)
       set_pwm_duty(1,sin_table2[PWM]);
       PWM++;
mohammad3d
improve algorithm ...
PostPosted: Thu Mar 28, 2013 1:10 am     Reply with quote
Hi all,
I improve last software algorithm.
//        33Kohm  |
//               --- 100 nf
//               GND
#fuses XT
int8 resync_step=0;
int16 i;
int16 Sine_wave_step=0;//pwm step counter
int16 sin_table[361];//Store 0~360 degree sine lookup table
#INCLUDE <math.h>
    sin_table[i]=125+floor(125*sin(i * PI /180));
    sin_table[i+180]=250-sin_table[i];
 for(;;)
//////////// 0~360 degree loop ///////////////////////
   Sine_wave_step=0;
   while(Sine_wave_step<360)
       set_pwm_duty(1,sin_table[ Sine_wave_step]);
       Sine_wave_step++;
ihsanbu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Thu Apr 25, 2013 11:39 pm     Reply with quote
ThanK for these codes , i need code to interface SIM900D GSM module with pic18f452 micro-controller.
regard
ihsanbu@gmail.com
ihsan ullah khan
Embedded Designer Since 2003
ihsanbu
PostPosted: Thu Apr 25, 2013 11:41 pm     Reply with quote
hi can i use this for pic18f452
ihsan ullah khan
mohammad3d
PostPosted: Thu Apr 25, 2013 11:58 pm     Reply with quote
Hi dear ihsan,
Yes, you can use this code for any kind of PIC18f series, but you must
configure your chip PWM module and step delay to get right frequency.
I don't know SIM900 module and don't know which kind of PWM you need,
but my code just simulate sine wave form just like 220v/50hz power line.
Very Happy
Regards,
Mohammad.
AsadZero2
18f4550
PostPosted: Wed Dec 18, 2013 10:20 am     Reply with quote
aoa Mohammed3d
I know I'm asking this after ages but i hope you or someone will be able to help me. I'm new to the uController thing and i need to generate a sine wave that'll vary in frequency upon certain conditions.
I used the code however there were some things i couldn't get to fix according to the pic18f4550.
#fuses XT
int8 resync_step=0;
int16 i;
#INCLUDE <math.h>
 for(;;)
   Sine_wave_step=0;
       set_pwm_duty(1,sin_table[ Sine_wave_step]);   // *** I'm getting paranthesis error in this line
       Sine_wave_step++;
So i changed the CODE to:
#include <18F4550.h>
#fuses XT
int8 resync_step=0;
int16 i;
#INCLUDE <math.h>
setup_timer_3(t3_INTERNAL | t3_DIV_BY_1);//PWM set to 250(0xfa)step at 10 Khz
//setup_compare(1, COMPARE_PWM | COMPARE_TIMER3);//PIN 58 (PORT D0) // *** I HAD TO DISABLE THIS LINE TO MAKE IT WORK
 for(;;)
   Sine_wave_step=0;
       set_pwm1_duty(sin_table[Sine_wave_step]);
       Sine_wave_step++;
I need to know which pin is it giving output on and how can i change the frequency of the output wave.
mohammad3d
change sine wave frequency.
PostPosted: Mon Dec 23, 2013 5:04 am     Reply with quote
Dear asad,
You can change "Step_delay" to take other period time.
If "step_delay = 50 ", your while loop execute about 0.02 second or 50 time
per second and you have an sine output with 50 Hz frequency.
Regards,
Mohammad Kouchekzadeh.
joanpebupe
PostPosted: Thu Feb 19, 2015 11:03 am     Reply with quote
Good afternoon!
I was looking for that style of code to do a sine wave with the pwm. i'm using PIC18F4331 and i would really like to know how implement this code but using power pwm instead of CCP/PWM.
above all i would like to know how configure the sentence:
set_power_pwm0_duty(*******)
cause I think it works different on power PWM.
Thanks!
Juanpe
