josb86
modbus in 16f887 "modbus_phy_layer_rtu.c " this sa |
Posted: Mon Apr 15, 2013 3:15 pm |
I am trying to implement modbus protocol in a pic16f887. I have the version 4.140 compiler. I use the project wizard option and when I wish to compile the program, it shows a error in the line "#USE TIMER(TIMER=1,TICK=.1ms,BITS=16, ISR)" of "modbus_phy_layer_rtu.c ". This say "line 25(9,47):internal error - contact ccs ppuse"
Code: | #include <v2.h>
#define MODBUS_BUS SERIAL
#define MODBUS_TYPE MODBUS_TYPE_SLAVE
#define MODBUS_SERIAL_TYPE MODBUS_RTU
#define MODBUS_SERIAL_RX_BUFFER_SIZE 64
#define MODBUS_SERIAL_RX_PIN PIN_C7
#define MODBUS_SERIAL_TX_PIN PIN_C6
//#define MODBUS_SERIAL_ENABLE_PIN PIN_
//#define MODBUS_SERIAL_RX_ENABLE PIN_
#define MODBUS_SERIAL_BAUD 9600
#define MODBUS_OUR_ADDRESS 230
#include "modbus.c"
{ boolean respond = false;
modbus_init();
fprintf(SLAVE_PC, "\n\rReady...");
while(!modbus_kbhit());
fprintf(SLAVE_PC, "\n\rBus Active");
if((respond = (modbus_rx.address == MODBUS_OUR_ADDRESS)) || modbus_rx.address == 0)
fprintf(SLAVE_PC, "\n\rRequest for us");
fprintf(SLAVE_PC, "\n\rFunction: %X", modbus_rx.func);
switch(modbus_rx.func)
case 0x01:
if(respond)
//read the coils
case 0x02:
if(respond)
//read discrete inputs
case 0x03:
if(respond)
//read holding registers
case 0x04:
if(respond)
//read input registers
case 0x05:
case 0x06:
case 0x07:
case 0x08:
if(respond) {modbus_diagnostics_rsp(MODBUS_OUR_ADDRESS,
make16(modbus_rx.data[0],modbus_rx.data[1]),
make16(modbus_rx.data[2], modbus_rx.data[3]));}
fprintf(SLAVE_PC, "\n\rResetting...");
reset_cpu();
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
Code: | #include <16F887.h>
#device adc=16
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT //Power Up Timer
#use FIXED_IO( A_outputs=PIN_A7,PIN_A6,PIN_A5,PIN_A4,PIN_A3,PIN_A2,PIN_A1,PIN_A0 )
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=SLAVE_PC) |
can any help me to resolve this problem? |
Posted: Mon Apr 15, 2013 3:30 pm |
It compiles with no errors for me. I made it all be one file.
I didn't include the bottom code as v2.h, I just put it at the top of
the main code. I used compiler vs. 4.140.
From the .LST file:
Quote: |
CCS PCM C Compiler, Version 4.140, 15-Apr-13 14:28
Filename: C:\Program Files\PICC\Projects\PCM_Test\PCM_Test.lst
ROM used: 1395 words (17%)
Largest free fragment is 2048
RAM used: 92 (25%) at main() level
110 (30%) worst case
Stack: 7 worst case (4 in main + 3 for interrupts) |
From the MPLAB Output window (Build tab):
Quote: |
Executing: "C:\Program files\Picc\CCSC.exe" +FM "C:\Program Files\PICC\Projects\PCM_Test\PCM_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA -EW
--- Info 300 "C:\Program Files\PICC\drivers\modbus_phy_layer_rtu.c" Line 25(1,1): More info: Timer 1 tick time is 102.40 us
Memory usage: ROM=17% RAM=25% - 30%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCM_Test\PCM_Test.cof.
BUILD SUCCEEDED: Mon Apr 15 14:28:04 2013 |
josb86
Posted: Tue Apr 16, 2013 8:12 am |
I tried reinstall the program and before it after compile ok |
