plateau
| Problems with dynamic memory in CCS (calloc and malloc) |
Posted: Wed Jan 23, 2013 5:04 pm |
HiHo, friends, are you all fine?
After so much problems in handling the interrupts, I've decided to use the KBHIT approach ( http://www.ccsinfo.com/forum/viewtopic.php?t=49774). Now, everything is ok but I have a doubt about dynamic memory use.
In my code, I have a pair of routines to write and read data from EEPROM. Both are based on native CCS EEPROM routines.
The read routine is:
| Code: | char* leStringEEPROM(int8 low, int8 high){
//char* texto = calloc((high-low),sizeof(char));
char texto[12];
int8 i,y=0;
for(i=low;i<high;i++){
texto[y] = (char)read_int16_eeprom(i);
y++;
return texto;
I don't know why, but this routine only works well when I declare the variable 'TEXTO' as a static length array. When I use the dynamic array associated with calloc, the array TEXTO always returns with wrong length (per example, if the right length would be 10, it returns 12).
Can anybody help me to solve this issue?
Regards,
Pedro Rosa. |
Posted: Wed Jan 23, 2013 8:52 pm |
Post a simple test program that can be run in MPLAB Simulator, so we
can test your problem. And post your compiler version.
Here's an example. Post a program similar to this. Tell us what you
expect it to display, and tell us what you actually see as the output.
#include <18F4680.h>
#use delay(clock=16M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS )
#include <stdlibm.h>
char *texto;
int8 i, y=0;
texto = calloc((high-low), sizeof(char));
for(i=low; i<high; i++){
texto[y] = y; // (char)read_int16_eeprom(i);
y++;
return texto;
int8 i;
char *ptr;
ptr = leStringEEPROM(0, 10);
for(i = 0; i < 12; i++)
printf("%X ", *ptr++);
printf("\r");
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Wed Jan 23, 2013 9:48 pm |
The code looks OK. You are taking into account the trailing zero that C strings require?
I would seriously recommend avoiding dynamic memory on microcontrollers. PICs don't have enough memory to make it worthwhile. Those functions are just there (IMHO) to make it easier to reuse existing code. Stick with statically allocated memory. _________________ Andrew |
plateau
Posted: Thu Jan 24, 2013 6:08 am |
| andrewg wrote: | The code looks OK. You are taking into account the trailing zero that C strings require?
I would seriously recommend avoiding dynamic memory on microcontrollers. PICs don't have enough memory to make it worthwhile. Those functions are just there (IMHO) to make it easier to reuse existing code. Stick with statically allocated memory. |
HiHo, andrewg, how are you?
First of all, thank you so much for having replied me.
At the first moment, I determined the size of array using the calloc instruction:
| Code: | | char* texto = calloc((high-low),sizeof(char)); |
But it never worked well...the array 'TEXTO' always returns the wrong size.
Looking your reply about my code doesn't ensure the null-terminated character and some related doubts in other places around the internet, I've tried to increase by 1 Byte the size of array in the calloc instruction (i.e
| Code: | | char* texto = calloc((high-low)+1],sizeof(char)); |
and now it seems to work. :-D ).
From now on, I'll not use dynamic memory in PIC :-D
One more time, thank you so much.
Best regards,
Pedro Rosa!  |
