Mahdi
| pic16f1938 internal oscillator -lcd problem[Solved] |
Posted: Fri Nov 30, 2012 5:35 pm |
Hi. I want to show the message in 2*16 lcds with pic16f1938 with internal oscillator. But when I write the lcd register defined in ccs the pic does not work. For example:
This code is not work
#include <16F1938.h>
#FUSES INTRC_IO
#use delay(clock=4m)
#define use_portB_lcd TRUE
#define LCD_ENABLE_PIN PIN_B3
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B2
#define lcd_data4 pin_b4
#define lcd_data5 pin_b5
#define lcd_data6 pin_b6
#define lcd_data7 pin_b7
#define LCD_TYPE 2
#include <lcd.c>
lcd_init();
while(true)
lcd_gotoxy(1,1);
printf(lcd_putc,"Hi");
output_toggle(pin_c2);
But this code is work:
#FUSES INTRC_IO
while(true)
One thing I have to say that all codes will work on Proteus.
This is my circuit:
Where is the problem?
Posted: Fri Nov 30, 2012 8:53 pm |
hints..
1) Proteus is NOT a 'good' simulator. If you wired up your circuit as shown in the Proteus schematic the LCD will never, ever work.
2) Most PIC I/O pins will serve several purposes and other 'peripherals' must be disabled. Typically I/O pins with ADC capability will be defaulted to ADC use, thus overriding basic I/O use.
3)How do you know program 2 works? Do you use an oscilloscope to see the output on C2? If not, put an LED (and correct resistor) on it to visually confirm proper operation.
4) It's better to use the 'flex_lcd.c' driver. Most here use it, I think.
5) Check the 'timing' setup for your LCD. Not all are the same.
6) You MUST call lcd_init() before sending the LCD any data. Think of lcd_init() as the 'key' that unlocks the door (the LCD module). You can't get in until it's unlocked.
hth
jay |
Mahdi
Posted: Sat Dec 01, 2012 2:13 am |
| Quote: | | 3)How do you know program 2 works? Do you use an oscilloscope to see the output on C2? If not, put an LED (and correct resistor) on it to visually confirm proper operation. |
i use the led.when i write the lcd define in ccs the lcd not flashes but when delete the lcd register the pic is work and led flashes properly
i test this code with pic16f877a and external osc it work properly.now my problem is with internal osc
I do not know what to do |
Posted: Sat Dec 01, 2012 7:59 am |
The define 'USE_PORTB_LCD', requires the LCD pins to be wired as:
B0 enable
B1 RS
B2 RW
B3 N/C
B4...B7 to the LCD D4 to D7 pins.
When this define is used, the individual pin defines are ignored.....
You have the N/C pin on B0, which won't work with this define.
Obviously on a real display, the lack of supply connections to the display will prevent it working. One of the dangers of Proteus.
Mahdi
Posted: Sat Dec 01, 2012 10:46 am |
| Ttelmah wrote: | The define 'USE_PORTB_LCD', requires the LCD pins to be wired as:
B0 enable
B1 RS
B2 RW
B3 N/C
when i delete lcd_init(); and printf(lcd_putc,"Hi"); the led on pin_c2 start to blinking.
According to Ttelmah i connect lcd pin as standard mode
#define LCD_ENABLE_PIN PIN_b0
#define LCD_RS_PIN PIN_b1
#define LCD_RW_PIN PIN_b2
#define LCD_DATA4 PIN_b4
#define LCD_DATA5 PIN_b5
#define LCD_DATA6 PIN_b6
#define LCD_DATA7 PIN_b7
but its not work
this is my code
it work and the led start to blinking:
| Code: | #include <16F1938.h>
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES WDT_SW
#FUSES NOBROWNOUT
#FUSES NOLVP
#use delay(int=4000000)
#include <lcd.c>
delay_ms(300);
its not work and the led not blinking:
#FUSES WDT_SW //No Watch Dog Timer, enabled in Software
#include <lcd.c>
lcd_init();
delay_ms(300);
lcd_gotoxy(1,1);
when i touch the pin_b7, the led become switch on and again when i touch the pin_b7 the led become switch off.in fact my finger play oscillator roll.
whats the reason of this event? |
Mahdi
Posted: Sun Dec 02, 2012 6:19 am |
| i pull down the pin b7 and its work properly.thanks alot |
