pingpong
| 18f4620 tcpip server multiple devices on an intranet |
Posted: Mon Nov 26, 2012 8:28 am |
I have made a Datalogger made from 18f4620 with tcpip using enc28j60. The device works well and communicates the data collected from an instrument to the PC based application.
A single device connected in an intranet works OK.
The problem is when I want to have multiple such devices communicating readings from different instruments on either the same or multiple PC's all connected in the same intranet. Since the instruments are different, their PC programs are also different.
At present, I am keeping the port address of 1000 for all the devices and assigning different IP address to each device. I am able to connect to only one device. I want to communicate on all devices on the same intranet.
Can someone help please.
Jimmy. |
bkamen
Posted: Mon Nov 26, 2012 12:20 pm |
A lot more information would help on this...
Are you doing TCP or UDP? Are the connections persistent or created/released as needed?
Anyway, the first thing that comes to mind is this:
Did you see the number of sockets definition in the PIC tcpip stack? This limits the number of simultaneous connections the PIC will allow.
What is that number of sockets currently set at? _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
pingpong
Posted: Mon Nov 26, 2012 12:38 pm |
Thanks bkamen
I am implementing Tcp. My software is a client and the 18f is server. I connect to my 18f before starting and that connection remains on all through out.
At present the max sockets is 5. But I am going to change that to 1 tomorrow as I don't want my device to be accessible to multiple PC simultaneously.
As soon as a reading is received, my device sends the reading to the pc software. |
dorinm
Posted: Sun Dec 02, 2012 5:10 am |
| are your MAC#s different? |
pingpong
Posted: Sun Dec 02, 2012 6:44 am |
| No The Mac's are the same. |
asmallri
Joined: 12 Aug 2004 Posts: 1676 Location: Perth, Australia
Posted: Sun Dec 02, 2012 8:33 am |
| pingpong wrote: | | No The Mac's are the same. |
MACs in theory should be globally unique. In practice you can have duplicate MAC addresses provided these addresses do not occur on the same network segment.
If you have multiple devices on the same network segment (broadcast domain) then you will break the network layer and chaos will reign. LAN switches will thrash their tables as they learn the same MAC address in the same VLAN on different ports. IP forwarding for devices sharing the same MAC address will break, Devices will intermittently become unreachable. _________________ Regards, Andrew
pingpong
Posted: Sun Dec 02, 2012 9:10 am |
OK I tried with different MAC Addresses and the thing worked.
Thanks all of you. |
gpsmikey
Posted: Sun Dec 02, 2012 10:02 am |
I forget just where I saw it, but someone suggested having one of the digital temperature sensors on your board. Not only does it provide temperature, it also has a unique serial number which can then be used to build the MAC address for your board. The end result is you don't have to customize the code for each board to define the unique MAC address, it ends up with a unique address due to the unique serial number of the sensor. Struck me at the time as a clever idea that would solve the problem easily.
mikey _________________ mikey
bkamen
Posted: Sun Dec 02, 2012 10:51 am |
| gpsmikey wrote: | | I forget just where I saw it, but someone suggested having one of the digital temperature sensors on your board. Not only does it provide temperature, it also has a unique serial number which can then be used to build the MAC address for your board. |
For Dallas One-Wire devices, that's true, but Dallas makes those numbers up themselves and to my knowledge, those devices are not registered in the official MAC address block database.
So while it might work fine, technically, that device could bump into MAC addresses that are truly assigned in the big MAC database...
That's not a solution I would release into the wild in mass quantities. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Sun Dec 02, 2012 10:52 am |
Something useful about MAC addresses is that bit 1 in the first byte marks the address as "locally administered". You will (er, should) never see a "real" MAC address with that bit set, so if you're making up your own addresses, setting that bit should guarantee no collisions. i.e. 02:XX:XX:XX:XX:XX.
Something I also noticed the other day was that Microchip have added MAC addresses into a selection of their RTC chips (in addition to the range of EEPROMs with MAC addresses). It's becoming ever easier to get proper MAC addresses into a design. _________________ Andrew |
gpsmikey
Posted: Sun Dec 02, 2012 9:00 pm |
Good points Ben - I am used to my local network here where I am not likely to run into a problem, but you are correct about it not being a good plan to release into the "wild" (we all know how Murphy lurks around the corners). I did hear about 10 years back (when I was taking a Cisco class) that some vendors were starting to re-use some of their old MAC addresses figuring that the original hardware they had created was very unlikely to exist any more.
bkamen
Posted: Sun Dec 02, 2012 9:08 pm |
| gpsmikey wrote: | Good points Ben - I am used to my local network here where I am not likely to run into a problem, but you are correct about it not being a good plan to release into the "wild" (we all know how Murphy lurks around the corners). I did hear about 10 years back (when I was taking a Cisco class) that some vendors were starting to re-use some of their old MAC addresses figuring that the original hardware they had created was very unlikely to exist any more.
Yep! And not that it's unacceptable for in the lab use..
I have a stack of old ethernet cards that have been destroyed (recycled) and I kept the MAC addresses around...
but that whole release into the wild -- just mentioning it so people don't think it's a free pass. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
bkamen
Posted: Sun Dec 02, 2012 9:09 pm |
| andrewg wrote: | Something useful about MAC addresses is that bit 1 in the first byte marks the address as "locally administered". You will (er, should) never see a "real" MAC address with that bit set, so if you're making up your own addresses, setting that bit should guarantee no collisions. i.e. 02:XX:XX:XX:XX:XX.
until you put such a device out in mass quantities in the real world and it runs into someone else doing the same thing. hahah. that would suck.
As for the rest about microchip selling so many other single use MAC on an EEPROM or what -- it just makes it soooo easy.
