HELP!!!! glcd problem in pic18f452
sudarsan
PostPosted: Wed Nov 21, 2012 11:28 pm     Reply with quote
I am using jhd24064c glcd (t6963c controller).
Datasheet for glcd jhd24064c:
http://img09.b2b.hc360.com/pic-9/handbook-pic-1/9-1-1275991.pdf
http://www.ccsinfo.com/forum/viewtopic.php?t=49389&highlight=t6963c+pic16f877a
glcd code is working with pic16f877a.
Hardware connection:
C0 ---WRITE
C1----READ
C2----CE
C3----CD
C4----RST
PORT D - DATA
When I am trying to implement the same code (with alternate port address) in pic18f452, glcd not display. But its working in Proteus simulation.
Plz help me ! I don't know why it's not displayng.
PostPosted: Thu Nov 22, 2012 6:36 am     Reply with quote
1) Please read the very first post PIC101......
2) "with alternate port address". Which port? Have you disabled every onboard peripheral on that port.
3) code written for one PIC series will not 'instantly' work for another. 16 series is far different than the 18 series with respect to pin usages, register addresses, fuses, etc.
The code will have to be modified for use on the 18F452.
hth
jay
PostPosted: Thu Nov 22, 2012 10:01 am     Reply with quote
As a separate comment though, before trying to get the GLCD driver working have you fully verified the PIC18, is actually running, and running at the right frequency:
Simple 'flash an LED program, and verify the LED does flash, and at the speed expected.
PIC's require their oscillators to work, and things like LCD code, require that they are running at the right frequency. Proteus, will accept what you tell it is the oscillator frequency, even if it is impossible, and will make the power connections without showing them. Errors in either of these will stop a real PIC working.
