stoyanoff
| Problem with debugging of 18F66J60 |
Posted: Thu Nov 08, 2012 3:26 am |
Hi! I made a program for 18F66J60. It combines TCPIP stack and MDD card stack. The program compiles but when I run it it blocks.
When I stop the debugger(PicKit 3) it points to
#use delay(clock=25 000 000)
Here is the code before this row:
#include <18f66j60.h>
#fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
#define PIN_LED1 PIN_B5
#define PIN_LED2 PIN_B4
#define PIN_LED3 PIN_B3
#define LED_ON(x) output_low(x)
#define LED_OFF(x) output_high(x)
#define BUTTON_PRESSED() !input(PIN_A4)
#include "filesystem\p18cxxx.h" //C18 to PCH compatability
#use delay(clock=25000000)
Can you tell me what`s causing that???
Thanks! |
rodrigo.bzsilva
| Re: Problem with debugging of 18F66J60 |
Posted: Tue Nov 20, 2012 6:13 am |
| stoyanoff wrote: | Hi! I made a program for 18F66J60. It combines TCPIP stack and MDD card stack. The program compiles but when I run it it blocks.
Thanks! |
try to use the directive #use delay before the defines.. soon after the #fuses.. |
