creating a function to output a string into LCD ?
small_chick
PostPosted: Wed Nov 14, 2012 6:43 pm     Reply with quote
I'd like to create a function to output a string into LCD, but there's a problem here.
lcd.h code:
#define      LCD_module
#ifdef      LCD_module
#define   LCD_RS      RD1
#define   LCD_EN      RD3
#define   LCD_RW      RD2
#define   LCD_DATA4   RD4
#define   LCD_DATA5   RD5
#define   LCD_DATA6   RD6
#define   LCD_DATA7   RD7
#define   LCD_RS_TRIS      TRISD1
#define   LCD_EN_TRIS      TRISD3
#define   LCD_RW_TRIS      TRISD2
#define   LCD_DATA4_TRIS   TRISD4
#define   LCD_DATA5_TRIS   TRISD5
#define   LCD_DATA6_TRIS   TRISD6
#define   LCD_DATA7_TRIS   TRISD7
typedef union _BYTE_VAL
    unsigned char Val;
    struct
        unsigned char b0:1;
        unsigned char b1:1;
        unsigned char b2:1;
        unsigned char b3:1;
        unsigned char b4:1;
        unsigned char b5:1;
        unsigned char b6:1;
        unsigned char b7:1;
    } bits;
} BYTE_VAL;
unsigned char lcd_get_byte(unsigned char rs);
void lcd_put_byte(unsigned char rs, unsigned char b);
int1 lcd_busy();
void lcd_gotoxy(unsigned char col, unsigned char row);
void lcd_putc(char c);
void lcd_init();
void lcd_clear();
#endif
lcd.c code:
#include "lcd.h"
#include "IO_module.h"
#use delay(clock = 4000000)
   BYTE_VAL b;
   LCD_DATA4_TRIS = 1;
   LCD_DATA5_TRIS = 1;
   LCD_DATA6_TRIS = 1;
   LCD_DATA7_TRIS = 1;
   LCD_RW = 1;
   LCD_RS = 0;
   if(rs) LCD_RS = 1;
   delay_us(20);
   LCD_EN = 1;
   delay_us(20);
   b.bits.b7 = LCD_DATA7;
   b.bits.b6 = LCD_DATA6;
   b.bits.b5 = LCD_DATA5;
   b.bits.b4 = LCD_DATA4;
   LCD_EN = 0;
   delay_us(20);
   LCD_EN = 1;
   delay_us(20);
   b.bits.b3 = LCD_DATA7;
   b.bits.b2 = LCD_DATA6;
   b.bits.b1 = LCD_DATA5;
   b.bits.b0 = LCD_DATA4;
   LCD_EN = 0;
   return b.Val;
   BYTE_VAL temp;
   LCD_DATA4_TRIS = 0;
   LCD_DATA5_TRIS = 0;
   LCD_DATA6_TRIS = 0;
   LCD_DATA7_TRIS = 0;
   LCD_RS = 0;
   if(rs) LCD_RS = 1;
   delay_us(20);
   LCD_RW = 0;
   delay_us(20);
   LCD_EN = 0;
   temp.Val = b;
   // send the high nibble
   LCD_DATA4 = temp.bits.b4;
   LCD_DATA5 = temp.bits.b5;
   LCD_DATA6 = temp.bits.b6;
   LCD_DATA7 = temp.bits.b7;
   delay_us(20);
   LCD_EN =  1;
   delay_us(20);
   LCD_EN = 0;
   // send the low nibble
   LCD_DATA4 = temp.bits.b0;
   LCD_DATA5 = temp.bits.b1;
   LCD_DATA6 = temp.bits.b2;
   LCD_DATA7 = temp.bits.b3;
   delay_us(20);
   LCD_EN =  1;
   delay_us(20);
   LCD_EN = 0;
int1 lcd_busy()
   int1 busy;
   LCD_DATA4_TRIS = 1;
   LCD_DATA5_TRIS = 1;
   LCD_DATA6_TRIS = 1;
   LCD_DATA7_TRIS = 1;
   LCD_RW = 1;
   LCD_RS = 0;
   delay_us(20);
   LCD_EN = 1;
   delay_us(20);
   busy = LCD_DATA7;
   LCD_EN = 0;
   delay_us(20);
   LCD_EN = 1;
   delay_us(20);
   LCD_EN = 0;
   return busy;
   unsigned char address;
   if(row!=0)
      address=0x40;
      address=0;
   address += col;
   lcd_put_byte(0,0x80|address);
   while(lcd_busy());
 switch(c)
    case '\f':
      lcd_put_byte(0,1);
      delay_ms(2);
    case '\n':
       lcd_gotoxy(1,2);
    case '\b':
       lcd_put_byte(0,0x10);
    default:
       lcd_put_byte(1,c);
void lcd_init()
   int8 temp;
   LCD_EN_TRIS = 0;
   LCD_RS_TRIS = 0;
   LCD_RW_TRIS = 0;
   LCD_DATA4_TRIS = 0;
   LCD_DATA5_TRIS = 0;
   LCD_DATA6_TRIS = 0;
   LCD_DATA7_TRIS = 0;
   LCD_EN = 0;
   LCD_RS = 0;
   LCD_RW = 0;
   delay_ms(100);            // delay for power on
   // reset LCD
   lcd_put_byte(0,0x30);
   delay_ms(50);
   delay_ms(50);
   lcd_put_byte(0,0x32);
   delay_ms(100);            // delay for LCD reset
   while(lcd_busy());
   /*Function set:4 bit interface + 2 lines + 5x7 dot format
   lcd_put_byte(0,0x28);
   while(lcd_busy());
   /*display off + cursor underline & cursor blink off
   lcd_put_byte(0,0x08);
   while(lcd_busy());
   /*display on + cursor underline & cursor blink off
   lcd_put_byte(0,0x0C);
   while(lcd_busy());
   /*clear display and move cursor to home
   lcd_put_byte(0,0x01);
   while(lcd_busy());
   /*Character Entry mode:increment + display shift off
   lcd_put_byte(0,0x06);
   while(lcd_busy());
void lcd_clear()
   lcd_put_byte(0,1);      // display off
   while(lcd_busy());
void lcd_puts(const char* s)
   while(*s)
      lcd_putc(*s++);
and error statements from MPLAB:
*** Error 28 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 196(21,25): Expecting an identifier
*** Error 48 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 196(27,28): Expecting a (
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 197(1,2): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 198(1,6): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 198(6,7): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 198(7,8): Expecting a declaration
*** Error 48 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 198(8,9): Expecting a (
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 199(1,2): Expecting a declaration
*** Error 32 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 200(11,12): Expecting a , or )
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 200(14,15): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 200(15,16): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 201(1,2): Expecting a declaration
*** Error 43 "D:\document\Study\university of technology\sesmester_7\Embedded System Design\Big_assignment\lcd.c" Line 202(1,2): Expecting a declaration
13 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Nov 14 19:39:52 2012
problem here is "lcd_puts", i don't know why CCS can't accept "const char* s" ? this function works well in Hi-tech compiler !Looking forward to receiving your support !
Very Happy
PostPosted: Wed Nov 14, 2012 8:28 pm     Reply with quote
CCS doesn't do constant strings in the same way as Hi-Tech.
Solution:
Don't use 'const' in the function declaration, and add the #device
statement: PASS_STRINGS=IN_RAM
small_chick
PostPosted: Wed Nov 14, 2012 9:58 pm     Reply with quote
it's well-done now, PCM programmer ! thank you very much ! Very Happy
small_chick
PostPosted: Thu Nov 15, 2012 6:23 pm     Reply with quote
I've tried lcd.h &.c with PIC16F887 and dsPIC30F4011.Then they work well with only PIC16F887 .
Here the code for PIC16F887:
#include <16F887.h>
#device PASS_STRINGS = IN_RAM
#fuses   XT,NOWDT,PUT,BROWNOUT,BORV40
#include "lcd.c"
   lcd_puts("adc");
when using dsPIC30F4011, I only changed in lcd.h as following:
#define   LCD_RS      RB1
#define   LCD_EN      RB3
#define   LCD_RW      RB2
#define   LCD_DATA4   RB4
#define   LCD_DATA5   RB5
#define   LCD_DATA6   RB6
#define   LCD_DATA7   RB7
#define   LCD_RS_TRIS      TRISB1
#define   LCD_EN_TRIS      TRISB3
#define   LCD_RW_TRIS      TRISB2
#define   LCD_DATA4_TRIS   TRISB4
#define   LCD_DATA5_TRIS   TRISB5
#define   LCD_DATA6_TRIS   TRISB6
#define   LCD_DATA7_TRIS   TRISB7
a part of code in IO_module.h (included in lcd.c):
#word    TRISB = 0x02C6
#word   PORTB = 0x02C8
#word   LATB = 0x02CA
#bit   TRISB8 = 0x02C6.8
#bit   TRISB7 = 0x02C6.7
#bit   TRISB6 = 0x02C6.6
#bit   TRISB5 = 0x02C6.5
#bit   TRISB4 = 0x02C6.4
#bit   TRISB3 = 0x02C6.3
#bit   TRISB2 = 0x02C6.2
#bit   TRISB1 = 0x02C6.1
#bit   TRISB0 = 0x02C6.0
#bit   RB0 = 0x02C8.0
#bit   RB1 = 0x02C8.1
#bit   RB2 = 0x02C8.2
#bit   RB3 = 0x02C8.3
#bit   RB4 = 0x02C8.4
#bit   RB5 = 0x02C8.5
#bit   RB6 = 0x02C8.6
#bit   RB7 = 0x02C8.7
#bit   RB8 = 0x02C8.8
#bit   LATB0 = 0x02CA.0
#bit   LATB1 = 0x02CA.1
#bit   LATB2 = 0x02CA.2
#bit   LATB3 = 0x02CA.3
#bit   LATB4 = 0x02CA.4
#bit   LATB5 = 0x02CA.5
#bit   LATB6 = 0x02CA.6
#bit   LATB7 = 0x02CA.7
#bit   LATB8 = 0x02CA.8
code in main.c:
#include    <30F4011.h>
#include   "lcd.c"
#fuses XT,NOWDT,PUT64,BROWNOUT,BORV42
   ADPCFG = 0xFFFF;//config all ANx as digital
   lcd_puts("adc");
I suppose the problem here is in lcd_init() because when i try it, it's always stuck in lcd_busy() ! I can't understand why this happened with dsPIC30F4011 but didn't with PIC16F887 ???? Please help me ! Sad
PostPosted: Fri Nov 16, 2012 2:11 am     Reply with quote
Fractionally puzzled what code you are actually using?. The standard lcd.c, that comes with the compiler, doesn't have an lcd.h, or an IO_module.h, nor does it use register bit definitions for the ports. Switch to the standard driver as a 'first thing to do'. In all honesty, flex_lcd, is more flexible, and possibly more likely to work.
The general thing that causes a problem on a particular chip, is that the pins being used 'wake up' configured to something else. Try making sure that analog functions are turned off on these pins before starting.
