How to use multi dimentional array
Gerrit
PostPosted: Tue May 20, 2003 11:37 am     Reply with quote
Can some one help,
I have the next structure and array. What ways can I use to copy an element of Modulo_Index to the Structure Red_Modulo.
char const Modulo_Index[3][4] =
{{0x00, 0x00, 0x00, 0x00},
{0x00, 0x01, 0x00, 0x00},
{0x01, 0x00, 0x01, 0x00}};
typedef struct {
char First;
char Second;
char Thirdth;
char Fourth;
}RGB_Modulo;
RGB_Modulo Red_Modulo;
Original Post ID: 144514597
Re: How to use multi dimentional array
PostPosted: Tue May 20, 2003 1:51 pm     Reply with quote
:=Can some one help,
:=I have the next structure and array. What ways can I use to copy an element of Modulo_Index to the Structure Red_Modulo.
:=char const Modulo_Index[3][4] =
:= {{0x00, 0x00, 0x00, 0x00},
:= {0x00, 0x01, 0x00, 0x00},
:= {0x01, 0x00, 0x01, 0x00}};
:=typedef struct {
:= char First;
:= char Second;
:= char Third;
:= char Fourth;
:= }RGB_Modulo;
:=RGB_Modulo Red_Modulo;
Red_Modulo.First = Modulo_Index[0][0];
Red_Modulo.Second = Modulo_Index[0][1];
Red_Modulo.Third = Modulo_Index[0][2];
Red_Modulo.Fourth = Modulo_Index[0][3];
Original Post ID: 144514600
R.J.Hamlett
PostPosted: Tue May 20, 2003 2:57 pm     Reply with quote
:=typedef struct {
:= char First;
:= char Second;
:= char Thirdth;
:= char Fourth;
:= }RGB_Modulo;
This line makes no sense. If you want to use 'RGB_Modulo', as a new 'type', you will need to use a typedef.
RGB_Modulo.First=Modulo_Index[0][0];
This will copy the first element in the array, into the first entry in the structure.
Original Post ID: 144514601
Gerrit
PostPosted: Tue May 20, 2003 3:15 pm     Reply with quote
Hello PCM programmer,
What you sugested I have tested and that works.
What I want to know is if I can use a single element from
Modulo_Index[x] to palce in the structur Red_Modulo (all four
value's)
CCS if giving no error or warning on this
Red_Modulo = Modulo_Index[x];
What am I doing here? cant figger it out.
Regards,
Gerrit
:=:=Can some one help,
:=:=I have the next structure and array. What ways can I use to copy an element of Modulo_Index to the Structure Red_Modulo.
:=:=char const Modulo_Index[3][4] =
:=:= {{0x00, 0x00, 0x00, 0x00},
:=:= {0x00, 0x01, 0x00, 0x00},
:=:= {0x01, 0x00, 0x01, 0x00}};
:=:=typedef struct {
:=:= char First;
:=:= char Second;
:=:= char Third;
:=:= char Fourth;
:=:= }RGB_Modulo;
:=:=RGB_Modulo Red_Modulo;
:=Red_Modulo.First = Modulo_Index[0][0];
:=Red_Modulo.Second = Modulo_Index[0][1];
:=Red_Modulo.Third = Modulo_Index[0][2];
:=Red_Modulo.Fourth = Modulo_Index[0][3];
Original Post ID: 144514602
Gerrit
PostPosted: Tue May 20, 2003 3:16 pm     Reply with quote
value's)
Regards,
Gerrit
:=:= char First;
:=:= char Second;
:=:= char Third;
:=:= char Fourth;
:=:= }RGB_Modulo;
Original Post ID: 144514603
PostPosted: Tue May 20, 2003 4:01 pm     Reply with quote
:=What you sugested I have tested and that works.
:=What I want to know is if I can use a single element from
:=Modulo_Index[x] to palce in the structur Red_Modulo (all four
:=value's)
:=CCS if giving no error or warning on this
:= Red_Modulo = Modulo_Index[x];
It gives me an error. It says "Bad expression syntax".
That's with PCM vs. 3.148.
Modulo_Index is defined as a two-dimensional array,
but you're trying to use it as a one-dimensional array.
So that's why it gives the error.
What's wrong with using the method of copying the bytes
that I posted ? Are you looking for a method that
only takes one line of C code, or is there some other reason ?
Original Post ID: 144514606
Gerrit
PostPosted: Tue May 20, 2003 5:23 pm     Reply with quote
No not pritacarly looking for a one line command
but, what I'm doing wrong or why CCS is not
reporting an error.
It has taken me a lot of time testing today And I could not explain what I was doing wrong.
The line I used copied 3 variables to the structure. I'am
using Version 3.152, 18034.
I will modify my software tomorrow at work.
Thanks for the response
reagrds,
Gerrit
:=:=What you sugested I have tested and that works.
:=:=What I want to know is if I can use a single element from
:=:=Modulo_Index[x] to palce in the structur Red_Modulo (all four
:=:=value's)
:=:=CCS if giving no error or warning on this
:=:= Red_Modulo = Modulo_Index[x];
:=It gives me an error. It says "Bad expression syntax".
:=That's with PCM vs. 3.148.
:=Modulo_Index is defined as a two-dimensional array,
:=but you're trying to use it as a one-dimensional array.
:=So that's why it gives the error.
:=What's wrong with using the method of copying the bytes
:=that I posted ? Are you looking for a method that
:=only takes one line of C code, or is there some other reason ?
Original Post ID: 144514608
PostPosted: Tue May 20, 2003 5:38 pm     Reply with quote
:=No not pritacarly looking for a one line command
:=but, what I'm doing wrong or why CCS is not
:=reporting an error.
:=It has taken me a lot of time testing today And I could not explain what I was doing wrong.
:=The line I used copied 3 variables to the structure. I'am
:=using Version 3.152.
I installed PCM vs. 3.152 and it gave me an error message:
But 3.152 has got some serious problems. For example, it
will not give an error if you're missing a closing brace.
I just did a test right now. I removed the closing brace
from main(). It didn't complain at all.
I would switch to either vs. 3.148 or 3.158, if you're able to.
Original Post ID: 144514609
Woody
Arrays of structures
PostPosted: Wed May 21, 2003 4:43 am     Reply with quote
<font face="Courier New" size=-1>In order to assign values to the whole structure in one go you will need to change your array to an array of structures, rather than a two dimensional array. ( Unless it needs to be a two dimensional array for some other reason. )
#include <16f876.h>
typedef struct {
char First;
char Second;
char Third;
char Fourth;
} RGB_Modulo;
const RGB_Modulo Modulo_Index [3] = {
void main (void)
Red_Modulo = Modulo_Index [1];
}</font>
Original Post ID: 144514625
Gerrit
Re: Arrays of structures
PostPosted: Wed May 21, 2003 6:31 am     Reply with quote
Hello woody,
This is what I was looking for.
I'm already correcting the arrays.
Thanks for the example
Regards,
Gerrit
:=In order to assign values to the whole structure in one go you will need to your array to an array of structures, rather than a two dimensional array. ( Unless it needs to be a two dimensional array for some other reason. )
:=#include <16f876.h>
:=typedef struct {
:= char First;
:= char Second;
:= char Third;
:= char Fourth;
:=} RGB_Modulo;
:=const RGB_Modulo Modulo_Index [3] = {
:= {0x00, 0x00, 0x00, 0x00},
:=void main (void)
:= Red_Modulo = Modulo_Index [1];
Original Post ID: 144514628
