mancio76
| Debugging 18F25K22 |
Posted: Tue Nov 13, 2012 10:02 am |
Hello to everybody,
I'm trying debugging PIC18F25K22 bus something seems doesn't work correctly.
I'm using PCWHD 4.137.
To attach to my target, I'm using the ICD3 from Microchip.
The .h file is the following:
#include <18F25K22.h>
#device ICD=TRUE
#device adc=16
#FUSES INTRC //Internal RC Osc
#FUSES PRIMARY_SW //Primary clock can be disabled in software
#FUSES WDT_NOSLEEP //Watch Dog Timer, disabled during SLEEP
#use delay(int=32000000,RESTART_WDT)
And the .c is:
| Code: | #include <Test_18F25K22.h>
setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
setup_timer_4(T4_DISABLED,0,1);
setup_timer_5(T5_DISABLED | T5_DIV_BY_1);
setup_timer_6(T6_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
output_low(PIN_C0);
delay_ms( 50 );
output_high(PIN_C0);
delay_ms( 50 );
The problem is that in debugging mode the system seem's doesn't work correctly.
Sometimes it connects to the target and let it running.
If I work with breakpoints or stops the system working, I need to reconnect the ICD to the target, as debugger, to let the system start.
In programming mode seems the system works fine.
Where is the trouble?
Is there anyone can help me?
Thanks |
n-squared
Posted: Tue Nov 13, 2012 11:17 pm |
Hi
Try adding the following to the header file:
BR
NN _________________ Every solution has a problem. |
gpsmikey
Posted: Tue Nov 13, 2012 11:58 pm |
Don't know if this affects your problem, but I just got email from CCS informing me that version 4.138 had been released - the interesting line in the update info was
"Updated: PIC18F25K22"
mikey _________________ mikey
mancio76
Posted: Wed Nov 14, 2012 2:05 am |
| n-squared wrote: | Hi
BR
NN |
Thank you for the suggestion.
I've correct the header with
But still not working properly!
I'm working around on internal clock to understand if the problem can reach from that.
Also, I'm waiting for news coming from version 4.138!
I hope it will resolve the problem!! |
mancio76
Posted: Wed Nov 14, 2012 3:55 am |
I've update the software to 4.138 and the system was working a little.
Then, I've anailze more in deep my electrical circuit and I've found some components attached to the PGD and PGC data of the ICD3.
I've then isolate the system, removing some resistors and now, finally, the system eneter in debug mode correctly.
That was basically an hardware problem. Maybe mixed a little with the 4.137 software version
Thanks to everyone |
