READ CONFIG BYTES on 18F252 ?
IK1WVQ
PostPosted: Tue May 20, 2003 7:01 am     Reply with quote
hi,
it is possible to read (write) the values of the CONFIG BYTES
from inside the program (directly "C" or by an assebler rutine)
in a 18F252 ???
thanks
Original Post ID: 144514588
acid
Re: READ CONFIG BYTES on 18F252 ?
PostPosted: Tue May 20, 2003 7:33 am     Reply with quote
:=hi,
:=it is possible to read (write) the values of the CONFIG BYTES
:=from inside the program (directly "C" or by an assebler rutine)
:=in a 18F252 ???
:=thanks
Ti riferisci ai config bit?
Original Post ID: 144514590
Woody
PostPosted: Tue May 20, 2003 8:07 am     Reply with quote
Yes. The table read and write feature of the PIC18 must be used. This is described in the data sheet under "special features of the cpu".
Something like the following code snippet or something similar might do.
#include <18f252.h>
#pragma case
typedef union tagAddress {
struct {
int8 byte0;
int8 byte1;
int8 byte2;
} ubyte;
int32 uint32;
} Address;
void config_write (int32 addr, int8 value )
#pragma ASM
MOVF ((Address) addr).ubyte.byte0,W
MOVWF 0xFF6
MOVF ((Address) addr).ubyte.byte1,W
MOVWF 0xFF7
MOVF ((Address) addr).ubyte.byte2,W
MOVWF 0xFF8
MOVF value,W
TBLWT*+
#pragma ENDASM
int8 config_read (int32 addr )
int8 value;
#pragma ASM
MOVWF 0xFF6
MOVWF 0xFF7
MOVWF 0xFF8
TBLRD*
MOVFF 0xFF5,value
#pragma ENDASM
return (value);
void main (void)
int8 v;
config_write (0x300008, 0x20 );
v = config_read (0x300008 );
Original Post ID: 144514592
