danielz85
| sampling audio output using PIC16f690 |
Posted: Sat Oct 20, 2012 7:12 am |
I'm trying to sample the audio jack (3.5mm) of my iPhone/PC using my PIC.
I'm using AN4 as input to my ADC module.
The iPhone's output signal is a pure sine wave around 1K freq.
The results are printed out using UART tool.
However, I'm witnessing strange phenomena in doing so:
1. pic is able to sample iPhone's output, however I'm getting too many zeros. I think that those zeros might be since the iPhone's audio output voltage is negative?
2. same thing happens with the tablet.
3. when connecting the pic to the PC, I get a bunch of zeros. non-stop.
and I'm unable to sample it at all...
#include <16F690.h>
#device adc=10
#fuses INTRC_IO, NOWDT, NOBROWNOUT, PUT,NOMCLR
#use delay(clock=8000000)
#use rs232(baud=9600,xmit=pin_A0,rcv=pin_A1)
void main() {
int i=0;
int16 arr[25];
int16 adc_value;
setup_adc_ports(sAN4);
set_adc_channel(4);
setup_adc(ADC_CLOCK_DIV_16);
delay_us(20);
while (TRUE)
delay_us(20);
adc_value=READ_ADC(); //READ FROM ADC PORT
DELAY_US(4);
//output_low(PIN_C0);
arr[i] = adc_value;
i++;
if (i==25) {
for (int k=0 ; k<25 ; k++)
printf("%ld ",arr[k]);
i=0;
Any suggestions why this fails?
Is it because the output voltage coming out of any music player has a negative part? (just like the negative part of a pure sine wave).
Thanks alot! |
Mike Walne
Posted: Sat Oct 20, 2012 1:07 pm |
Use an oscilloscope. It will answer all your questions.
If you have a problem with negative voltage signals you will have to provide an offset.
It's been covered here loads of times.
Mike |
danielz85
| you mean |
Posted: Sat Oct 20, 2012 1:22 pm |
Thanks.
You mean that I have to do that in hardware ?
Is there any other way to get negative sign to the pic, such as with the comparator, instead of using ADC ?
Our goal is to get low frequency (10-20khz) signal and print it.
Thanks. |
Posted: Sat Oct 20, 2012 2:22 pm |
| Quote: |
Your question is about level shifting of an analog input signal. The basic
name for this topic is signal conditioning.
Look at the voltage divider circuit in Figure 3 in the link below. This shows
one way to level shift an analog input signal for a PIC:
http://www.analog.com/library/analogDialogue/archives/33-01/chip/
You may need different resistor values (referring to the ratio). You
should use much smaller values, due to the requirements of the PIC's A/D input circuit. And finally, there are other ways to do this.
This thread has a link to an Opamp circuit:
http://www.ccsinfo.com/forum/viewtopic.php?t=29494 |
danielz85
| thanks |
Posted: Sat Oct 20, 2012 2:34 pm |
Thanks, I will do that.
But what about the frequency ?
Can I sample an input of a sinus wave in the frequency of 18khz ?
It seems that I don't have enough samples, and i don't know if this is because the line has a negative values(which gives me so many zero's), or that i don't sample fast enough, or that i can't even sample that frequency ? |
Mike Walne
Posted: Sat Oct 20, 2012 5:04 pm |
| Quote: | | Can I sample an input of a sinus wave in the frequency of 18kHz ? | Do you mean sampling at 18k samples / second ?
OR
Taking enough samples of an 18kHz sinus to be able to reconstruct something approaching the original?
Mike |
gpsmikey
Posted: Sat Oct 20, 2012 10:34 pm |
As others have indicated, the A/d can't handle negative voltages without some sort of level shifting - check out the data sheet for the processor and it will tell you what input voltage range is valid for the A/D input (and typically you want some protection against spikes and excursions outside the specified range - that needs to be done in the hardware). Another issue you are going to run into - if you are trying to send the samples out at 9600 baud, that is approximately 1 ms per character (1 k characters/second) - there is no way you could keep up with anything over 1khz (and that would only be one sample per cycle which is not overly useful). If you wanted to be able to have say, 10 samples per cycle, at 9600 baud, the best you could possibly do is about 100hz. (unless you use some sort of buffer and only capture for a short period then spit the data out again). You need to first look at the signal with an 'scope so you know what you are working with then design the front end to match that with the requirements of the A/D converter in the PIC.
mikey _________________ mikey
Mike Walne
Posted: Sun Oct 21, 2012 11:19 am |
Your duplicate thread on this subject has been locked.
Asking the same questions again helps nobody.
The other respondents and I are trying to help you.
We want you to answer OUR questions.
We can't give answers to your questions because you have not provided enough information.
We are asking for more details so that we can decide whether what you are trying to do is possible (or not), or if you should be persuing some other approach.
When we get the all the necessary data, you'll be freely given good advice.
Mike |
danielz85
| Thanks for the replies!! |
Posted: Mon Oct 22, 2012 1:54 am |
After having read your replies, I've decided not to work with ADC.
Thanks again, |
