pull up pb with PIC12F675
vincent74
PostPosted: Thu Apr 21, 2005 10:20 am     Reply with quote
I have a pb with pullups of PIC12F675, on port GPO and GP1. I do this code, but the pull ups are not enable, where is the problem?
#byte WPU = 0x95 ///< Registre des Weak UP Pullup
#byte OPTION_REG = 0x81 ///< Registre OPTION_REG
VOID main( VOID )
   // Setup I/O PORTS
   set_tris_a( 0b11011111 ); // 0 output, 1 input
   /*WPU = 0x03; // pull up for GP0 et GP1
   OPTION_REG &= 0x7F; // Enable Pull-ups*/
   port_a_pullups(0x03);
   for(;;); // GP0 and GP1 are low (nothing is plug on GP0 and GP1)
PostPosted: Thu Apr 21, 2005 12:58 pm     Reply with quote
What is your version of the compiler ?
vincent74
PostPosted: Fri Apr 22, 2005 12:16 am     Reply with quote
answer:
#byte CNCOM = 0x19 ///< Registre CNCOM du comparateur //<<<<<
VOID main( VOID )
  // Setup I/O PORTS
  CNCOM = 0x07; // config of comparator pin....//<<<<<<<<<<<<<
  // pull ups OK
Sorry, I should read the datasheet before start programming.
PostPosted: Fri Apr 22, 2005 1:13 am     Reply with quote
That's why I asked what was your version of the compiler.
In PCM vs. 3.222, the start-up code inserted by the compiler
correctly turns off the comparators. I suspected that your
version did not, but wanted to confirm it.
This is the start-up code produced by vs. 3.222:
0000                00219 ..... void main()
0000                00220 ........... {
0019 0184       00221 CLRF   04
001A 301F       00222 MOVLW  1F
001B 0583       00223 ANDWF  03,F
001C 131F       00224 BCF    1F.6
001D 1683       00225 BSF    03.5
001E 101F       00226 BCF    1F.0
001F 109F       00227 BCF    1F.1
0020 111F       00228 BCF    1F.2
0021 119F       00229 BCF    1F.3
0022 3007       00230 MOVLW  07      // W = 7
0023 1283       00231 BCF    03.5    // Bank 0
0024 0099       00232 MOVWF  19      // Set CMCON = 7
0025 1683       00233 BSF    03.5
0026 0805       00234 MOVF   05,W
0027 1283       00235 BCF    03.5
0028 0819       00236 MOVF   19,W
0029 118C       00237 BCF    0C.3
PostPosted: Mon Apr 25, 2005 1:01 pm     Reply with quote
I guess that's why I always try to configure things the way I want it even if I don't have to.
A test program I used for the 12F675.
#include "C:\Program Files\PICC\Programs\12F675\test.h"
#BYTE porta = 0x05
   setup_adc_ports(0);
   setup_adc(ADC_OFF);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   set_tris_a(0x0F);
      porta = 0x00;
      delay_ms(1);
      porta = 0x30;
      delay_cycles(2);
Bilgehan
Config Pull up problem
PostPosted: Thu Oct 18, 2012 7:36 am     Reply with quote
Dear all,
I have been working on PIC 12F675 and want to use internal pull ups. GP0, GP1 and GP2.
But I could not get success,
Is it ok only use port_a_pullups(0bxxxxxx); command to make a config?
How can I canfig, the internal pull ups.
It works with assembly code.
Or what?
MY CODES
   set_tris_a(0b00000111);
   port_a_pullups(0b00000111);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   output_a(0x00);
   output_high(ROLE);
   output_high(LED);
      if(SAGYAT == 1)
      delay_ms(10);
      ONDAKIKA=0;
      BIRDAKIKA=0;
      output_high(ROLE);
      output_high(LED);
      else if(SAGYAT == 0)
      delay_ms(10);
      ONDAKIKA=0;
      BIRDAKIKA=0;
      output_low(ROLE);
      output_low(LED);
What I want to do:
I have 3 pins and if one of them or both or all or combination of them active or passive, do smth, such open/close relay.
I want to use internel pull ups but could not.
Any idea!
Thanks.
PostPosted: Thu Oct 18, 2012 8:10 am     Reply with quote
#use fast_io(a)
By default the compiler is set to 'standard_io' mode.
In standard_io mode, the instruction:
output_a(0x00);
sets the _whole_ of portA as outputs.
Two choices. Either switch to fast_io mode, _or_ change the order of the instructions.
Just use:
output_a(0x00);
This way, you pre-load the output latch with '0', and only then set the TRIS, which then doesn't get changed on the low bits, provided you only use the bit I/O instructions (output_high and output_low).
