mohsin_hashmi
| password program not verifying |
Posted: Sun Oct 07, 2012 10:08 am |
Hello !
I have written a program that asks for password. But even if i am entering the correct password "mohsin" it is still saying password not correct. Please help.
#include <16F876A.h>
#device adc=8
#FUSES LP //Low power osc < 200 khz
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
#include <string.h>
char k;
char name[6];
puts("**********************************");
puts(" Console Test ");
putc('\n');
putc('\r');
printf("Enter Password:");
gets(name);
puts(name);
if (name=="mohsin")
puts("Password is Correct");
puts("Password is Incorrect");
Mike Walne
Posted: Sun Oct 07, 2012 10:42 am |
Of course it doesn't work.
The CCS manual shows how you could perform password function.
For starters your array [name] isn't big enough.
String arrays need an extra space for a terminating zero.
It's advisable to add errors to the #use RS232.
Mike |
gpsmikey
Posted: Sun Oct 07, 2012 10:56 am |
You also need to look up the string functions in the user manual for comparing strings. In addition to Mikes comment on the buffer length, part of the error checking should be to verify the entered string does not overflow the input buffer - one of the first hacks people try to break into systems is to overflow input buffers.
mikey _________________ mikey
mohsin_hashmi
Posted: Sun Oct 07, 2012 11:17 am |
I have tried the example in the CCS C manual but same problem.
char string[30];
char temp[30];
strcpy(temp,"mohsin");
printf("Password: ");
gets(string);
if(strcmp(string,temp))
printf("OK");
printf("Wrong");
gpsmikey
Posted: Sun Oct 07, 2012 12:00 pm |
A little basic debugging - have you tried printing out both the test string and the string you received to see if they are the same ? Printf(thingies) is your friend.
Posted: Sun Oct 07, 2012 1:29 pm |
| Another tip for debugging is not only to test for the answer you are looking for, but also try to see what happens when you give a wrong input. Sometimes this gives you a very helpful hint about what is wrong... |
Posted: Sun Oct 07, 2012 1:51 pm |
| Quote: | if(strcmp(string,temp))
printf("OK");
printf("Wrong");
Same old problem. Doesn't read the manual. Doesn't read about what
is the return value for strcmp() for a match.
http://www.ccsinfo.com/forum/viewtopic.php?t=47945&start=2
And using Proteus for sure:
| Quote: |
#device adc=8
#use delay(clock=20000000) |
