vinay
| Help with glcd_text57() function in GLCD.c |
Posted: Mon Oct 01, 2012 2:52 am |
I am using glcd_text57() function to display text on an 128X64 Ampire GLCD(ks1080 based), but some of the pixels are missing. I have attached the driver program(I have made changes to CS1 and CS2 as active low in the driver) and the main() function that I am using, also I have attached a screenshot of the output I am getting.
compiler version 4.114
Pls suggest any corrections to get proper output.
| Code: | /////////////////////////////////////////////////////////////////////////
//// GLCD.C ////
void glcd_writeByte(char chip, BYTE data)
if(chip == GLCD_CS1) // Choose which chip to write to
output_low(GLCD_CS1);
output_low(GLCD_CS2);
output_high(GLCD_CS1); // Reset the chip select lines
output_high(GLCD_CS2);
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
BYTE glcd_readByte(BYTE chip)
BYTE data; // Stores the data read from the LCD
if(chip == GLCD_CS1) // Choose which chip to read from
return data; // Return the read data
Most glcd.c driver code removed. Only changes left.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers
- Forum Moderator
[/img]
| Code: | char hello[]={"HELLO!"};
glcd_init(ON);
glcd_text57(0,0,hello,2,ON);
Markdem
Posted: Mon Oct 01, 2012 6:35 pm |
We need to see the rest of the code in main, but I bet this will have something to do with the oscillator set at a speed above 20Mhz or Proteus doing something stupid with timings.
Try to run the pic at 20Mhz or change the delays in glcd_writeByte to a higher number and see how you go.
Have Fun |
vinay
| rest of code !!! |
Posted: Wed Oct 03, 2012 12:07 am |
#include <16F877A.h>
#device adc=10
#use delay(clock=4000000) |
vinay
| Solved it !!!! |
Posted: Wed Oct 03, 2012 5:03 am |
Finally solved the prob
there is read problem in glcd_readbyte(), the enable pin is not pulsed properly. I am attaching the code through which I got proper output
| Code: | // Purpose: Reads a byte of data from the specified chip
//input_d(); // Set port d to input
set_tris_d(0xFF);
output_high(GLCD_RW); // Set for reading
output_low(GLCD_E);
delay_us(10);
output_high(GLCD_E); // Pulse the enable pin
delay_us(10);
output_low(GLCD_E);
delay_us(10);
data = input_d(); // Get the data from the display's output register
output_low(GLCD_E);
MARKDEM, thank you for your reply.
