PIC24 - Reproducable compiler crash v4.135
kam
PostPosted: Mon Aug 06, 2012 2:46 pm     Reply with quote
Hi all,
Okay, trying to debug why I'm getting "issues" using structures, and I came across this crash! Sad Sad Sad
Just the act of compiling caused the compiler v4.135 to crash/lockup/die.
#include <24HJ128GP306.h>
#include <stdio.h>
#include <string.h>
#IGNORE_WARNINGS 203
#zero_ram
#FUSES HS
#FUSES NOWDT
#FUSES PR
#use delay(clock=40Mhz, crystal=20Mhz)
// THIS LINE CAUSES A COMPILER CRASH!!!
char *pExternalCommand[] =
    "AAAA",
    "BBBB",
    "CCCC",
    NULL
    printf("Sleeping\r\n");
    while (1);
Thoughts?
~Kam
PostPosted: Mon Aug 06, 2012 2:59 pm     Reply with quote
It fails with the PCH compiler as well. I found the actual problem quickly
by commenting out the "weirdest" line. What's the line most likely to
cause a problem ? What's the strangest thing, at least in terms of CCS's
ability to handle things ? Comment that line out and you'll see what the
problem is.
