I2C master and 2 slaves, getting wrong ADC values !!!
Goto page 1, 2  Next
semmoor
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Jul 13, 2012 3:41 pm     Reply with quote
Hi guys, I'm just using the same code written by pcmprogrammer, but with two slaves and getting wrong values, when the microcontroller starts it gives the correct value but then immediately changes to 255 for ever !!!.
However, when I request data from slave_1 only it works, and the same when I only request data form slave_2 it gives the correct values.
So why can't I use both of them at the same time to get correct values?
This the master code:
#include <16F877.H>
#use delay(clock=4M)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#include "lcd.c"
#define SLAVE1_WRT_ADDR   0x12
#define SLAVE1_READ_ADDR  0x13
#define SLAVE2_WRT_ADDR   0x14
#define SLAVE2_READ_ADDR  0x15
int8 data; //stores data sent by slave_1
int8 data_2; //stores data sent by slave_2
   //requesting data form slave_1
   i2c_start();
   i2c_write(SLAVE1_READ_ADDR);
   data = i2c_read(0);
   i2c_stop();
   printf("Slave_1 ADC: %u \n\r", data); //displaying data sent by slave_1 on RS232
   //requesting data form slave_2
   i2c_start();
   i2c_write(SLAVE2_READ_ADDR);
   data_2 = i2c_read(0);
   i2c_stop();
   lcd_putc("\f"); //clear lcd
   printf(lcd_putc,"Slave_2 ADC: %u \n\r", data_2); //displaying data sent by slave_2 on LCD
and this is slave_1 code:
#include <16F877.h>
#device adc=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x12)
int8 adc_result;
#INT_SSP
void ssp_interrupt()
int8 incoming, state;
state = i2c_isr_state();
if(state < 0x80)     // Master is sending data
   incoming = i2c_read();
if(state == 0x80)   // Master is requesting data from slave
   i2c_write(adc_result);
void main ()
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_result = read_adc();
enable_interrupts(INT_SSP);
Lastly this is the slave_2 code:
#include <16F877.h>
#device adc=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x14)
int8 adc_result;
#INT_SSP
void main ()
set_adc_channel(0);
delay_us(20);
PostPosted: Fri Jul 13, 2012 3:46 pm     Reply with quote
Do you have the correct I2C bus resistors installed for speed-distance-VCC ?
semmoor
PostPosted: Fri Jul 13, 2012 4:13 pm     Reply with quote
yup, I'm using 2.2k for scl and sda.
I tried with different resistor values like 1.7k and 4.7k, but still doesn't work.
PostPosted: Fri Jul 13, 2012 7:54 pm     Reply with quote
hmmmm...
I'd run PCM pgmr's I2C test program to see if it sees both slaves...
PostPosted: Sat Jul 14, 2012 12:44 am     Reply with quote
One 'classic' possible problem.
State 0x80 needs you to first _read_ the byte from the slave, then write.
So he slave code need:
#INT_SSP
void ssp_interrupt(void) {
   if(state <= 0x80)     // Master is sending data - note the =
This is a very common 'miss' on I2C, with state 0x80, being 'unique' in requiring this 'double' transaction.
semmoor
PostPosted: Sat Jul 14, 2012 7:13 am     Reply with quote
#INT_SSP
This is avery common 'miss' on I2C, with state 0x80, beng 'unique' in requiring this 'double' transaction.
I did exactly what you said but still didn't work, it didn't even show any result i saw just blank on lcd and RS232, so nothing is displayed.
semmoor
PostPosted: Sat Jul 14, 2012 12:28 pm     Reply with quote
No solutions ??
it's the second day and still didn't solve this issue!!
PostPosted: Sat Jul 14, 2012 1:10 pm     Reply with quote
What's your report on using PCM pgmr's I2C testing program ??
semmoor
PostPosted: Sat Jul 14, 2012 1:28 pm     Reply with quote
can you please give me PCM pgmr's I2C testing program ??
please temtronic, and thank you for helping me.
PostPosted: Sun Jul 15, 2012 2:38 am     Reply with quote
Hasn't anyone heard of using search?.....
If you do a search for 'I2C diagnostic', and 'search for all terms', the very first thread links to where PCM programmer originally posted this.
<http://www.ccsinfo.com/forum/viewtopic.php?t=47707&postdays=0&postorder=asc&highlight=i2c+diagnostic&start=15>
It has been referenced by dozens (possibly hundreds) of other I2C threads, and looking through these would find links to it.
It really is a most 'basic' test, scanning the bus for devices, and if it finds them, telling you the addresses they are on. Brilliant basic test that the bus is working, pull-ups are adequate, and connections are OK.
semmoor
PostPosted: Sun Jul 15, 2012 5:52 am     Reply with quote
Ttelmah thank you for the link:
i tried I2C diagnostic it says nothing found !!
how come??
PostPosted: Sun Jul 15, 2012 7:21 am     Reply with quote
Well we know his program works so possible causes include
1) incorrect pullup resistors on the I2C busses
2) no ground between devices
3) no power to devices
4) incorrect setup/configuration of devices
5) bad solder joint,loose wiring,etc.
6) 3 blue moons in the sky
It is very difficult to pinpoint why it fails to see your devices as your setup is not in front of us!
Since you're using PICs as I2C devices,I'd try it with a real I2C device,say a DS1307 RTC if you have one.Using a real device will prove the I2C test program works on your breadboard or test setup.
hth
jay
semmoor
PostPosted: Sun Jul 15, 2012 10:20 am     Reply with quote
hth
jay
temtronic, thank you my friend i appreciate that i will try to check what you told me, and thanks to all.
semmoor
PostPosted: Sun Jul 15, 2012 10:29 am     Reply with quote
guys i modified the above code to send a string from slave(pic_1) to master(pic_2), but didn't work it only sends the first char!
so, what can you advice me to make the slave sends a string like "ABCD" whenever the master requests a data?
this is the slave code:
#include <16F877.h>
#device adc=8
#INT_SSP
    i2c_write('A');  //send first char to slave
    i2c_write('B');  //send second char to slave
    i2c_write('C');  //send third char to slave
void main ()
master code:
#include <16F877.H>
#define SLAVE1_WRT_ADDR   0x14
#define SLAVE1_READ_ADDR  0x15
char data[3]; //stores data sent by slave
   i2c_start();
   data[0] = i2c_read(0); delay_ms(100); //stores first char sent by slave
   data[1] = i2c_read(0); delay_ms(100); //stores second char
   data[2] = i2c_read(0); delay_ms(100); //stores third char sent by slave
   i2c_stop();
   printf(" [ %s ] \r\n", data); //now display completed string on RS232
when i make a simple run for the code above i only see the first char printed on RS232.
jeremiah
PostPosted: Sun Jul 15, 2012 1:04 pm     Reply with quote
try only NACK'ing the last byte you read in the master code. You are NACK'ing all 3. Usually when you NACK a read byte, that is the master telling the slave it is finished.
Goto page 1, 2  Next
Page 1 of 2
