dsPIC30 printf 32-bit ints
AlastairM
PostPosted: Wed Jul 04, 2012 4:16 pm     Reply with quote
I'm using a dsPIC30F4011, MPLAB 8.85, CCS 4.134
I am having some strange printf results. Could someone explain if it's me or a bug?
      int16    buf[3];
      int32   PackedData;
      #use rs232(UART2,baud=19200,parity=N,bits=8,stream=DEBUG,errors)
      buf[0]=0x169;   //ADCBUF0;
      buf[1]=0x2AA;   //ADCBUF1;
      buf[2]=0x355;   //ADCBUF2;
      PackedData=(((int32)buf[2])<<22)|(((int32)buf[1])<<12)|(((int32)buf[0])<<2);
      fprintf(DEBUG,"%4LX,%4LX,%4LX = %8LX\r\n\r\n",   buf[2],buf[1],buf[0],PackedData);
output from MPLAB SIM
   Update      Address      Symbol Name      Value       Hex                    Binary
                 80E     PackedData        0xD56AA5A4 0xD56AA5A4  11010101 01101010 10100101 10100100
                 808     buf
                 808     [0]                   0x0169     0x0169                    00000001 01101001
                 80A     [1]                   0x02AA     0x02AA                    00000010 10101010
                 80C     [2]                   0x0355     0x0355                    00000011 01010101
I'm Happy with that!
but output from serial
0355,02AA,0169 =  FFFFFFFFD56AA5A4
what are all those extra 'F's?
If I change it to
   buf[0]=0x69;
      buf[1]=0xAA;
      buf[2]=0x55;
then I get on the serial:
0055,00AA,0069 =  154AA1A4
(as an aside the print field width for hex numbers seems to be ignored)
Al
PostPosted: Thu Jul 05, 2012 2:53 pm     Reply with quote
I don't have that compiler but just to make an educated guess, I think
that because PCD has a "long long int" data type (64 bits) that it may be
sign-extending the value. Try casting the variable in the fprintf statement
to an int32. See if that fixes the problem.
In other words, CCS doesn't have separate printf format strings for all
the various sizes beyond a byte. In PCM and PCH, it has "%LX" which
is used to display both 16-bit and 32-bit values. There is no "%LLX".
So in PCD, they add an even larger type, 64-bits, to the same format
string. That's why I think casting the variable (inside the fprintf
statement) may fix the problem. At least it's something to try.
AlastairM
PostPosted: Thu Jul 05, 2012 5:03 pm     Reply with quote
That didn't work - I've admitted defeat, I assume there's a bug that thinks a 32-bit unsigned int with the MSB set is a 64-bit signed int.
Here's my gruesome workaround!
   fprintf(DEBUG,"%4LX,%4LX,%4LX ...  %4LX%4LX\r\n\r\n",   buf[2],buf[1],buf[0],(int16)(PackedData>>16), (int16)PackedData);
which gives the correct output on the serial:
0355,02AA,0169 ...  D56AA5A4
Thanks for your help
Al
AlastairM
PostPosted: Tue Jul 10, 2012 2:30 pm     Reply with quote
I've had an email from CCS Support:
The problem you reported has been fixed and will be in the next compiler release.
That was quick! Don't forget to send your bug reports to them...
