Using CCS with CodeWright
thomas
PostPosted: Thu May 15, 2003 11:27 pm     Reply with quote
Hi everyone,
I want to edit and compile PICC under CodeWright. I tried to setup the command line but it doesn't work. It looks like this:
${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
I also want to be able to click on the error message and automatically jump to the error line. Is it possible?
Regards
Thomas
Original Post ID: 144514501
Re: Using CCS with CodeWright
PostPosted: Fri May 16, 2003 11:42 am     Reply with quote
:=Hi everyone,
:=I want to edit and compile PICC under CodeWright. I tried to setup the command line but it doesn't work. It looks like this:
:=${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
Try this one, from the archives:
<a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12546.html</a>
Original Post ID: 144514511
thomas
PostPosted: Sat May 17, 2003 11:30 am     Reply with quote
Thank you for your help! I tried this one already but it still doesn't work.
:=:=Hi everyone,
:=:=I want to edit and compile PICC under CodeWright. I tried to setup the command line but it doesn't work. It looks like this:
:=:=${FTEE} "C:\Program Files\PICC\CCSC.exe" +FM E:\Project\Test\main.c
:=Try this one, from the archives:
:= <a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/12546.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12546.html</a></a>
Original Post ID: 144514524
davidpk
PostPosted: Sat May 17, 2003 5:43 pm     Reply with quote
I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
"c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
I used the following options:
No command shell
Save all files
:=Thank you for your help! I tried this one already but it still doesn't work.
Original Post ID: 144514528
thomas
PostPosted: Sun May 18, 2003 9:01 pm     Reply with quote
Thank you for your help! Using this command line, do you get it work properly? I tried this but still, it doesn't work. Would you please point me to a document or something about what the +DC, +LN, etc option mean?
Thanks!
Thomas
:=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
:="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
:=I used the following options:
:=No command shell
:=Save all files
:=:=Thank you for your help! I tried this one already but it still doesn't work.
Original Post ID: 144514535
davidpk
PostPosted: Wed May 21, 2003 11:14 am     Reply with quote
The switches you're asking about are in the Compiler Manual, page 2. What version of CodeWright are you using? I was able to do this with versions 6.5 and 7.5. Also, did you set the check boxes the same way I did?
Oh, (just in case) you did use your source code path, not mine, right?
:=Thank you for your help! Using this command line, do you get it work properly? I tried this but still, it doesn't work. Would you please point me to a document or something about what the +DC, +LN, etc option mean?
:=Thanks!
:=Thomas
:=:=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
:=:="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
:=:=I used the following options:
:=:=No command shell
:=:=Save all files
:=:=:=Thank you for your help! I tried this one already but it still doesn't work.
Original Post ID: 144514634
thomas
PostPosted: Wed May 21, 2003 1:46 pm     Reply with quote
The code was compile OK. My problem is when I double-click on the error message, CodeWright is unable to open the file with error and jump to the appropriate place. I think it has to do with the way CodeWright interprets the error message.
Regards,
Thomas
:=The switches you're asking about are in the Compiler Manual, page 2. What version of CodeWright are you using? I was able to do this with versions 6.5 and 7.5. Also, did you set the check boxes the same way I did?
:=Oh, (just in case) you did use your source code path, not mine, right?
:=:=Thank you for your help! Using this command line, do you get it work properly? I tried this but still, it doesn't work. Would you please point me to a document or something about what the +DC, +LN, etc option mean?
:=:=Thanks!
:=:=Thomas
:=:=:=I use CodeWright and decided to find a way to make this work when I saw your post. I ended up with this as a command line:
:=:=:="c:\program files\picc\CCSC.exe" +DC +LN +T +A +M +Y9 +P30 "c:\data\FTS Firmware\Tango\302-4006500.c"
:=:=:=I used the following options:
:=:=:=No command shell
:=:=:=Save all files
:=:=:=:=Thank you for your help! I tried this one already but it still doesn't work.
Original Post ID: 144514644
