thibow
| nRF24L01 using PIC18F2550 and CCS compiler with Brennen lib |
Posted: Wed May 02, 2012 1:26 pm |
I'm trying to get my nRF24L01+ board working with 2 Pic 18LF2550. Thank's to Brennen's library I managed to understand how it works but I am facing some building's errors as I modified some minor things to compile with CCS Compiler (Brennen uses C18).
I use to get spi working between my two PIC using wires (still with CCS Compiler), I now try to put the nRF24L01+ in between..
Here is what I changed to Brennen's library according to my compiler :
I did not include "spi.c" or "uart.h" as I don't think I need it, and I modified the spic1.c as followed
spi1.c:
| Code: | //#include <spi.h>
#include <18f2550.h>
#byte SSPBUF=getenv("SFR:SSPBUF")
unsigned char spi1_send_read_byte(unsigned char byte)
SSPBUF = byte;
while(!spi_data_is_in());
return SSPBUF;
Then I managed to change every "#include #include <p18f452.h>" by "#include <18f2550.h>" and finally I tried to define IO port as follow:
| Code: | #include <18f2550.h>
//defines for uC pins CE pin is connected to
//This is used so that the routines can send TX payload data and
// properly initialize the nrf24l01 in TX and RX states.
//Change these definitions (and then recompile) to suit your particular application.
#define nrf24l01_CE_IOREGISTER PORTC //pin_C4 10 000
#define nrf24l01_CE_PINMASK pin_C4 //0x10
//defines for uC pins CSN pin is connected to
//This is used so that the routines can send properly operate the SPI interface
// on the nrf24l01.
#define nrf24l01_CSN_IOREGISTER PORTA // pin_A5 100 000
#define nrf24l01_CSN_PINMASK pin_A5//0x20
//defines for uC pins IRQ pin is connected to
//This is used so that the routines can poll for IRQ or create an ISR.
#define nrf24l01_IRQ_IOREGISTER PORTC // pin_C2 100
#define nrf24l01_IRQ_PINMASK pin_C2 //0x04 |
BUT, "PORTC", "PORTB", an "PORTA" are not defined in my pic18f2550.h and I don't know what to set here..
as I chosed to use the following pin for CE, CSN and IRQ
| Code: | #define SPI_CSN pin_A5
#define SPI_CE pin_C4
#define SPI_IRQ pin_C2 |
Do you think there is anything I should change for my project to compile.. here is the code I try to compile:
| Code: | #include <18F2550.H>
#include <STDLIB.H>
#include "nRF24L01.h"
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,PLL2,CPUDIV4,NOVREGEN,NOMCLR
#use delay(clock=16000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C5,bits=8,STOP=1)
#define LED1 pin_A1
#define LED0 pin_A0
char *mychar=NULL;
int i=0;
int length;
unsigned char data;
void init(void){
//configure the device to be a master, data transmitted on H-to-L clock transition
setup_spi(spi_master | spi_l_to_h | spi_clk_div_16 | spi_xmit_l_to_h);
output_HIGH(LED1); //Led lit
output_HIGH(LED0); //Led lit
output_HIGH(SPI_CSN); // CSN initialized
nrf24l01_initialize_debug(false, 1, false); //initialize the 24L01 to the debug configuration as TX, 1 data byte, and auto-ack disabled
void main (void){
init();
while(1){
getc();
//delay_us(100);
nrf24l01_write_tx_payload(&data, 1, true); //transmit received char over RF
//wait until the packet has been sent or the maximum number of retries has been reached
while(!(nrf24l01_irq_pin_active() && nrf24l01_irq_tx_ds_active()));
nrf24l01_irq_clear_all(); //clear all interrupts in the 24L01
nrf24l01_set_as_rx(true); //change the device to an RX to get the character back from the other 24L01
//wait a while to see if we get the data back (change the loop maximum and the lower if
// argument (should be loop maximum - 1) to lengthen or shorten this time frame
for(count = 0; count < 20000; count++)
//check to see if the data has been received. if so, get the data and exit the loop.
// if the loop is at its last count, assume the packet has been lost and set the data
// to go to the UART to "?". If neither of these is true, keep looping.
if((nrf24l01_irq_pin_active() && nrf24l01_irq_rx_dr_active()))
nrf24l01_read_rx_payload(&data, 1); //get the payload into data
//if loop is on its last iteration, assume packet has been lost.
if(count == 19999)
data = '?';
nrf24l01_irq_clear_all(); //clear interrupts again
printf("%c", data); //print the received data (or ? if none) to the screen
Delay_US(130); //wait for receiver to come from standby to RX
nrf24l01_set_as_tx(); //resume normal operation as a TX
I am getting weird errors such as
"Expecting an identifier" on the line "unsigned char spi1_send_read_byte(unsigned char byte); " from my spi1.H
here it is
| Code: | /*****************************************************************************
* File: spi1.h
* Copyright S. Brennen Ball, 2006-2007
* The author provides no guarantees, warantees, or promises, implied or
* otherwise. By using this software you agree to indemnify the author
* of any damages incurred by using it.
#ifndef _SPI1_H_
#define _SPI1_H_
//#include <spi.h>
#endif //_SPI_H_ |
If you have any idea.. |
Posted: Wed May 02, 2012 1:50 pm |
Why not just get rid of that file ? All it has in it is a function prototype.
If necessary, move the prototype statement into your main program. |
thibow
Posted: Wed May 02, 2012 5:53 pm |
well, I managed to understand that what was wrong was the fact that this library uses variable names that are reserved (such as byte)... I'll have a closer look at Eduardo's library much more recent and made for CCS.
Here it is : http://www.ccsinfo.com/forum/viewtopic.php?t=47351 |
mrdongus
| @thibow |
Posted: Mon Jun 18, 2012 6:32 am |
Hi thibow,
I also work nRF24L01 with PIC18F2550, the same with you. I am beginner with both of them.
Could you share code and your email with me !
Thank you !  |
