Gabriel
| ADC - The hard way |
Posted: Fri Jun 08, 2012 7:12 am |
After my initial post related to proper configuration of the internal OSC with my old compiler:
http://www.ccsinfo.com/forum/viewtopic.php?t=48366
I'm now faced with additional problems due to the compiler not fully supporting my PIC... thankfully as explained on the referenced thread i learned how to go around that.
My problem is that the ADC setup functions do not work at all.
Not even the channel select functions.
now, the datasheet says:
| Quote: | 1) Configure analog/digital I/O (ANSEL)
2) Configure voltage reference (ADCON1)
3) Select A/D input channel (ADCON0)
4) Select A/D conversion clock (ADCON0)
5) Turn on A/D module (ADCON0)
6) Wait for A/D conversion to complete
7) Read A/D Result register pair |
I've done(in the appropriate locations):
#byte ANSEL = 0x9B
#byte ADCON0 = 0x1F
#byte ADCON1 = 0x9F
Selected my ADC ports:
ANSEL=0x03; //Ports AN0 and AN1
configured Vrefs and ADC clock
ADCON1=0x08; // Right justified, no div2, Vdd/Vss
I'm good till here...
My question is for ADCON0, I can do all these 3 in one go:
| Quote: |
Must I do them in steps? Does it matter?
This:
ADCON0=0x40; //Fosc/16 - Chan 0 - No Go - ADC OFF
ADCON0=0x41; //Fosc/16 - Chan 0 - No Go - ADC ON
ADCON0=0x45; //Fosc/16 - Chan 0 - GO - ADC ON
Delay_us(20); //conversion time delay
ADC_value=Read_ADC();
Vs. This:
| Code: | ADCON0=0x45; //Fosc/16 - Chan 0 - GO - ADC ON
Is there any difference in setting all the bits in different steps than just writing all of them together?
Should there be any delay between the bit writing steps?
Is _location_ of my ADC conversion delay correct?
Then, when switching channels after executing the above code,
can I just do:
| Code: | ADCON0=0x4D; //Fosc/16 - Chan 1 - GO - ADC ON
Or must I go through the whole setup again turning the ADC of, switching channels etc... ADC on again... etc...
Its not that my code is not working... it is.. i can read my adc, i wrote my own channel switch function etc. I just want to make sure I'm doing things correctly and not just forcing my way into a working, yet wrong setup.
Thanks! _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Mike Walne
Posted: Fri Jun 08, 2012 8:19 am |
The microchip manual DS33023A.pdf does an in-depth discussion of the ADC system.
It includes:-
(1) Advising not to set GO/DONE in the same instruction as turning on the ADC module. | Quote: | | Note: The GO/DONE bit should NOT be set in the same instruction that turns on the A/D, due to the required acquisition time requirement. |
(2) Suggesting that you can select your next channel to convert soon after setting GO/DONE.
| Quote: | Question 2: After starting an A/D conversion may I change the input channel (for my next conversion)?
Answer 2: After the holding capacitor is disconnected from the input channel, typically 100 ns after the GO bit is set, the input channel may be changed.
Mike |
Gabriel
Posted: Fri Jun 08, 2012 12:24 pm |
Ah! The plot thickens!
thanks! ill make sure to read that manual!
