LMB204BDC with Flex 4 x 20 driver not displaying text
Goto page Previous  1, 2, 3
seifpic
PostPosted: Sat Jun 09, 2012 8:41 pm     Reply with quote
PCM programmer wrote:
That switch circuit can't supply two logic states. With that circuit, the PIC
pin is either a floating input or it's a logic "1". You need to fix that.
Change them all to the schematic that I posted. You will also need to
change the logic of your code to look for a logic "0" as the active state of
the switches.
If your switches are connected to pins on PortB, then you can enable
the built-in PortB pullups and save yourself from having to add the
resistors. All you have to do in that case is change the +5v connection
to be Ground instead.
Is there a way to make it work using my current setup? Because there is no way that I can change it now (This thing is due today and with the jumble of wires I have I cant desolder joints), I always thought that switches should have an output of either one or zero, one being 5v and zero being 0v
PostPosted: Sat Jun 09, 2012 8:53 pm     Reply with quote
You need to do something similar to what I describe in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18121
You have the switch wired the opposite way from that thread. You have
it wired to +5v instead of to Ground. But I think the basic idea can still
work. The logic of the code would have to be changed and tested.
I can't do that right now. I can do it tomorrow afternoon. Or maybe
you can figure it out. But don't burn up any more PICs.
Re this question:
That is correct, but your switch circuit doesn't do that. It puts out "nothing" or +5v. It does not put out "0v" or "+5v".
seifpic
PostPosted: Sun Jun 10, 2012 11:31 am     Reply with quote
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
I got an extended time from my teacher and I think I have time to use this setup, however, when I do so will input(BTN_A) == 0 be equal to the button being pushed? And also does the resistor need to be 4.7K? If not, what can the value be?
PostPosted: Sun Jun 10, 2012 11:42 am     Reply with quote
You can use 10K or any reasonable value.
Yes, when the button is pressed it will be read as a Logic 0 by the PIC.
seifpic
PostPosted: Sun Jun 10, 2012 11:52 am     Reply with quote
Ok I'm going to try and tell you my results.
seifpic
PostPosted: Sun Jun 10, 2012 12:01 pm     Reply with quote
Can I use 1k ohm resistors?
PostPosted: Sun Jun 10, 2012 12:27 pm     Reply with quote
Yes, that will work.
seifpic
PostPosted: Sun Jun 10, 2012 1:25 pm     Reply with quote
I used different resistor values for each button (as I cannot find equal values), this is how my buttons are wired:
             +5v
         >R1 >R2 > R3
         <   <   <    ___  Switch A
To       |   |   |   _|_|_
PIC -------------x---o   o---------x
         |   |        ___  Switch B|
To       |   |       _|_|_         |
PIC ---------x-------o   o---------x
         |            ___  Switch C|
To       |           _|_|_         |
PIC -----x-----------o   o---------x
                              GND ___
R1 = 1K ohm
R2 = 2K ohm
R3 = 9.5K ohm
I think this results in the electrons 'preferring' to go through the R1 resulting in the push to be read as switch C's result. The only resistors I have many of are 330 ohm resistors (I use them to power LEDs from 5v) are these significant enough? Can I use them in this circuit?
Thanks in advance.
PostPosted: Sun Jun 10, 2012 1:39 pm     Reply with quote
Come on, you are spending way too much time on this. The resistor
size doesn't matter that much. Having 3 different sizes doesn't matter.
I hope you have the output of each circuit connected to a different PIC pin.
That's what you should have.
You need to move on from this, and do the rest of your project.
seifpic
PostPosted: Sun Jun 10, 2012 1:42 pm     Reply with quote
I finished the rest, all the code is done also, but the only last problem is the push buttons, none of them do anything except button C, which has the 1k Resistor. Here's my code for this project (I know it's not the most efficient and I didn't use best practices but here it is anyway)
#include <16f877a.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
#use delay (crystal=4000000)
#include <Flex_LCD420.c>
#include <7segDisp.c>
#define btn_A PIN_C4
#define btn_B PIN_C5
#define btn_C PIN_C6
void testScreen(){
   // Test the clear screen and newline commands.
   // Also test that we can write to all 4 lines.
   printf(lcd_putc, "\fThis is the 1st line");
   printf(lcd_putc, "\nNext is the 2nd line");
   printf(lcd_putc, "\nThis is the 3rd line");
   printf(lcd_putc, "\nFinally the 4th line");
   delay_ms(3000);
   // Test some additional characters.
   printf(lcd_putc, "\fABCDEFGHIJKLMNOPQRST");
   printf(lcd_putc, "\nabcdefghijklmnopqrst");
   printf(lcd_putc, "\n12345678901234567890");
   printf(lcd_putc, "\n!@#$^&*(){}[]:;<>?/=");
   delay_ms(3000);
      // Clear the LCD.
   printf(lcd_putc, "\f");
   // Test that lcd_gotoxy() works.  Go to each of
   // the four corners and put a number in each one,
   // in a clockwise direction, starting with the upper
   // left corner.
   lcd_gotoxy(4, 2);
   printf(lcd_putc, "Put a number in");
   lcd_gotoxy(4, 3);
   printf(lcd_putc, "each corner.");
   lcd_gotoxy(1, 1);
   printf(lcd_putc, "1");
   lcd_gotoxy(20, 1);
   printf(lcd_putc, "2");
   lcd_gotoxy(20, 4);
   printf(lcd_putc, "3");
   lcd_gotoxy(1, 4);
   printf(lcd_putc, "4");
   delay_ms(3000);
//end testscreen
void beep() {
   output_high(PIN_D0);
   output_low(PIN_D0);
void StartUpScreen() {
   beep();
   delay_ms(500); //clear the lcd
   printf(lcd_putc, "\n   Welcome to The  ");
   printf(lcd_putc, "\n    Quizzor2000   ");
   delay_ms(3000);
   printf(lcd_putc, "\fRead an essay about\nthe revolution cycle\nand complete a quiz.");
   while(true){
      if(input(btn_A) == 0 || input(btn_B) == 0 || input(btn_C) == 0) {
         beep();
      lcd_gotoxy(1, 2);
      printf(lcd_putc, "\fProceeding to essay.");
//end startupscreen
void EssayScreen() {
     char i;
   printf(lcd_putc, "\f     Read the\nInformational Essay\nThen Press Any Btn");
   while(true){
         beep();
      lcd_gotoxy(1, 2);
      printf(lcd_putc, "Proceeding to quiz..");
      for (i=5;i==0;--i) {
         updateDisplay(i);
         beep();
   beep();
   beep();
//end essayscreen
void ResultScreen(int scr) {
   beep();
   if(scr >= 95){
      printf(lcd_putc, "\f\nYou've aced the quiz");
   } else if(scr < 95 && scr >= 75){
      printf(lcd_putc, "\f\nNot Bad Better\nLuck Next Time!");
   }else if(scr < 75){
      printf(lcd_putc, "\f\nYou can do better\nthan that!");
void good() {
   printf(lcd_putc, "\f\n      Correct!");
   delay_ms(1500);
void bad() {
   printf(lcd_putc, "\f\n Sorry, incorrect..");
   delay_ms(1500);
void QuizScreen() {
   int score = 0;
   updateDisplay(score);
   printf(lcd_putc, "\f1. Thomas Jefferson\nMentioned ....\n Years in Between \n Each Revolution?");
   while(true){
         beep();
   printf(lcd_putc, "\nA.15");
   printf(lcd_putc, "\nB.20");
   printf(lcd_putc, "\nC.5");
      while(true){
         if(input(btn_B) == 0){
            beep();
            good();
            score += 10;
         } else if(input(btn_A) == 0 || input(btn_C) == 0){
            beep();
            bad();
     printf(lcd_putc, "\f\n2. A Revolution is\nusually against ....");
   while(true){
         beep();
   printf(lcd_putc, "\f2.");
   printf(lcd_putc, "\nA.President");
   printf(lcd_putc, "\nB.Government");
   printf(lcd_putc, "\nC.All Of The Above");
      while(true){
         if(input(btn_C) == 0){
            beep();
            good();
            score += 10;
         } else if(input(btn_B) == 0 || input(btn_A) == 0){
            beep();
            bad();
     printf(lcd_putc, "\f\n3.What causes the\ncycle of revolution");
   while(true){
         beep();
   printf(lcd_putc, "\f3.");
   printf(lcd_putc, "\nA.Unjust Government");
   printf(lcd_putc, "\nB.Other Revolutions");
   printf(lcd_putc, "\nC.Presidents");
      while(true){
         if(input(btn_A) == 0){
            beep();
            good();
            score += 10;
         } else if(input(btn_B) == 0 || input(btn_C) == 0){
            beep();
            bad();
          printf(lcd_putc, "\f\n4.In Latin\nRevolution means");
   while(true){
         beep();
      printf(lcd_putc, "\f4.");
   printf(lcd_putc, "\nA.'redo'");
   printf(lcd_putc, "\nB.'turn around'");
   printf(lcd_putc, "\nC.'enormous power'");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
     printf(lcd_putc, "\f5.According to\nthe information,\nwhat might happen\nin Egypt?");
   while(true){
         beep();
      printf(lcd_putc, "\f5.");
   printf(lcd_putc, "\nA.We Live Happily");
   printf(lcd_putc, "\nB.Cycle of Rebels");
   printf(lcd_putc, "\nC.Endless Dictators");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
     printf(lcd_putc, "\f6.It is of human ...\nTo go by the rebel\n      Cycle.");
   while(true){
         beep();
      printf(lcd_putc, "\f6.");
   printf(lcd_putc, "\nA.origin 1");
   printf(lcd_putc, "\nB.rights 2");
   printf(lcd_putc, "\nC.nature 3");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
          printf(lcd_putc, "\f7.During Most\nRevolutions, What\nUsually Happens\n  With Power?");
   while(true){
         beep();
      printf(lcd_putc, "\f7.");
   printf(lcd_putc, "\nA.Sold");
   printf(lcd_putc, "\nB.Removed");
   printf(lcd_putc, "\nC.Changed");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
   printf(lcd_putc, "\f8.The Revolution\nCycle .... In The\n  Hunger Games");
   while(true){
         beep();
      printf(lcd_putc, "\f8.");
   printf(lcd_putc, "\nA.Changed");
   printf(lcd_putc, "\nB.Partially Occured");
   printf(lcd_putc, "\nC.Didn't Occur");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
        printf(lcd_putc, "\f9.How Can People\nStop The Rebellion\n     Cycle?");
   while(true){
         beep();
      printf(lcd_putc, "\f9.");
   printf(lcd_putc, "\nA.Changing thoughts");
   printf(lcd_putc, "\nB.Changing habits");
   printf(lcd_putc, "\nC.All of the Above");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
             printf(lcd_putc, "\f10.What is the\nusual reason for\na sequencial rebel?");
   while(true){
         beep();
      printf(lcd_putc, "\f10.");
   printf(lcd_putc, "\nA.For Fun");
   printf(lcd_putc, "\nB.Clean up the past");
   printf(lcd_putc, "\nC.None of the Above");
      while(true){
            beep();
            good();
            score += 10;
            beep();
            bad();
      ResultScreen(score);
//end quizscreen
   output_low(LCD_RW);
   lcd_init(); //start the lcd
   delay_ms(1500);
   if(input(btn_A) == 0 && input(btn_B) == 0 && input(btn_C) == 0) {
     beep();
     beep();
     testScreen();
   StartUpScreen();
   EssayScreen();
   QuizScreen();
   //While (true) {
int i;
   output_low(LCD_RW);
   printf(lcd_putc, "\fHello World");
   printf(lcd_putc, "\f\n     Welcome To");
   printf(lcd_putc, "\n    Quizzor 2000");
   updateDisplay(5);
   updateDisplay(4);
   updateDisplay(3);
   updateDisplay(2);
   updateDisplay(1);
   printf(lcd_putc, "\f\n       Boom!");
   //delay_ms(5000);
   //for (i=10;i==0;i--) {
    //     updateDisplay(i);
    //     printf(lcd_putc, "\f");
    //     printf(lcd_putc, i);
    //     delay_ms(1000);
seifpic
PostPosted: Sun Jun 10, 2012 6:02 pm     Reply with quote
I de-soldered the three buttons and connected them to pins B0, B1, and B2 (That way I can connect them to +5v without resistors) however they always read 1 in the program, which is a test one:
#define btn_A PIN_B0
#define btn_B PIN_B1
#define btn_C PIN_B2
int i;
   output_low(LCD_RW);
   printf(lcd_putc, "\fPress Any Button");
   while(1){
      if(input(btn_A) == 0 || input(btn_B) == 1 || input(btn_C) == 1) {
   printf(lcd_putc, "\fChecking Btns..A");
   while(1){
      if(input(btn_A) == 1) {
   printf(lcd_putc, "\fChecking Btns..B");
   while(1){
      if(input(btn_B) == 1) {
      printf(lcd_putc, "\fChecking Btns..C");
   while(1){
      if(input(btn_C) == 1) {
PostPosted: Sun Jun 10, 2012 6:31 pm     Reply with quote
I was unable to access the CCS website for the last 4 hours, at least.
But now it's up again.
Your program is way too complicated for checking a button. Try this one
instead. It reads btn_A once every second and displays the results on
the 2nd line of the LCD. It should display a '1' every second, and then
when you press and hold down the button, it should start to display 0's,
and when you release it, then it should displays 1's again.
Also notice that I have enabled PortB pull-ups. That's essential.
int8 result;
output_low(LCD_RW);
port_b_pullups(TRUE);
printf(lcd_putc, "\fPress Any Button\n");
   result = input(btn_A);
   printf(lcd_putc, "%u", result);
seifpic
PostPosted: Sun Jun 10, 2012 6:46 pm     Reply with quote
I wasn't able to access it either.
int8 result;
output_low(LCD_RW);
It keeps Outputting 1s, no zeros. This is how my switches are wired now:
                      ___  Switch A
To                   _|_|_
B0  -----------------o   o---------x
                      ___  Switch B|
To                   _|_|_         |
B1  -----------------o   o---------x
                      ___  Switch C|
To                   _|_|_         |
B2  -----------------o   o------ --x
                                  +5v
Edit:
Finally! I connected the switches to ground and it outputs zeros and ones! Thanks so much for your help, now I just have to get the original program working...
Edit2:
God Bless you, I couldn't have done this project without your help! It works great!
Page 3 of 3
