LMB204BDC with Flex 4 x 20 driver not displaying text
Goto page Previous  1, 2, 3  Next
seifpic
PostPosted: Fri Jun 08, 2012 5:38 am     Reply with quote
PCM programmer wrote:
Let's configure the driver so it doesn't use the lcd's busy bit.
Done that, still first and third line boxes and second and fourth line empty Confused
ezflyr
PostPosted: Fri Jun 08, 2012 7:54 am     Reply with quote
I get 2 errors:
unidentified identifyer
unidentified identifyer ANSEL
Ugh, sorry, that chip has no ANSEL register. I should have researched this a bit more before posting a solution that has worked with other PIC's, but that I wasn't 100% sure was applicable to this one Sad ........
Both I/O ports A and E have analog input capability, and there are several registers (each) that control the functionality of those ports. It might be worth looking at the .lst file generated during compile to be sure that port A and E are being configured for digital I/O.
John
seifpic
PostPosted: Fri Jun 08, 2012 9:12 am     Reply with quote
YAY, I got it to work by trying out a different PIC16F877a I had lying around and it worked! Thanks for all of your help.
seifpic
PostPosted: Fri Jun 08, 2012 5:11 pm     Reply with quote
DAMN! I somehow managed to burn the other PIC that worked. Is there a way to fix a burnt PIC? I program it using MicroPro and I get an error:
ROM programming error at address 0x0001
Good 0x0000
Bad 0x0020
Or can I fix the other PIC that somehow doesn't work with the display??
Thanks in advance, I really need an answer soon as this should be finished by Sunday.
PostPosted: Fri Jun 08, 2012 5:37 pm     Reply with quote
How do you know it's the PIC ? Maybe it's a programmer problem.
You didn't post the part number of your programmer. But you should
search with Google for some tips on solving the problem. Example:
http://diykit.websitetoolbox.com/post?id=1511204
seifpic
PostPosted: Fri Jun 08, 2012 5:40 pm     Reply with quote
I know it's the PIC because I mistakenly connected the 12v power to the 5v power lines and the PIC became very hot. So I'm 100% sure it's the PIC.
Edit: My programmer is a K128 BTW.
PostPosted: Fri Jun 08, 2012 5:53 pm     Reply with quote
I don't think you can fix that problem. You have to get a new PIC.
seifpic
PostPosted: Fri Jun 08, 2012 5:56 pm     Reply with quote
How about the one that for some reason doesn't power the display?
PostPosted: Fri Jun 08, 2012 6:03 pm     Reply with quote
Maybe some of the i/o pins are not working on that PIC. Try using
pins on a different i/o port.
seifpic
PostPosted: Sat Jun 09, 2012 8:00 am     Reply with quote
I bought two new PICs and everything works except for the display...
PostPosted: Sat Jun 09, 2012 2:48 pm     Reply with quote
Post a link to a schematic for your PIC circuit, including all connections
to the PIC and to the LCD (Power, ground, signals, external components,
values of components, etc).
Use a free image hosting service such as http://www.imageshack.us
to host the schematic file (.jpg, .gif, .bmp, etc.), then post the link here.
seifpic
PostPosted: Sat Jun 09, 2012 5:56 pm     Reply with quote
Nevermind, with a crapload of debugging, I found out that my screen also burned, so I bought a new screen, now I'm debugging my program... BTW, do you have an idea why the following code doesn't function properly?
   if(input_state(btn_A) && input_state(btn_B) && input_state(btn_C)) {
      beep();
      testScreen();
and
while(true){
         if(input_state(btn_A)){
            beep();
            good();
            score += 10;
            updateDisplay(score);
         } else if(input_state(btn_B) || input_state(btn_C)){
            beep();
            bad();
Should I add
between each of the {}?
PostPosted: Sat Jun 09, 2012 7:10 pm     Reply with quote
I need to know how your switches are wired - negative or positive logic.
Post a schematic of your push-button circuits. For example, this is the
normal way a push-button switch and its pullup resistor are connected
to a PIC i/o pin. This is negative logic. A button press causes a logic 0
to be applied to the input pin:
           +5v
            > 4.7K
            <         ___  Switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
Should I add break;
If you want to break out of the while loop after a certain button event
has occurred, then yes, you need to put a break statement at the end
of the code in each set of braces. That's what break is used for.
seifpic
PostPosted: Sat Jun 09, 2012 7:49 pm     Reply with quote
This is how my switches are wired
                      ___  Switch
To                   _|_|_
PIC -----------------o   o------ +5v
pin
Please reply quickly as it's 3 AM and I need some sleep.
PostPosted: Sat Jun 09, 2012 8:30 pm     Reply with quote
That switch circuit can't supply two logic states. With that circuit, the PIC
pin is either a floating input or it's a logic "1". You need to fix that.
Change them all to the schematic that I posted. You will also need to
change the logic of your code to look for a logic "0" as the active state of
the switches.
If your switches are connected to pins on PortB, then you can enable
the built-in PortB pullups and save yourself from having to add the
resistors. All you have to do in that case is change the +5v connection
to be Ground instead.
Page 2 of 3
