mtsoule
String fprintf and fputc (fputc works, printf does not) |
Posted: Sun May 20, 2012 9:47 am |
ok, with this code my output is
I expect the output to be
which tells me the length of my string is 0, however if I uncomment the fputc statement, I get the expected data.
I have, for simplicity, taken out all of the error checking and other non essential code.
Compiler version is 4.132
while(BT_inchar != '\n')
while(!BT_Inchar_Ready)
BT_Inchar_Ready = 0;
RX_Buffer[RX_ctr] = BT_inchar;
RX_ctr++;
// fputc(BT_inchar,prog);
fprintf(prog,"{%i{%s}}",strlen(RX_buffer), RX_Buffer);
here is my isr
#int_RDA
void RDA_isr(void)
BT_Inchar = getc(BT);
BT_Inchar_Ready = 1;
bkamen
Posted: Sun May 20, 2012 5:47 pm |
Keep in mind using any string stuff in fprintf (or just printf) requires the string be NULL terminated.
Otherwise, the printf can run off into la-la land.
So when you get your string, before printing it, you need to make sure there's a zero at the end.
mtsoule
Got it!! |
Posted: Mon May 21, 2012 4:39 am |
Thanks Ben, that was it! i ended up moving my "Buffer Filler" to the ISR (i hate putting it there) i like to go in to the ISR and get out. But i found it works best for my app.
Basically here is what i have now in the ISR
#int_RDA
void RDA_isr(void)
if((Packet == Packet_Count) && (BT_Inchar != '\r') && (BT_Inchar != '\n'))
RX_Buffer[RX_ctr] = BT_Inchar;
RX_ctr++;
RX_Buffer[RX_ctr] = 0x00;
if(BT_Inchar == '\n')
Packet_Count++;
i do this so i can read a spific portion of the incomming stream, and i also want to throw away all the "LF's" and "CR's" |
