ROM or CONST Pointer
cfernandez
PostPosted: Sat May 12, 2012 8:20 am     Reply with quote
Is possible use memcpy with a ROM POINTER ?
For example:
rom unsigned char matrix[4] = {1,2,3,4};
rom char *pointer;
char aux[2];
pointer = &matrix;
memcpy( aux, &pointer[ 2 ], 2 );
printf( %02X %02X\n\r", aux[ 0 ], aux[ 1 ] );
I test this and dont work.
I use the last version of compiler.
Best Regards,
bkamen
PostPosted: Sat May 12, 2012 6:09 pm     Reply with quote
ROM CONST is used in C18.
To understand how CCS deals with ROM based information, look at the CCS help .CHM file and the section Titled: Using Program Memory for Data.
Cheers,
-Ben
PostPosted: Sun May 13, 2012 4:47 am     Reply with quote
With PIC16 and PIC18, rom pointers need to be emulated by the compiler, this works only with specific settings. With PIC24 and newer PCD versions, PSV (program storage visibility) allows a direct pointer access to ROM.
Your syntax is wrong however. You are writing
pointer = &matrix;
Should be changed to
pointer = matrix; // or &matrix[0], &matrix is usually understood too
memcpy( aux, pointer[ 2 ], 2 ); // you want to load the pointer value rather than it's address
