| bolubeyi
				| t6963c port change help |
				|  Posted: Mon Apr 30, 2012 7:48 am |   |
				| Hi, I use t6963 and pic18f67k22. My control pins are port F (F1 cd, F2 rd, F3 wr,  F4 rst). Data pins are Port D and I don't changed pins configuration but I don't run it. How can do it? Driver is here but don't work.
  	  | Code: |  	  | /////////////////////////////////////////////////////////////////////////
 ////    T6963C.c     -      T6963C driver                            ////
 ////   Not for comercial Use                                         ////
 ////      Driver by treitmey Graphic functions and Resolution Select ////
 ////                                    by mcdoganay(mcdoganay@gmail.com) ////
 //// This file contains drivers for using a Tosiba T6963C controller ////
 //// in parallel/8080(intel) mode.  The T6963C is 256 pixels across  ////
 ////  and 256 pixels down. The driver treats the upper left pixel 0,0 ////
 ////  Connections are as follows:                                    ////
 ////  /WR - - C4                                                     ////
 ////  /RD - - C5                                                     ////
 ////  C//D- - C6                                                     ////
 ////  /RST- - C7                                                     ////
 ////  DATA0-7 PORTD0-7                                               ////
 ////  LCD's FS is tied low (FS = 0 is 8x8 font)                      ////
 // 256 x 256 in the 8x8 font mode means that 30 characters across by
 // 32 rows of characters may be displayed
 #define set_tris_lcd(x) set_tris_d(x) // Data hattı hangi portta ise o tanımlanacak örneğin "set_tris_c(x)"
 #define LCDColorBlack 0b1
 #define LCDColorWhite 0b0
 #use fast_io(d) // Yukarıda tanımlanan data portu girilecek örneğin fast_io(C)
 const int16 TextHome = 3968;
 const int8  TextArea = 30; // how many bytes before a new line
 const int16 GraphicsHome = 0;
 const int8  GraphicsArea = 30; // how many bytes before a new line
 const int8 AutoModeWrite = 0xB0;
 const int8 AutoModeRead  = 0xB1;
 const int8 AutoModeReset = 0xB2;
 const int8 LCDModeSet  = 0x80;   // send this OR'd with the following
 const int8 LCDMode_OR  = 0b0000;
 const int8 LCDMode_XOR = 0b0001;
 const int8 LCDMode_AND = 0b0010;
 const int8 LCDMode_TA  = 0b0100; // TEXT ATTRIBUTE mode.
 const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
 const int8 LCDSetCursorPtr  = 0x21;  // cursor address
 const int8 LCDSetCursorSize = 0xA0;  // 1 line cursor
 const int8 LCDDispMode = 0x90;   // send this OR'd with the following
 const int8 LCDDisp_BLK = 0b0001;
 const int8 LCDDisp_CUR = 0b0010;
 const int8 LCDDisp_TXT = 0b0100;
 const int8 LCDDisp_GRH = 0b1000;
 const int8 LCDBitSet   = 0xF8;
 const int8 LCDBitReset = 0xF0;
 const int8 LCDBit0 = 0b000;
 const int8 LCDBit1 = 0b001;
 const int8 LCDBit2 = 0b010;
 const int8 LCDBit3 = 0b011;
 const int8 LCDBit4 = 0b100;
 const int8 LCDBit5 = 0b101;
 const int8 LCDBit6 = 0b110;
 const int8 LCDBit7 = 0b111;
 const int8 LCDSetPtr = 0xE0;
 struct lcd_pin_def
 BOOLEAN cd;       // Kontrol hattının 6. pini Command/Data bar bağlı (1=command 0=data)
 BOOLEAN r_bar;    // Kontrol hattının 5. pini Read bar bağlı (düşükte aktif)
 BOOLEAN w_bar;    // Kontrol hattının 1. pini Write bar bağlı (düşükte aktif)
 BOOLEAN reset_bar;// Kontrol hattının 7. pini Reset bağlı (düşükte aktif)
 BOOLEAN unused1;  // Kontrol hattının 0. pini
 BOOLEAN unused2;  // Kontrol hattının 2. pini
 BOOLEAN unused3;  // Kontrol hattının 3. pini
 // BOOLEAN unused4;  // Kontrol hattının 4. pini
 struct lcd_pin_def  LCD;
 #byte LCD = 0xf85        // Kontrol portunun işlemcideki adresi (18f452 için B port adresi 0xf81)
 #byte LCD_Data = 0xf83   // Data portunun işlemcideki adresi (18f452 için D port adresi 0xf83)
 int   glcd_ReadByte(void);
 void  glcd_WriteByte(int1 cd, int data);
 void  glcd_WriteByteAuto(int data);
 void  glcd_WriteCmd2(int16 data, int cmd);
 void  glcd_WriteCmd1(int data, int cmd);
 void  glcd_gotoxy(int x, int y, int1 text);
 //// Defines a 5x7 font
 const int8 FONT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
 0x00, 0x00, 0x5F, 0x00, 0x00, // !
 0x00, 0x03, 0x00, 0x03, 0x00, // "
 0x14, 0x3E, 0x14, 0x3E, 0x14, // #
 0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
 0x43, 0x33, 0x08, 0x66, 0x61, // %
 0x36, 0x49, 0x55, 0x22, 0x50, // &
 0x00, 0x05, 0x03, 0x00, 0x00, // '
 0x00, 0x1C, 0x22, 0x41, 0x00, // (
 0x00, 0x41, 0x22, 0x1C, 0x00, // )
 0x14, 0x08, 0x3E, 0x08, 0x14, // *
 0x08, 0x08, 0x3E, 0x08, 0x08, // +
 0x00, 0x50, 0x30, 0x00, 0x00, // ,
 0x08, 0x08, 0x08, 0x08, 0x08, // -
 0x00, 0x60, 0x60, 0x00, 0x00, // .
 0x20, 0x10, 0x08, 0x04, 0x02, // /
 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
 0x00, 0x04, 0x02, 0x7F, 0x00, // 1
 0x42, 0x61, 0x51, 0x49, 0x46, // 2
 0x22, 0x41, 0x49, 0x49, 0x36, // 3
 0x18, 0x14, 0x12, 0x7F, 0x10, // 4
 0x27, 0x45, 0x45, 0x45, 0x39, // 5
 0x3E, 0x49, 0x49, 0x49, 0x32, // 6
 0x01, 0x01, 0x71, 0x09, 0x07, // 7
 0x36, 0x49, 0x49, 0x49, 0x36, // 8
 0x26, 0x49, 0x49, 0x49, 0x3E, // 9
 0x00, 0x36, 0x36, 0x00, 0x00, // :
 0x00, 0x56, 0x36, 0x00, 0x00, // ;
 0x08, 0x14, 0x22, 0x41, 0x00, // <
 0x14, 0x14, 0x14, 0x14, 0x14, // =
 0x00, 0x41, 0x22, 0x14, 0x08, // >
 0x02, 0x01, 0x51, 0x09, 0x06, // ?
 0x3E, 0x41, 0x59, 0x55, 0x5E, // @
 0x7E, 0x09, 0x09, 0x09, 0x7E, // A
 0x7F, 0x49, 0x49, 0x49, 0x36, // B
 0x3E, 0x41, 0x41, 0x41, 0x22, // C
 0x7F, 0x41, 0x41, 0x41, 0x3E, // D
 0x7F, 0x49, 0x49, 0x49, 0x41, // E
 0x7F, 0x09, 0x09, 0x09, 0x01, // F
 0x3E, 0x41, 0x41, 0x49, 0x3A, // G
 0x7F, 0x08, 0x08, 0x08, 0x7F, // H
 0x00, 0x41, 0x7F, 0x41, 0x00, // I
 0x30, 0x40, 0x40, 0x40, 0x3F, // J
 0x7F, 0x08, 0x14, 0x22, 0x41, // K
 0x7F, 0x40, 0x40, 0x40, 0x40, // L
 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
 0x7F, 0x02, 0x04, 0x08, 0x7F, // N
 0x3E, 0x41, 0x41, 0x41, 0x3E, // O
 0x7F, 0x09, 0x09, 0x09, 0x06, // P
 0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
 0x7F, 0x09, 0x09, 0x09, 0x76};// R
 const int8 FONT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
 0x01, 0x01, 0x7F, 0x01, 0x01, // T
 0x3F, 0x40, 0x40, 0x40, 0x3F, // U
 0x1F, 0x20, 0x40, 0x20, 0x1F, // V
 0x7F, 0x20, 0x10, 0x20, 0x7F, // W
 0x41, 0x22, 0x1C, 0x22, 0x41, // X
 0x07, 0x08, 0x70, 0x08, 0x07, // Y
 0x61, 0x51, 0x49, 0x45, 0x43, // Z
 0x00, 0x7F, 0x41, 0x00, 0x00, // [
 0x02, 0x04, 0x08, 0x10, 0x20, // \
 0x00, 0x00, 0x41, 0x7F, 0x00, // ]
 0x04, 0x02, 0x01, 0x02, 0x04, // ^
 0x40, 0x40, 0x40, 0x40, 0x40, // _
 0x00, 0x01, 0x02, 0x04, 0x00, // `
 0x20, 0x54, 0x54, 0x54, 0x78, // a
 0x7F, 0x44, 0x44, 0x44, 0x38, // b
 0x38, 0x44, 0x44, 0x44, 0x44, // c
 0x38, 0x44, 0x44, 0x44, 0x7F, // d
 0x38, 0x54, 0x54, 0x54, 0x18, // e
 0x04, 0x04, 0x7E, 0x05, 0x05, // f
 0x08, 0x54, 0x54, 0x54, 0x3C, // g
 0x7F, 0x08, 0x04, 0x04, 0x78, // h
 0x00, 0x44, 0x7D, 0x40, 0x00, // i
 0x20, 0x40, 0x44, 0x3D, 0x00, // j
 0x7F, 0x10, 0x28, 0x44, 0x00, // k
 0x00, 0x41, 0x7F, 0x40, 0x00, // l
 0x7C, 0x04, 0x78, 0x04, 0x78, // m
 0x7C, 0x08, 0x04, 0x04, 0x78, // n
 0x38, 0x44, 0x44, 0x44, 0x38, // o
 0x7C, 0x14, 0x14, 0x14, 0x08, // p
 0x08, 0x14, 0x14, 0x14, 0x7C, // q
 0x00, 0x7C, 0x08, 0x04, 0x04, // r
 0x48, 0x54, 0x54, 0x54, 0x20, // s
 0x04, 0x04, 0x3F, 0x44, 0x44, // t
 0x3C, 0x40, 0x40, 0x20, 0x7C, // u
 0x1C, 0x20, 0x40, 0x20, 0x1C, // v
 0x3C, 0x40, 0x30, 0x40, 0x3C, // w
 0x44, 0x28, 0x10, 0x28, 0x44, // x
 0x0C, 0x50, 0x50, 0x50, 0x3C, // y
 0x44, 0x64, 0x54, 0x4C, 0x44, // z
 0x00, 0x08, 0x36, 0x41, 0x41, // {
 0x00, 0x00, 0x7F, 0x00, 0x00, // |
 0x41, 0x41, 0x36, 0x08, 0x00, // }
 0x02, 0x01, 0x02, 0x04, 0x02};// ~
 #inline
 void glcd_init(unsigned int16 res_x, unsigned int16 res_y) {
 int16 counter;
 set_tris_f(0b00000000);  // Kontrol portunun yönlendirilmesi
 set_tris_lcd(0xff);      // Data portunun yönlendirilmesi
 LCD.w_bar = 1;      // INITIAL STATES OF CONTROL PINS
 LCD.r_bar = 1;      //
 LCD.cd = 1;         // command
 LCD.reset_bar = 0;  // perform a reset
 LCD.reset_bar = 1;  // run
 // Set up the graphics and text areas
 glcd_WriteCmd2(TextHome, 0x40);
 glcd_WriteCmd2(TextArea, 0x41);
 glcd_WriteCmd2(GraphicsHome, 0x42);
 glcd_WriteCmd2(GraphicsArea, 0x43);
 // set address to 0
 glcd_WriteCmd2(0x0000, 0x24);
 // Clear all RAM of LCD (8k)
 glcd_WriteByte(1, AutoModeWrite);
 for (counter = 0; counter < 0x1fff; counter++)
 glcd_WriteByteAuto(0);    // fill everything with zeros
 glcd_WriteByte(1, AutoModeReset);
 int status = 0, temp = 0;
 set_tris_lcd(0xff);
 LCD.w_bar = 1;
 LCD.r_bar= 1;
 LCD.cd = 1;//defaults
 while (status != 0x03) {  // is LCD busy?
 LCD.r_bar= 0;
 temp = LCD_Data;
 LCD.r_bar = 1;
 status = temp & 0x03;
 set_tris_lcd(0x00);    // All outputs
 LCD.cd = cd;           // Command/Data bar
 LCD_Data = data;
 LCD.r_bar = 1;         // not read
 LCD.w_bar = 0;         // write
 LCD.w_bar = 1;         // release
 int status = 0, temp = 0; // status bits ARE DIFFERENT BITS THAN NORMAL
 set_tris_lcd(0xff);
 LCD.w_bar = 1;
 LCD.r_bar = 1;
 LCD.cd = 1; // defaults
 while (status != 0x08) {  // is LCD busy?
 LCD.r_bar = 0;
 temp = LCD_Data;
 LCD.r_bar = 1;
 status = temp & 0x08;
 LCD.cd = 0;             // This is always data, cd=0
 LCD_Data = data;        // Put data on data bus
 glcd_WriteByte(0, data);
 glcd_WriteByte(1, cmd);
 glcd_WriteByte(0, data & 0xff);
 glcd_WriteByte(0, data>>8);
 int data = 0, status = 0, temp = 0;
 set_tris_lcd(0xff);
 LCD.w_bar = 1;
 LCD.r_bar = 1;
 #asm nop #endasm
 LCD.r_bar = 0;
 temp = LCD_Data;
 LCD.r_bar = 1;
 LCD.cd = 0;          // Command/Data bar
 LCD.r_bar = 0;        // read
 #asm nop #endasm    // THIS PAUSE IS VERY NESSESARY !!!//
 data = LCD_Data;
 LCD.r_bar = 1;
 LCD.cd = 1;
 return data;        // Return the read data
 void glcd_putc(char c) {
 glcd_WriteCmd1(c - 0x20, 0xc0);
 void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
 // location 1,1 is upper left corner;  text = 1 (text area), text = 0 (graphics area)
 int16 location, home;
 int line;
 if (text==0) {
 home = GraphicsHome;
 line = GraphicsArea;
 } else {
 home = TextHome;
 line = TextArea;
 location = home + (((int16)y) * line) + x;
 glcd_WriteCmd2(location, 0x24);
 // Purpose:       Clears LCD RAM
 void glcd_clr(int16 location,int16 size)
 ////fprintf(DEBUG,"loc=%lu  size=%lu\n\r",location,size);
 // look very simular to the init,... doesn't it. : )
 glcd_WriteCmd2(location,LCDSetPtr);
 glcd_WriteCmd1(1,AutoModeWrite);
 for (;size;size--)
 glcd_WriteByteAuto(0x00);//clear ram
 glcd_WriteCmd1(1,AutoModeReset);
 // Graphics Controller by mcdoganay (c)2010
 //    mcdoganay@gmail.com
 //       Not for comercial use
 unsigned int8 i;  //General Purpouse variable
 // glcd_pixel(x,y,c) sets pixel x,y with c color
 void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 c){
 unsigned int8 x_H;
 unsigned int8 x_L=0;
 x_H = (x / 8);//6x8 karaktere göre ayarlandı
 x_L = 7 - (x - 8*x_H);//6x8 karaktere göre ayarlandı
 glcd_gotoxy(x_H,y,0);    //Bug fixed, thanks to etiedon
 if(c){
 glcd_WriteCmd1(1,(LCDBitSet|x_L));
 } else {
 glcd_WriteCmd1(1,(LCDBitReset|x_L));
 // glcd_pixel8(x,y,px8) sets 8 pixels in line.
 void glcd_pixel8(unsigned int8 x, unsigned int8 y, int8 pixel8){
 unsigned int8 x_H;
 x_H = (x / 8); //6x8 karaktere göre ayarlandı
 glcd_WriteCmd1(pixel8,0xc0);
 // glcd_line(x0,y0, x1,y1, c) puts line from (x0, y0) to (x1, y1) with c color
 #separate
 void glcd_line(int16 x1, int16 y1, int16 x2, int16 y2, int kalilik, int1 color)
 int16        dy, dx;
 signed int8  addx=1, addy=1;
 signed int16 P, diff;
 int16 i=0;
 int8 j = 0;
 dx = abs((signed int16)(x2 - x1));
 dy = abs((signed int16)(y2 - y1));
 if(x1 > x2)
 addx = -1;
 if(y1 > y2)
 addy = -1;
 if(dx >= dy)
 dy *= 2;
 P = dy - dx;
 diff = P - dx;
 for(; i<=dx; ++i)
 glcd_pixel(x1 + j, y1, color);
 if(P < 0)
 P  += dy;
 x1 += addx;
 P  += diff;
 x1 += addx;
 y1 += addy;
 dx *= 2;
 P = dx - dy;
 diff = P - dy;
 for(; i<=dy; ++i)
 glcd_pixel(x1, y1 + j, color);
 if(P < 0)
 P  += dx;
 y1 += addy;
 P  += diff;
 x1 += addx;
 y1 += addy;
 // glcd_square(x0,y0,x1,y1, c) sets square
 void glcd_square( unsigned int8 x0, unsigned int8 y0,
 unsigned int8 x1, unsigned int8 y1 , int1 c){
 glcd_line(x0,y0, x1,y0,1, c);
 glcd_line(x1,y0, x1,y1, 1,c);
 glcd_line(x0,y1, x1,y1, 1,c);
 glcd_line(x0,y0, x0,y1, 1, c);
 // glcd_box(x0,y0,x1,y1, c)
 void glcd_box( unsigned int8 x0, unsigned int8 y0,
 unsigned int8 x;
 unsigned int8 y;
 for(y=y0; y<=y1;y++){
 for(x=x0; x<=x1;x++){
 if((!(x%8)) && ((x1-x)>8)){
 glcd_pixel8(x,y,0xFF*c);  //Same time to write 8 pixel
 x +=7 ;
 } else {
 glcd_pixel(x,y,c);
 // Purpose:       Draw a circle on a graphic LCD
 // Inputs:        (x,y) - the center of the circle
 //                radius - the radius of the circle
 //                fill - YES or NO
 //                color - ON or OFF
 void glcd_circle(int16 x, int16 y, int16 radius, int1 fill, int1 color)
 #ifdef LARGE_LCD
 signed int16 a, b, P;
 #else
 signed int8  a, b, P;
 #endif
 a = 0;
 b = radius;
 P = 1 - radius;
 do
 if(fill)
 glcd_line(x-a, y+b, x+a, y+b, 1, color);
 glcd_line(x-a, y-b, x+a, y-b, 1, color);
 glcd_line(x-b, y+a, x+b, y+a, 1, color);
 glcd_line(x-b, y-a, x+b, y-a, 1, color);
 glcd_pixel(a+x, b+y, color);
 glcd_pixel(b+x, a+y, color);
 glcd_pixel(x-a, b+y, color);
 glcd_pixel(x-b, a+y, color);
 glcd_pixel(b+x, y-a, color);
 glcd_pixel(a+x, y-b, color);
 glcd_pixel(x-a, y-b, color);
 glcd_pixel(x-b, y-a, color);
 if(P < 0)
 P += 3 + 2 * a++;
 P += 5 + 2 * (a++ - b--);
 } while(a <= b);
 //glcd_image8 (*Pic, x, y, size_x, size_y)
 void glcd_image8(int8 *pic_px, unsigned int8 x, unsigned int8 y,
 unsigned int8 size_x, unsigned int8 size_y){
 unsigned int16 px_y;
 unsigned int16 px_x;
 unsigned int16 px=0;
 for(px_y=y; px_y<(y+size_y); px_y++){
 for(px_x=x; px_x<(x+size_x); px_x+=8) //6x8 karaktere göre ayarlandı
 glcd_pixel8(px_x, px_y, *(!pic_px+px));
 px+=1;
 void glcd_text57(int16 x, int16 y, char* textptr, int8 size, int1 color)
 int8 j, k, l, m;                       // Loop counters
 int8 pixelData[5];                     // Stores character data
 for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
 if(*textptr < 'S') // Checks if the letter is in the first font array
 memcpy(pixelData, FONT[*textptr - ' '], 5);
 else if(*textptr <= '~') // Check if the letter is in the second font array
 memcpy(pixelData, FONT2[*textptr - 'S'], 5);
 memcpy(pixelData, FONT[0], 5);   // Default to space
 // Handles newline and carriage returns
 switch(*textptr)
 case '\n':
 y += 7*size + 1;
 continue;
 case '\r':
 x = 0;
 continue;
 if(x+5*size >= 240)          // Performs character wrapping
 x = 0;                           // Set x at far left position
 y += 7*size + 1;                 // Set y at next position down
 for(j=0; j<5; ++j, x+=size)         // Loop through character byte data
 for(k=0; k < 7; ++k)             // Loop through the vertical pixels
 if(bit_test(pixelData[j], k)) // Check if the pixel should be set
 for(l=0; l < size; ++l)    // These two loops change the
 {                          // character's size
 for(m=0; m < size; ++m)
 glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
