PIC18 and Batron LCD
Nador
PostPosted: Thu May 10, 2012 3:34 pm     Reply with quote
Hi guys,
I'm currently facing some trouble dealing with a Batron LCD (BT96040AV1).
It is connected to a PIC18F4520 via I2C.
I'm using C and MPlab IDE v8.
First it took me some days to find out that the LCD now uses another controller (ST7549T) instead of the one provided on the Farnell homepage (STE2004S).
With that information i was able to setup the LCD and turn all segments on (wow i can see something on the screen :D).
But since I'm still a beginner and the data sheet is a little confusing to me, i could need some help on how to write data to the ram / show a dot or a line on the display. I've tried several approaches, but none brought me any results.
The data sheet can be found here for example http://pdf1.alldatasheet.com/datasheet-pdf/view/326159/SITRONIX/ST7549T.html
Here's the working code for setting up the display:
#include <main.h>
#define LCD_RST PIN_B3
#define LCD_SCL PIN_C3
#define LCD_SDA PIN_C4
#define LCD_ADDRESS 0x7E
int ack_status;
#use delay(clock=8000000)
#use i2c(MASTER,FAST,SDA=LCD_SDA,SCL=LCD_SCL)
void command (unsigned int8 command) {
    i2c_write(0x80);   //C0 = 1, A0 = 0, another control byte will follow the data byte
    i2c_write(command);
void setFunction (unsigned int8 page, unsigned int8 cmd) {
    command(0x20+page); //select page
    command(cmd);
void init_io() {
    output_low(LCD_RST);
    output_high(LCD_RST);
void main() {
    init_io();
    i2c_start();
    ack_status =  i2c_write(LCD_ADDRESS);
   //set bias system, bias = 9, 1/68 duty
    setFunction(1,0x12);
    //set D0 = 1
    setFunction(1,0x0C);
    //set start line
    setFunction(1, 0x41);
    //set voltage
    setFunction(1,0xd8);
    //PRS high
    setFunction(0,0x05);
    //all segments on
    setFunction(0,0x09);
    //display normal mode
    setFunction(0,0x0c);
    i2c_stop();
Any help will be appreciated Smile
Thanks in advance.
Jul
PostPosted: Thu May 10, 2012 4:02 pm     Reply with quote
See this thread. It may help you to get started.
http://www.ccsinfo.com/forum/viewtopic.php?t=36806
PostPosted: Thu May 10, 2012 6:57 pm     Reply with quote
Since it's an I2C device, do you have the correct pullup resistors on the I2C data lines ?
Nador
PostPosted: Fri May 11, 2012 1:33 am     Reply with quote
@PCM programmer
Thanks, this is the thread that helped me getting started and setting up the display, but defining the start points or writing seems to not have any effect... the screens stays blank without showing anything.
@temtronic
i'm using 4.9k pullups, and since the display acknowledges the write of any byte-data it seems fine Smile but thanks for the hint Smile
I'm glad for every response that might help Smile
Nador
PostPosted: Sun May 13, 2012 4:01 pm     Reply with quote
Since I'm getting nowhere, I have read the datasheet a few more times but still don't understand how to write data to the display.
I've rewritten my code to avoid any mistakes in the setup process.
If anybody could help me, or post a link where i can find further information on how to drive this display, i would be really grateful!
Thanks in advance.
Jul
PostPosted: Sun May 13, 2012 4:12 pm     Reply with quote
The link PCM referenced you to should have been enough. Post what you
have now so we can help find the error.
Nador
PostPosted: Mon May 14, 2012 5:19 am     Reply with quote
According to the thread PCM referenced I should use a "data" function to set x and y address and write data.
So this is what my code then looks like (regretfully not showing anything to me).
I tried to understand the graphics (page 20-21) that explain the RAM format but I still don't get the correlation between writing to an address in the RAM specified by a value for x and y and which dot on the display lights up.
#include <main.h>
int ack_status;
    i2c_write(command);
    command(cmd);
void data (unsigned int8 data, int8 col, int8 row)   {
setFunction(0,0x80+col);      // set vertical (X) start point
setFunction(0,0x40+row);      // set horizontal (Y) start point
i2c_write(0xC0);
i2c_write(data);
void init_io() {
void main() {
    init_io();
    i2c_start();
    //set D0 = 1
    //set start line
    //set voltage
    //PRS high
    //all segments on
    //set start points and write data
    data(0xFF,5,2);
    i2c_stop();
I'll keep trying, but it's pretty hard for a newbie Very Happy
Nador
PostPosted: Thu May 24, 2012 7:09 am     Reply with quote
Hey guys,
Since i'm getting nowhere, can somebody suggest a well-documented graphical display?
Time is passing by really fast, and i need to get my project to work Very Happy
Thanks again.
Jul
ezflyr
PostPosted: Thu May 24, 2012 12:55 pm     Reply with quote
I've had excellent luck with this particular display: http://www.sparkfun.com/products/710 It looks descent, and uses the fairly ubiquitous KS0108 display driver chip. There is a lot of code floating around for this chip, so that should not be a problem. The downside is that this display uses a parallel interface, so it's going to chew up a lot more of your I/O.
John
