MAKInnovation
| 18F6722 RS232 problem |
Posted: Mon Mar 19, 2012 12:32 am |
Dear Friends;
I am using 18F6722 microcontroller for 2 serial hardware ports.
I have made a simple program but it does not work correctly.
I really don't know the reason why.
Here is my code:
#include <18F6722.h>
#fuses HS,NOWDT,PROTECT,NOLVP
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N, XMIT=PIN_C6, RCV=PIN_C7,errors,bits=8,stream=s1)
#use rs232(baud=9600,parity=N, XMIT=PIN_G1, RCV=PIN_G2,errors,bits=8,stream=s2)
fprintf(s1,"Online\r\n");
fprintf(s2,"Online\r\n");
And this is the output I received on the terminal. Terminal stops receiving DATA after 2, 3 lines of DATA even if I am sending DATA with continuous loop and no DATA receive after the garbage. DATA..
\0Aine\0D
\0AOnline\0D
\0AOnline\0D
Ê‹«Onliÿ |
MAKInnovation
Posted: Mon Mar 19, 2012 2:41 am |
Spambot post removed. Sorry.
- Forum Moderator
Thanks;
I have just tried to use only one serial port and it is working fine with single serial port with RS485 IC
have a look:
#device ICD=TRUE
#fuses HS
#use rs232(baud=9600,parity=N, XMIT=PIN_G1, RCV=PIN_G2,errors,bits=8)
#fuses NOWDT
//#use rs232(baud=9600,parity=N, XMIT=PIN_C6, RCV=PIN_C7,errors,bits=8,stream=s1)
#use rs232(baud=9600,parity=N, XMIT=PIN_G1, RCV=PIN_G2,errors,bits=8)//,stream=s2)
//output_high(PIN_G0);
//output_low(PIN_G0);
printf("online");
// fprintf(s1,"Online\r\n");
// fprintf(s2,"Online\r\n");
output_toggle(PIN_G0);
[/code] |
RF_Developer
Posted: Mon Mar 19, 2012 4:42 am |
Try using UART1 and UART2 instead of specifying the pins.
RF Developer |
MAKInnovation
Posted: Tue Mar 20, 2012 1:54 am |
Thank you RF for your help.
I made a second hardware with the same controller and the same program is working with it.
There might be something wrong with RS232 IC or its connection in previous card. I am looking for it.
Thanks for everyone who helped me in my simple task.
Regards
Ashraf |
