4-Wire resistive touch driver
PICoHolic
PostPosted: Thu Mar 08, 2012 3:51 am     Reply with quote
#ifndef  RTOUCH_H
#define  RTOUCH_H
#bit     XpIO  =  PORTA.0
#bit     YpIO  =  PORTA.1
#bit     XnIO  =  PORTA.2
#bit     YnIO  =  PORTA.3
#bit     YpPU  =  PORTA.6  //pullup source (O)
#bit     RTsns =  PORTB.0  //sense pin (I)
#bit     XpTrs =  TRISA.0
#bit     YpTrs =  TRISA.1
#bit     XnTrs =  TRISA.2
#bit     YnTrs =  TRISA.3
#bit     YpPUTrs  =  TRISA.6
#bit     RTsnsTrs =  TRISB.0
#define  XpADC    sAN0
#define  YpADC    sAN1
#define  XnADC    sAN2
#define  YnADC    sAN3
#define  XpCh     0
#define  YpCh     1
#define  XnCh     2
#define  YnCh     3
#define  DriveXpLow()   {XpTrs=0; XpIO=0;}
#define  DriveXpHigh()  {XpTrs=0; XpIO=1;}
#define  FLoatXp()      XpTrs=1
#define  DriveXnLow()   {XnTrs=0; XnIO=0;}
#define  DriveXnHigh()  {XnTrs=0; XnIO=1;}
#define  FLoatXn()      XnTrs=1
#define  DriveYpLow()   {YpTrs=0; YpIO=0;}
#define  DriveYpHigh()  {YpTrs=0; YpIO=1;}
#define  FLoatYp()      YpTrs=1
#define  DriveYnLow()   {YnTrs=0; YnIO=0;}
#define  DriveYnHigh()  {YnTrs=0; YnIO=1;}
#define  FLoatYn()      YnTrs=1
#define  EnableYpPU()   {YpPUTrs=0; YpPU=1;}
#define  DisableYpPU()  YpPUTrs=1
#define  RTouched()     (RTsns==0)
#define  RT_kbhit()     RTouched()
typedef  struct _RT_Coordinate
   int16 X;
   int16 Y;
} RT_Coordinate;
void InitRtouch()
   FLoatYp();
   FLoatXp();
   FLoatYn();
   DriveXnLow();
   EnableYpPU();
int16 ReadYRaw()
   int16 p, n;
   // Read Xp
   FloatXp();
   setup_adc_ports(XpADC);
   set_adc_channel(XpCh);
   FloatXn();
   DriveYpHigh();
   DriveYnLow();
   delay_ms(5);   //tunable
   p = read_adc();
   // Read Xn
   FloatXn();
   setup_adc_ports(XnADC);
   set_adc_channel(XnCh);
   //DriveYpLow();
   //DriveYnHigh();
   n = read_adc();
   return ((n+p) >> 1); //return average
int16 ReadXRaw()
   int16 p, n;
   // Read Yp
   FloatYp();
   setup_adc_ports(YpADC);
   set_adc_channel(YpCh);
   FloatYn();
   DriveXpHigh();
   DriveXnLow();
   p = read_adc();
   // Read Yn
   FloatYn();
   setup_adc_ports(YnADC);
   set_adc_channel(YnCh);
   //DriveXpLow();
   //DriveXnHigh();
   n = read_adc();
RT_Coordinate GetRTRawXY(void)
   RT_Coordinate localXY={0,0};
   InitRtouch();
   while(!RTouched());  //Not touched yet?
   DisableYpPU();
   while (RTouched())
      localXY.X = ReadXRaw();
      localXY.Y = ReadYRaw();
      #ifdef _DEBUG_
         printf("\fX: %Lu     Y: %Lu", localXY.X, localXY.Y);
      InitRtouch();
      delay_ms(250);    //tunable
   return localXY;
Circuit:
[img]
http://myr.smoothdesign.net/downloads/rtouch.bmp
[/img]
Usage:
RT_Coordinate XY;
if (RT_kbhit())
         XY = GetRTRawXY();
PICoHolic
Updates
PostPosted: Thu Aug 02, 2012 5:13 am     Reply with quote
Here's an update:
Info: bug fixes, touch detection selection (on push or on release), etc...
#define  MAXPOINTS      4
#define  MAXPOINTSMSK   MAXPOINTS-1
#define  PICKPOINTS     (MAXPOINTS/2)
   RT_Coordinate localXY={INVALIDXY,INVALIDXY};
   signed int16 XY[MAXPOINTS][2];
   int8 PointPtr=0, Tcount=0;
   InitRtouch();
   do {
      DisableYpPU();
      XY[PointPtr][0] = ReadXRaw();
      XY[PointPtr][1] = ReadYRaw();
      #ifdef _DEBUG_TC_
         //fprintf(DEBUG_PORT, "\f%u - X: %Ld     Y: %Ld\n\r", PointPtr, XY[PointPtr][0], XY[PointPtr][1]);
      PointPtr = (PointPtr+1) & MAXPOINTSMSK;   //circular buffer
      InitRtouch();
      delay_ms(15);    //tunable
      Tcount++;
      restart_wdt();   //reset WDT
   #ifdef RETURN_ON_TOUCH
      }while (Tcount < MAXPOINTS);
   #else
      }while (RTouched());
      if (Tcount >= MAXPOINTS)
            //extract sample delayed by PICKPOINTS readings
            PointPtr = (PointPtr - PICKPOINTS) & MAXPOINTSMSK;
            LocalXY.X = XY[PointPtr][0];
            LocalXY.Y = XY[PointPtr][1];
   #ifdef _DEBUG_TC_
      fprintf(DEBUG_PORT, "X: %Ld     Y: %Ld\n\r", LocalXY.X, LocalXY.Y);
   return localXY;
Usage:
RT_Coordinate XY;
if (RT_kbhit())
         XY = GetRTRawXY();
         //Beep();
             while(RT_kbhit());
mhjccsinfo
PostPosted: Wed Sep 18, 2013 11:06 am     Reply with quote
Dear PICoHolic,
were you able to use this program completely?
for example could you draw any picture or write anything you want every where in your LCD?
I have used another circuit that I have design it by myself because I could not do these with the circuit you mentioned .I have added it some ICs!
before I do it the X and Y were related together. but now they are working great
thanks and hope of success for you
Mohammad_Hosein
PICoHolic
PostPosted: Wed Sep 18, 2013 2:20 pm     Reply with quote
Hello Mohammad,
This is a working code and it has nothing to do with LCDs. It's just a TOUCH PANEL driver.
The driver reads RAW data, in order to map it to an LCD you need to calibrate it.
Cheers
mhjccsinfo
PostPosted: Wed Sep 18, 2013 3:17 pm     Reply with quote
Well , my problem with this circuit was : increasing y with the increasing of x (and vice versa ). I never understand what was the problem but the problem solved when I change the circuit.
I watched this problem when I made a painting program for my LCD.
then I decided to print x and y on LCD.
the output for four corner of LCD should be below (after calibration):
(1,1)-------------------------------------------------(128,1)
(1,240)---------------------------------------------(128,240)
but it was something this:
(1,1)-------------------------------------------------(128,10)
(15,240)---------------------------------------------(140,270)
So you say the circuit (simple circuit with direct connecting touch to ADC) have no problem, yes?
Mohammad_Hosein
PICoHolic
PostPosted: Thu Sep 19, 2013 2:10 am     Reply with quote
Yes no problem
