Isaac aiyanyo Guest
| HOW TO SCROLL 8X8 LED |
Posted: Mon Nov 04, 2002 6:53 am |
Please picstars
could assist me on how i could make this 5x7 led
display scroll the letter across the screen.
i have being trying for days now i can't seem to
do it i am pulling my hair out
Here is the code below
i found this at
<a href="http://www.blitzlogic.com/Matrix.htm" TARGET="_blank">http://www.blitzlogic.com/Matrix.htm</a>
and intead to use it to help me learning process
Thanks in advance
Isaac
#include <16c84.h>
#USE DELAY( CLOCK=4000000 ) /* Using a 4 Mhz clock */
#FUSES XT,NOWDT,NOPROTECT,NOPUT
/* Use XT mode, No Watch Dog, No Code Protect, No Power-up Timer */
#byte port_b=6 /* define the location of register port_b */
#byte port_a=5 /* define the location of register port_b */
char const pat[5]={0x3f,0x02,0x04,0x02,0x3f};
main(){
char cnt, col;
set_tris_b(0); /* set port_b as outputs */
set_tris_a(0); /* set port_a as output */
port_b = 0; /* ZERO port_a & port_b */
port_a = 0;
for( ;; )
col = 1;
for(cnt = 0;cnt < 5;cnt++)
port_b = pat[cnt];
port_a = col;
delay_ms(1);
col<<=1;
___________________________
Original Post ID: 8481 |
Mark
| Re: HOW TO SCROLL 8X8 LED |
Posted: Mon Nov 04, 2002 7:59 am |
#include <16c84.h>
main(){
char cnt, scrollcnt, col;
port_a = 0;
col = 0b00000001; // The column that we are driving
scrollcnt = 0;
while(1) // Infinite loop to avoid run on code
++scrollcnt; // scrollcnt is used as a delay before we switch columns
if (scrollcnt == 250)
scrollcnt = 0;
col>>=1; // Rotate our mask for the next column
if (col == 0) // Reset our mask if needed
col = 0b00010000;
col = 1;
port_a = 0; // Turn off any previous data displayed
port_b = pat[cnt]; // Setup the data to display
port_a = col; // Display the new data
delay_ms(1); // Give some delay before we output the next column
col<<=1; // Rotate our mask for the next column
Regards
Mark
:= Please picstars
:= could assist me on how i could make this 5x7 led
:= display scroll the letter across the screen.
:= i have being trying for days now i can't seem to
:= do it i am pulling my hair out
:=Here is the code below
:=i found this at
:=and intead to use it to help me learning process
:=Thanks in advance
:=Isaac
:=#include <16c84.h>
:= #USE DELAY( CLOCK=4000000 ) /* Using a 4 Mhz clock */
:= #FUSES XT,NOWDT,NOPROTECT,NOPUT
:= /* Use XT mode, No Watch Dog, No Code Protect, No Power-up Timer */
:= #byte port_b=6 /* define the location of register port_b */
:= #byte port_a=5 /* define the location of register port_b */
:= char const pat[5]={0x3f,0x02,0x04,0x02,0x3f};
:= main(){
:= char cnt, col;
:= set_tris_b(0); /* set port_b as outputs */
:= set_tris_a(0); /* set port_a as output */
:= port_b = 0; /* ZERO port_a & port_b */
:= port_a = 0;
:= for( ;; )
:= col = 1;
:= for(cnt = 0;cnt < 5;cnt++)
:= port_b = pat[cnt];
:= port_a = col;
:= delay_ms(1);
:= col<<=1;
Original Post ID: 8482 |
Mark
Posted: Mon Nov 04, 2002 9:40 am |
Here is an example of scrolling a message:
#include <16c84.h>
char const pat[34]={0x7F,0x08,0x08,0x08,0x7F,0x00,0x7F,0x49,0x49,0x41,0x41,0x00,0x7F,0x01,0x01,0x01,0x01,0x00,0x7F,0x01,0x01,0x01,0x01,0x00,0x3E,0x41,0x41,0x41,0x3E,0x00,0x00,0x00,0x00,0x00};
main(){
char cnt, cnt2, scrollcnt, col;
port_a = 0;
scrollcnt = 0;
cnt2 = 0;
scrollcnt = 0;
++cnt2;
if (cnt2 == 34)
cnt2 = 0;
port_b = pat[cnt+cnt2]; // Setup the data to display
Regards,
Mark
:= Please picstars
:=i found this at
:=Thanks in advance
:=Isaac
:= main(){
:= char cnt, col;
:= port_a = 0;
:= for( ;; )
:= col = 1;
:= port_a = col;
:= delay_ms(1);
:= col<<=1;
Original Post ID: 8484 |
isaac aiyanyo Guest
Posted: Mon Nov 04, 2002 11:20 am |
Thank you very much mark
i am going to try them right now
i shall let you know the outcome
Top gun
Isaac
Original Post ID: 8488 |
aiyanyo Guest
Posted: Mon Nov 04, 2002 7:15 pm |
Mark,
Your example worked perfectly, and it has developed my
understanding of C programming.
i modified the program for an 8x8 Led using pic 16f873
the program scrolls the word hello acrsoss the display
it's perfect !!!
one more problem, when the program exits i tried to put
in a continous loop so that it starts again .
i use for (;;)& do-while but the program still would
not loop back.
am i doing something really bad here.
Thanks a million
Isaac
The program is attached below :
#if defined(__PCM__)
#include <16F873.H>
#fuses XT,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
//THIS IS ANOTHER PROGRAM CALLED SROLL2//
#byte port_a=5
#byte port_b=6
#byte port_c=7
char const pat[48]={0,255,255,24,24,255,255,0,0,255,255,219,219,195,195,0,
0,255,255,192,192,192,192,0,0,255,255,192,192,192,192,0,
0,60,126,195,195,126,60,0,0,0,0,0,0,0,0,0};
// The table above should scroll 'HELLO' across the display//
// the 1st 8 values reps 'H' the next 8 reps 'E' etc //
main()
char cnt, cnt2, scrollcnt, col; //declare variables
set_tris_c(0); /* set port_a as output */
//do
start:
port_b = 0; /* ZERO port_c & port_b */
port_c = 0;
scrollcnt = 0; /* set scrolcnt to zero */
cnt2 = 0;
if (scrollcnt == 25)
scrollcnt = 0;
++cnt2;
if (cnt2 == 48)
cnt2 = 0;
for(cnt = 0;cnt < 8;cnt++)
port_c = 0; // Turn off any previous data displayed
port_c = col; // Display the new data
col<<=1; // Shitf bit 1 place left
// }while(1);
// the program works fine but i can't seem to be able to put it into
// an infinate loop so that program starts again from the begining
// i still need your expert help
goto start;
Original Post ID: 8524 |
aiyanyo Guest
Posted: Mon Nov 04, 2002 7:18 pm |
the goto & start were just for test
Original Post ID: 8525 |
Mark
Posted: Mon Nov 04, 2002 9:47 pm |
My mistake! cnt+cnt2 exceeded the array size! Try this:
:= Mark,
:= Your example worked perfectly, and it has developed my
:= understanding of C programming.
:= i modified the program for an 8x8 Led using pic 16f873
:= the program scrolls the word hello acrsoss the display
:= it's perfect !!!
:= one more problem, when the program exits i tried to put
:= in a continous loop so that it starts again .
:= i use for (;;)& do-while but the program still would
:= not loop back.
:= am i doing something really bad here.
:= Thanks a million
:= Isaac
:= The program is attached below :
:=#if defined(__PCM__)
:=#include <16F873.H>
:=#fuses XT,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
:=#use delay(clock=4000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
:=//THIS IS ANOTHER PROGRAM CALLED SROLL2//
:=#byte port_a=5
:=#byte port_b=6
:=#byte port_c=7
:=char const pat[48]={0,255,255,24,24,255,255,0,0,255,255,219,219,195,195,0,
:= 0,255,255,192,192,192,192,0,0,255,255,192,192,192,192,0,
:= 0,60,126,195,195,126,60,0,0,0,0,0,0,0,0,0};
:= // The table above should scroll 'HELLO' across the display//
:= // the 1st 8 values reps 'H' the next 8 reps 'E' etc //
:=main()
:= char cnt, cnt2, scrollcnt, col; //declare variables
:= set_tris_c(0); /* set port_a as output */
:=//do
:= start:
:= delay_ms(500);
:= port_b = 0; /* ZERO port_c & port_b */
:= port_c = 0;
:= scrollcnt = 0; /* set scrolcnt to zero */
:= cnt2 = 0;
:=while(1)
:= // Infinite loop to avoid run on code
:= col = 0b00000001; // The column that we are driving
:= ++scrollcnt; // scrollcnt is used as a delay before we switch columns
:= if (scrollcnt == 25)
:= scrollcnt = 0;
:= ++cnt2;
if (cnt2 == 40)
:= cnt2 = 0;
:=for(cnt = 0;cnt < 8;cnt++)
:= port_c = 0; // Turn off any previous data displayed
:= port_b = pat[cnt+cnt2]; // Setup the data to display
:= port_c = col; // Display the new data
:= delay_ms(1); // Give some delay before we output the next column
:= col<<=1; // Shitf bit 1 place left
:= // }while(1);
:= // the program works fine but i can't seem to be able to put it into
:= // an infinate loop so that program starts again from the begining
:= // i still need your expert help
:=goto start;
Original Post ID: 8528 |
Isaac aiyanyo Guest
Posted: Tue Nov 05, 2002 7:04 am |
Perfert work mark.
It loops fine now.
you being a great,great help.
something that i wanted to get of my chest.
Why does the 7th column stay permanently ON during
the scroll process.
it only goes off after the last character'O'
is this a feature of the scroling method?
i can't thank you enough
Isaac
Original Post ID: 8541 |
Mark
Posted: Tue Nov 05, 2002 9:41 am |
When you say 7th column, do you mean the last column? Are you numbering the columns 0-7 or 1-8? I am assuming that you did change from a 5x7 LED matrix to a 8x8 matrix.
Mark
:= Perfert work mark.
:= It loops fine now.
:= you being a great,great help.
:= something that i wanted to get of my chest.
:= Why does the 7th column stay permanently ON during
:= the scroll process.
:= it only goes off after the last character'O'
:= is this a feature of the scroling method?
:= i can't thank you enough
:= Isaac
Original Post ID: 8548 |
Mark
Posted: Tue Nov 05, 2002 9:47 am |
Try the following to see if it helps with your problem. The last column is on a bit longer than the rest. This should take care of that.
Mark
:= Mark,
:= it's perfect !!!
:= not loop back.
:= Thanks a million
:= Isaac
:=#byte port_a=5
:=#byte port_b=6
:=#byte port_c=7
:=main()
:=//do
:= start:
:= delay_ms(500);
:= port_c = 0;
:= cnt2 = 0;
:=while(1)
:= scrollcnt = 0;
:= ++cnt2;
if (cnt2 == 40)
:= cnt2 = 0;
:= // }while(1);
:=goto start;
Original Post ID: 8550 |
Isaac aiyanyo Guest
Posted: Tue Nov 05, 2002 10:25 am |
My numbering are 1 - 8 and i am using an 8x8 led
This would mean RC6 on my pic as i am using a 16f873.
my table looks like this
RC0= COL1
RC1= COL2
RC2= COL3
RC3= COL4
RC4= COL5
RC5= COL6
RC6= COL7
RC7= COL8
i hope this gives you the picture
Isaac
from the above its col 7
Original Post ID: 8558 |
Isaac aiyanyo Guest
Posted: Tue Nov 05, 2002 10:53 am |
i still have the problem
Original Post ID: 8560 |
Mark
Posted: Tue Nov 05, 2002 12:53 pm |
Can you describe the problem in a little more detail? Are all eight LEDs in column 7 on the whole time? Does column 7 appear brighter than the rest? Does column 7 show incorrect data? What kind of circuit board are you using? Have you checked all the connections? Is there anything else on RC6?
Mark
Original Post ID: 8570 |
Isaac aiyanyo Guest
Posted: Wed Nov 06, 2002 6:17 am |
Mark,
its was all my fault.
i was complied the wrong project in malab.
so each time i recomplied it wasn't making any
changes.
its work perfectly now, and all credits to you.
Honestly you have being so helpful (HATS OFF 4 U)
i am still studying the way the program works and
when i have taken it all in.
My next project would be to modified the example
to use the 74hc595 shift reg on portc for my columns.
to save myself a few pins.
i would let you know how i get on, just making the
hardware at this minute.
Thanks a million
Isaac
Original Post ID: 8596 |
Mark
Posted: Wed Nov 06, 2002 8:20 am |
How many columns are you planning on driving. The more columns you drive, then dimmer the LEDs will get.
Mark
:= Mark,
:= its was all my fault.
:= i was complied the wrong project in malab.
:= so each time i recomplied it wasn't making any
:= changes.
:= its work perfectly now, and all credits to you.
:= Honestly you have being so helpful (HATS OFF 4 U)
:= i am still studying the way the program works and
:= when i have taken it all in.
:= My next project would be to modified the example
:= to use the 74hc595 shift reg on portc for my columns.
:= to save myself a few pins.
:= i would let you know how i get on, just making the
:= hardware at this minute.
:= Thanks a million
:= Isaac
Original Post ID: 8601 |
