-- serial receive error fix 18F46K22 - 26K22 pre A4 release
asmboy
PostPosted: Mon Mar 05, 2012 2:40 pm     Reply with quote
for the 18f46k22 26k22 family prior to rev A4
fix for 1 in 256 faulty character receive, silicon error
You can continue with the standard #useRS232 setup statement
BUT call this function BEFORE you do any serial transmit or receive
uartnum is 0 or 1 for the FIRST or second UART in these parts
masterfreq is the same value you use in the #use_delay() compiler directive
baudrate is YOUR desired baudrate
void Set_baudfix( int1 uartnum, unsigned int32 masterfreq, unsigned int32 baudrate){
     unsigned int16 baudiv;
// UART 1
#byte SPBRG =0xFAF
#byte SPBRGH=0xFB0
#byte TXSTA =0xFAC
#byte BAUDCON=0xFB8
#BIT  BRG16 =0xFB8.3
// UART 2
#byte SPBRG2 =0xF75
#byte SPBRGH2=0xF76
#byte TXSTA2 =0xF72
#byte BAUDCON2=0xF70
#BIT  BRG16_2 =0xF70.3
    baudiv= (unsigned int16) (( masterfreq / (4*baudrate))-1);
if (!uartnum){
    BRG16=1;
    SPBRG =make8(baudiv,0);
    spbrgh=make8(baudiv,1);
    txsta=0xA6;  // std 8 bit see txsta bit mapping and BRGH=1
    //  0xA6 needs to be changed for 9 bits && other  than 8-1-N
else{
    BRG16_2=1;
    SPBRG2 =make8(baudiv,0);
    spbrgh2=make8(baudiv,1);
    txsta2=0xA6;  // std 8 bit see txsta bit mapping and BRGH=1
[/code]
