Dividing a 32bit floating number into (4) 8-bit integers for
liche
PostPosted: Tue May 13, 2003 5:46 am     Reply with quote
I have a few 32bit floating numbers which I want to use to send to an EEPROM for storage. Does anyone have an idea of how to break this 32bit floating number into 4 separate 8-bit integers???
The make8() function only works on integers and does work with floating point numbers.
liche
Original Post ID: 14400
Tomi
Re: Dividing a 32bit floating number into (4) 8-bit integers
PostPosted: Tue May 13, 2003 6:37 am     Reply with quote
See CCS FAQ "How do I write variables to EEPROM that are not a byte?" That example is about saving floats.
:=I have a few 32bit floating numbers which I want to use to send to an EEPROM for storage. Does anyone have an idea of how to break this 32bit floating number into 4 separate 8-bit integers???
:=The make8() function only works on integers and does work with floating point numbers.
:=Thanks
:=liche
Original Post ID: 14403
Haplo
PostPosted: Tue May 13, 2003 6:39 am     Reply with quote
Here's the answer to your question:
<a href="http://www.ccsinfo.com/faq/?24" TARGET="_blank">http://www.ccsinfo.com/faq/?24</a>
Personally, I prefer the unions:
union Convert
float f;
int8 i[4];
union Convert C;
C.f=some_float_value;
write_eeprom(address,i[0] ) ;
write_eeprom(address+1,i[1] ) ;
write_eeprom(address+2,i[2] ) ;
write_eeprom(address+3,i[3] ) ;
I hope that answers your question.
__Ali
Original Post ID: 14404
