RTTTL player and USB?
acidice333
PostPosted: Wed Jan 11, 2012 2:03 pm     Reply with quote
I grabbed the RTTTL ringtone player src someone supplied on here and it works great Im having troubles getting it to work with USB.
It works until I uncomment the code for the usb_enumuerated() then it just plays the first 3 notes and repeats the 1st note forever.
Can I get this working like that?
#include <18F4550.h>
#device *=16
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,MCLR
#use delay(clock=48000000)
// CCS Library dynamic defines
#define USB_CONFIG_HID_TX_SIZE   20  // to pc
#define USB_CONFIG_HID_RX_SIZE   20  // from pc
// CCS USB Libraries
#include <pic18_usb.h>   //Microchip 18Fxx5x hardware layer for usb.c
#include "usb_desc_hid.h"
#include <usb.c>        //handles usb setup tokens and get descriptor reports
#include "tones.h"
#int_timer0
void rtcc_isr(void)
   //set_rtcc(RTCC_PRESET);
   //update_switch_status();   // Poll the switches
  // Preload a value for TMR0 so that we can control how long it takes to
  // trigger an interrupt
  TMR0 = Tempo;
  // Is a note playing?
  if (DurationCount)
    DurationCount--;
    if (!DurationCount)
      setup_ccp2(CCP_OFF);
  // Note is finished playing, do we have anymore in our buffer?
  else if (Notestat.Count)
    DurationCount = NoteBuffer[Notestat.Head].duration;
    Note_Ticks = NoteBuffer[Notestat.Head].note;
    Notestat.Count--;
    Notestat.Head++;
    Notestat.Head &= NOTE_ROLLOVER_MASK;
    CCP_2 = TMR1 + Note_Ticks;
    if (Note_Ticks)
      /* Setup the CCP module to toggle the output pin c2 */
      setup_ccp2(CCP_COMPARE_TOGGLE_MATCH);
    // Nope, we are all through so disable the PWM
#int_ccp2
void ccp2_isr (void)
  CCP_2 += Note_Ticks;
int8 in_data[20];
   usb_init_cs();
   TRISCbits.TRISC2 = 0;
   inittimer();
   Melody_Pointer = JINGLEBELLS;
   while(true) {
      melody_task();
      usb_task();
      //if (usb_enumerated()) {
         //if (usb_kbhit(1)) {
         //   usb_get_packet(1, in_data, USB_CONFIG_HID_RX_SIZE);
tones.h:
#define CLOCKSPEED     48000000
#define CCP_COMPARE_TOGGLE_MATCH        2
#define TMR1_PRESCALE  1
#define NOTE_C_SHARP   (((CLOCKSPEED/4)/277.18)/TMR1_PRESCALE)            // 277.18Hz
#define NOTE_D_SHARP   (((CLOCKSPEED/4)/311.13)/TMR1_PRESCALE)            // 311.13 Hz
#define NOTE_F_SHARP   (((CLOCKSPEED/4)/369.99)/TMR1_PRESCALE)            // 369.99 Hz
#define NOTE_G_SHARP   (((CLOCKSPEED/4)/415.30)/TMR1_PRESCALE)            // 415.30 Hz
#define NOTE_A_SHARP   (((CLOCKSPEED/4)/466.16)/TMR1_PRESCALE)            // 466.16 Hz
#define NOTE_C         (((CLOCKSPEED/4)/261.63)/TMR1_PRESCALE)            // 261.63 Hz
#define NOTE_D         (((CLOCKSPEED/4)/293.66)/TMR1_PRESCALE)            // 293.66 Hz
#define NOTE_E         (((CLOCKSPEED/4)/329.63)/TMR1_PRESCALE)            // 329.63 Hz
#define NOTE_F         (((CLOCKSPEED/4)/349.23)/TMR1_PRESCALE)            // 349.23 Hz
#define NOTE_G         (((CLOCKSPEED/4)/392.00)/TMR1_PRESCALE)            // 392.00 Hz
#define NOTE_A         (((CLOCKSPEED/4)/440.00)/TMR1_PRESCALE)            // 440.00 Hz
#define NOTE_B         (((CLOCKSPEED/4)/493.88)/TMR1_PRESCALE)            // 493.88 Hz
#define NOTE_SILENCE   0
#define DURATION_32   5    // Duration = 2^x
#define DURATION_16   4    // Duration = 2^x
#define DURATION_8    3    // Duration = 2^x
#define DURATION_4    2    // Duration = 2^x
#define DURATION_2    1    // Duration = 2^x
#define DURATION_1    0    // Duration = 2^x
typedef enum
  JINGLEBELLS,
  LAST_MELODY
}MELODIES;
typedef struct
  int Head;
  int Tail;
  int Count;
} NOTESTATR;
typedef struct
  long note;
  long duration;
}NOTE_DEF;
struct
  int TRISC0:1;
  int TRISC1:1;
  int TRISC2:1;
  int TRISC3:1;
  int TRISC4:1;
  int TRISC5:1;
  int TRISC6:1;
  int TRISC7:1;
}TRISCbits;
#locate TRISCbits = 0xF94
long TMR1;
#locate TMR1 = 0xFCE
int TMR1L;
#locate TMR1L = 0xFCE
int TMR1H;
#locate TMR1H = 0xFCF
int TMR0;
#locate TMR0 = 0xFD6
#define   MAX_NOTE_BUFFER_SIZE  4
#define   NOTE_ROLLOVER_MASK     0b00000011
NOTE_DEF  NoteBuffer[MAX_NOTE_BUFFER_SIZE];
NOTESTATR  Notestat = {0,0,0};
long      DurationCount=0;
int       Tempo=0;
long      Note_Ticks=0;
MELODIES  Melody_Pointer;
long      Note_Index = 0xFFFF;
BOOLEAN   PlayMelodyFlag = TRUE;
int       Read_Button_Count = 0;
const struct
  char tune[202];
  int  defaultoctave;
  int  defaultduration;
  int  tempo;
}JingleBellsss = {
                 {"8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8e.,8d.,8d.,8e.,d.,g.,8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8g.,8g.,8f.,8d.,c.,1p"},
                 5,
                 DURATION_4,
                 180
const struct
  char tune[192];
  int16  defaultoctave;
  int16  defaultduration;
  int16  tempo;
}JingleBellss = {
                 {"f#.,8g#,f#,d#.,p.,f#.,8g#,f#,d#.,p.,2c#6,c#6,a#.,p.,2b,b,f#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2c#6,c#6,e.6,8c#6,a#,2b.,2d#6,p.,b,f#,d#,f#.,8e,c#,b.4,1p"},
                 5,
                 DURATION_4,
                 140
/* Function Prototypes */
void InitTimer(void);
int PlayMelody();
void PlayNote(long note, int octave, int duration);
char get_char_from_tune(long index);
int get_tempo(void);
int get_defaultoctave(void);
int get_defaultduration(void);
void display_melody_name(void);
void Melody_Task(void);
void Button_Task(void);
void Check_Button_Press(void);
  DESCRIPTION:  This function handles the playing of a melody
  RETURN:       True if the melody is still active or False if its complete
  ALGORITHM:    none
  NOTES:        none
int PlayMelody(void)
  int octave = 0;
  int duration = 0;
  long note = 0;
  // Check for a valid Melody
  if (Melody_Pointer >= LAST_MELODY)
    // Reset the Melody to the start
    Melody_Pointer = 0;
  // Load notes while we have enough room
  while (Notestat.Count < MAX_NOTE_BUFFER_SIZE)
    // Is this the first note?
    if (Note_Index == 0xFFFF)
      display_melody_name();
      Tempo = get_tempo();
      Note_Index = 0;
    // Set Default duration
    duration = get_defaultduration();
    // Set Default Octave
    octave = get_defaultoctave();
    // Play a bit of slience between notes
    if (get_char_from_tune(Note_Index) == ',')
      PlayNote(0, 4, DURATION_32);
      Note_Index++;
      return(TRUE);
    // We are checking the duration
    else if ((get_char_from_tune(Note_Index) == '3') && (get_char_from_tune(Note_Index+1) == '2'))
      duration = DURATION_32;
      Note_Index += 2;
    else if ((get_char_from_tune(Note_Index) == '1') && (get_char_from_tune(Note_Index+1) == '6'))
      duration = DURATION_16;
      Note_Index += 2;
    else if (get_char_from_tune(Note_Index) == '8')
      duration = DURATION_8;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '4')
      duration = DURATION_4;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '2')
      duration = DURATION_2;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '1')
      duration = DURATION_1;
      Note_Index++;
    // Now we get the note
    switch (get_char_from_tune(Note_Index++))
      case 'c':
        if (get_char_from_tune(Note_Index) == '#')
          note = NOTE_C_SHARP;
          Note_Index++;
          note = NOTE_C;
      case 'd':
          note = NOTE_D_SHARP;
          Note_Index++;
          note = NOTE_D;
      case 'e':
        note = NOTE_E;
      case 'f':
          note = NOTE_F_SHARP;
          Note_Index++;
          note = NOTE_F;
      case 'g':
          note = NOTE_G_SHARP;
          Note_Index++;
          note = NOTE_G;
      case 'a':
          note = NOTE_A_SHARP;
          Note_Index++;
          note = NOTE_A;
      case 'b':
        note = NOTE_B;
      case 'p': // slience
        note = NOTE_SILENCE;
    // See if this note is 1.5x the duration
    if (get_char_from_tune(Note_Index) == '.')
      // Use the MSB to signify 1.5x
      duration |= 0x80;
      Note_Index++;
    // Get the octave
    switch (get_char_from_tune(Note_Index))
      case '4':
        octave = 4;
        Note_Index++;
      case '5':
        octave = 5;
        Note_Index++;
      case '6':
        octave = 6;
        Note_Index++;
      case '7':
        octave = 7;
        Note_Index++;
      default:
    // Sometimes the duration multiplier comes after the octave
      /* Duration 1.5x */
      duration |= 0x80;
      Note_Index++;
    // Play the note (we actually just load it in a buffer
    PlayNote(note, octave, duration);
    // Is this the end?
    if (get_char_from_tune(Note_Index) == 0)
      return(FALSE);
    return(TRUE);
  DESCRIPTION:  This function handles checking for button presses
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  long duration_count;
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  // Process Note Duration
  duration_count = 256;
  duration_count >>= (duration & 0x7F);
  // If duration is 1.5x add .5 to duration
  if (duration & 0x80)
    duration_count += (duration_count >> 1);
  // Add the note to our buffer
  NoteBuffer[Notestat.Tail].note = note;
  NoteBuffer[Notestat.Tail].duration = duration_count;
  Notestat.Tail++;
  Notestat.Tail &= NOTE_ROLLOVER_MASK;
  Notestat.Count++;
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_1); //8 ;
  enable_interrupts(INT_CCP2);
  //enable_interrupts(INT_TIMER2);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  switch (Melody_Pointer)
    case JINGLEBELLS:
      return (JingleBellss.tune[index]);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
int get_tempo(void)
    case JINGLEBELLS:
      return (JingleBellss.tempo);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case JINGLEBELLS:
      return (JingleBellss.defaultoctave);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case JINGLEBELLS:
      return (JingleBellss.defaultduration);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (PlayMelodyFlag)
    if (!PlayMelody())
      Melody_Pointer++;
  DESCRIPTION:  This function displays the title of the melody on the LCD
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  // Clear the screen and make sure that we are at the top
  //lcd_putc("\f");
  //lcd_gotoxy(0,1);
  // Use our global Melody_Pointer to determine the title of the current tune
    case JINGLEBELLS:
      //lcd_putc("JingleBells");
     default:
  DESCRIPTION:  Button Tasks
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (!Read_Button_Count)
    Read_Button_Count = 30;
    Check_Button_Press();
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  static int debounce_count = 4;
  static int stable = 0xFF;
  static int last = 0xFF;
  int trans_low;
  int current = 0xFF;
  BOOLEAN change = FALSE;
  // Read the current state of the buttons
  if (!input(PIN_B7))
    bit_clear(current,2);
  if (!input(PIN_B6))
    bit_clear(current,3);
  // See if they have changed
  if (current != last)
    last = current;
    change = TRUE;
  // If they have changed then reset our counter
  if (change)
    debounce_count = 4;
  // Each time they are stable, then decrement our count
  else if (debounce_count)
    debounce_count--;
  // They have been stable long enough so act on them
  else if (current != stable)
    // Get the high transitions
    trans_low = ((stable ^ current) & stable);
    if (bit_test(trans_low,2))
      PlayMelodyFlag = ! PlayMelodyFlag;
    if (bit_test(trans_low,3))
      Melody_Pointer++;
        Melody_Pointer = 0;
    stable = current;
