colesha
| Display at LCD |
Posted: Mon Jan 09, 2012 7:24 am |
I made a code to flash a Led at one speed and when a switch is closed the Led changes the speed of flashing. The code was a success. Now I want to display this on an LCD 16x2. When the switch is not closed and led is flashing faster will display on the LCD-Fast and when the switch is closed display on LCD - Slow. But when I simulate it, it only displays Fast even if the switch is closed or not. Here is the code:
#include <16F877.H>
#use delay(clock = 4000000)
#include "flex_lcd.c"
#include <stdio.h>
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
lcd_init(); // Always call this first.
#define TRUE 1
#define FALSE 0
if(PIN_C0==TRUE)
printf(lcd_putc,"\SLOW\n");
else (PIN_C0==FALSE);
printf(lcd_putc,"\FAST\t");
while(1) // Keep checking switch
if(!input(PIN_C0)) // Siren while switch ON
output_high(PIN_C1); // Sound sequence
delay_ms(300);
output_low(PIN_C1);
delay_ms(300);
else(input(PIN_C0));
delay_us(500);
output_low(PIN_C1);
delay_us(500);
RF_Developer
Posted: Mon Jan 09, 2012 7:59 am |
// Delete the following line - you can't call anything here.
// The follwoing two lines are redundant. TRUE and FALSE are already defined for you.
#define TRUE 1
#define FALSE 0
// There's no need to compare pins to TRUE or FALSE. They are already true or false.
// Also PIN_C0 is a constant "pointer" to the pin. To read the state of the pin you must do input(PIN_C0) which returns true or false.
// The next line should be: if (input(PIN_C0))
if(PIN_C0==TRUE)
// Else should not have anything in brackets after it. Its simply: else
// This is always executed as its outside the if-else which ended at the semi-colon in the line above.
// This next block does nothing: its empty.
// Everything above happens only once. Everything inside this while block is done over and over.
// Correct pin input syntax this time.
delay_ms(300);
output_low(PIN_C1);
delay_ms(300);
// Else is wrong here too. Also nothing will be executed as the else block ends at the semicolon.
// This is NOT part of the if-else. Its totally separate and is ALWAYS executed.
delay_us(500);
output_low(PIN_C1);
delay_us(500);
I doubt this code compiles. If it does I really doubt it does what you want it to. I suspect you need something more like this pseudo-code:
while (1)
if (input(PIN_C0)
// Do something when PIN_C0 is one.
// Do something else when PIN_C0 in NOT one, i.e. its zero.
RF Developer |
colesha
Posted: Mon Jan 09, 2012 11:48 pm |
Thanks RF_Developer,
The code compiles but it does not do what I want as you said, fine I can use the if-else function but I just need to no how to do it. I made several attempts and appeared to be well but the problem I get is that the LED flash sequnce is affected.
All I need is to flash the LED at a different speed when the switch is closed and display fast or slow on the LCD. I can use the if-else function but maybe just can't figure out the best way to do it.
Some assistance Please. |
