New software bugs discovered.
sshahryiar
PostPosted: Fri Jan 06, 2012 3:32 am     Reply with quote
Dear all,
This message is directed particularly to the CCS software developers and all concerned. I'm currently using CCS compiler version 4.124 and I found out these two problems:
1. The comparator module in small PICs like PIC12F629 doesn't seem to work with the built-in functions like "setup_comparator(A0_A1)".
2. The PWM module also seems not to work with the internal oscillator configurations.
Any suggestion regarding this matter will be appreciated.
Thanks.
https://www.facebook.com/MicroArena
SShahryiar
SherpaDoug
PostPosted: Fri Jan 06, 2012 8:43 am     Reply with quote
Can you give a small complete program that demonstrates the problems? Also give your compiler version.
PostPosted: Fri Jan 06, 2012 1:48 pm     Reply with quote
12F629 doesn't have a CCP module and can't do hardware PWM.
sshahryiar
PostPosted: Sat Jan 07, 2012 1:38 am     Reply with quote
Dear PCM programmer,
I didn't mention "PWM module with PIC12F629". The comparator problem was discovered with PIC12F629. However it didn't occur with PIC12F675. The problem with PWM module happened with mid-range chips with internal oscillator like PIC16F690, PIC16F88, PIC12F683, etc. Test with any simple code and it is visible. I just want to know why it happened so.
Thanks.
SShahryiar
PostPosted: Sat Jan 07, 2012 3:32 am     Reply with quote
I can't actually see how what you describe for the PWM 'can' happen, and it certainly doesn't for me....
Am running the 690, with a PWM off the internal oscillator, and it runs fine with the current compilers.
The PWM setup just expects an output from timer2.
Timer2 just takes whatever oscillator it is fed.
If the master oscillator is running, Timer2, works. Doesn't care whether the source is internal or external.
There are no changes between running with internal or external oscillators.
On both problems, are you _sure_ that when you switch compiler versions, you change the project definitions to point to the include files for the latter compiler, not the ones for the old compiler?. There are some changes in some of the definitions that started to appear in the early 4.12x compilers, and if the old include file is used, all sorts of odd things can happen.
sshahryiar
PostPosted: Sun Jan 08, 2012 3:12 am     Reply with quote
Dear Ttelmah,
I'll give it a try and will post soon. Thanks.
SShahryiar
