pic16f877a pwm problem
masab_ahmad
PostPosted: Tue Dec 27, 2011 9:44 am     Reply with quote
Hi all,
I am using a pic16f877a to measure voltages and vary the PWM. The adc voltages vary just fine, but the PWM isn't generated...here is the code (is it ok? ):
#include <16F777.h>
#device ADC=16
#fuses XT,NOWDT,NOPROTECT
//long duty_cycle,period;
long adc_result0;
long adc_result1;
output_low(PIN_C1);   // Set CCP2 output low
output_low(PIN_C2);   // Set CCP1 output low
setup_ccp1(CCP_PWM);  // Configure CCP1 as a PWM
setup_ccp2(CCP_PWM);  // Configure CCP2 as a PWM
setup_timer_2(T2_DIV_BY_16, 124, 1);  // 500 Hz
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_16);
setup_timer_2(T2_DIV_BY_1, 255, 1);
while (1)
set_adc_channel(0);
delay_us(10);
adc_result0=read_adc();
set_adc_channel(1);
delay_us(10);
adc_result1=read_adc();
if(adc_result0 <655)
   set_pwm1_duty(255);
else if((adc_result0 > 655) &&(adc_result0 < 700))
   set_pwm1_duty(150);
else if((adc_result0 < 750) && (adc_result0 > 700))  //car far from obstacle
   set_pwm1_duty(120);
else if((adc_result0 < 800) && (adc_result0 > 750))  //car medium from obstacle
   set_pwm1_duty(100);
else if((adc_result0 < 900) && (adc_result0 > 800))          //car near to obstacle
   set_pwm1_duty(0);
   set_pwm2_duty(200);
if(adc_result1 < 460)          //car too far from obstacle
  set_pwm2_duty(250);
else if((adc_result1 < 500) && (adc_result1 > 460))          //car too far from obstacle
   set_pwm2_duty(150);
else if((adc_result1 < 550) && (adc_result1 > 500))          //car  far from obstacle
   set_pwm2_duty(120);
else if((adc_result1 < 600) && (adc_result1 > 550))          //car medium to obstacle
   set_pwm2_duty(100);
else if((adc_result1 < 780) && (adc_result1 > 600))          //car near to obstacle
   set_pwm2_duty(0);
   set_pwm1_duty(200);
masab_ahmad
PostPosted: Tue Dec 27, 2011 10:32 am     Reply with quote
its working in the 'Real Pic simulator", but not in proteus.....
PostPosted: Tue Dec 27, 2011 10:42 am     Reply with quote
So you should conclude to throw away Proteus. Search this site and you'll see hundreds of msgs saying how BAD it is with respect to 'simulating' PICs.
I'm old school(doing this for 30+ years...), cut code, program real PICs, test in the real world. NO simulator can simulate the real world properly.
