cd-rom music player
georpo
cd-rom music player
PostPosted: Tue Apr 19, 2011 11:45 am     Reply with quote
Are there any ideas about the commands needed to play audio cd with a low cost IDE cd-rom?
I am familiar with the interface, I have already a hard disk drive interface working.
I just need the commands for read TOC, play, stop, next track etc.
George.
PostPosted: Tue Apr 19, 2011 1:30 pm     Reply with quote
You could use google to help you out, simple search revealed 50,000+ 'hits' for me couple of minutes ago....
..this 'net stuff' is really useful and fast compared to the old dayze...
wslay
PostPosted: Fri Dec 02, 2011 8:51 am     Reply with quote
I think this not easy case to study, you can try my code as below. Good luck to you. Now I have problem as SCSI-2 CD-ROM, if you have good idea, please let me to know.
*  ATAPI IDE CD-ROM Library
*  If you have any problem, please contact to me.
*  Email:wslay0924@gmail.com
*  reference: sff8020i.pdf, d1153r18.pdf
*  initial v1.0  ---------------------------- 2011.10.07 by WSLAY
*  optimun v1.1  ---------------------------- 2011.11.27 by WSLAY
#include <ATAPI.h>
*** function     : void ATAPI_Register(BYTE reg)
*** input data   : reg
*** output data  : NA
*** description  : reg for address pin
void ATAPI_Reg(BYTE reg)
  output_bit(ATA_DIOW_PIN, 1);
  output_bit(ATA_DIOR_PIN, 1);
  output_bit(ATA_CS0_PIN, 0);
  output_bit(ATA_CS1_PIN, 0);
  output_bit(ATA_DA0_PIN, bit_test(reg, 0));
  output_bit(ATA_DA1_PIN, bit_test(reg, 1));
  output_bit(ATA_DA2_PIN, bit_test(reg, 2));
*** function     : ATAPI_input(BYTE reg, BYTE &LSB, BYTE &MSB)
*** output data  : LSB, MSB
*** description  : reg:define register ; LSB&MSB read from ATAPI device data
void ATAPI_input(BYTE reg, BYTE &LSB, BYTE &MSB)
  set_tris_LSB(0xFF);
  set_tris_MSB(0xFF);
  ATAPI_Reg(reg);
  output_bit(ATA_CS1_PIN, 1);
  output_low(ATA_DIOR_PIN);
  delay_cycles(1);
  LSB = input_LSB();
  MSB = input_MSB();
  output_high(ATA_DIOR_PIN);
  set_tris_LSB(0x00);
  set_tris_MSB(0x00);
  delay_cycles(1);
*** function     : ATAPI_output(BYTE reg, BYTE LSB, BYTE MSB)
*** input data   : reg, LSB, MSB
*** description  : reg:define register ; LSB&MSB write to ATAPI device data
void ATAPI_output(BYTE reg, BYTE LSB, BYTE MSB)
  set_tris_LSB(0x00);
  set_tris_MSB(0x00);
  ATAPI_Reg(reg);
  output_LSB(LSB);
  output_MSB(MSB);
  output_low(ATA_DIOW_PIN);
  delay_cycles(1);
  output_high(ATA_DIOW_PIN);
  delay_cycles(1);
*** function     : BYTE ATAPI_ReadStatus()
*** input data   : NA
*** output data  : ATAPI status
*** description  : return ATAPI status
  return ATAPI_inputLSB(reg_status);
*** function     : BYTE ATAPI_ReadError()
*** input data   : NA
*** output data  : ATAPI error
  return ATAPI_inputLSB(reg_error);
*** function     : BOOLEAN ATAPI_BSY()
*** input data   : NA
*** output data  : BOOLEAN
*** description  : busy flag status
BOOLEAN ATAPI_BSY()
  return bit_test(ATAPI_inputLSB(reg_status), BSY);
*** function     : BOOLEAN ATAPI_RDRY()
*** input data   : NA
*** description  : RDRY flag status
  return bit_test(ATAPI_inputLSB(reg_status), RDRY);
*** function     : BOOLEAN ATAPI_CHECK()
*** input data   : NA
*** description  : CHECK flag status
  return bit_test(ATAPI_inputLSB(reg_status), CHECK);
*** input data   : NA
*** description  : DRQ flag status
BOOLEAN ATAPI_DRQ()
  return bit_test(ATAPI_inputLSB(reg_status), DRQ);
*** function     : BOOLEAN ATAPI_waitDRQ()
*** input data   : NA
*** description  : wait DRQ flag status
  char i = 0, timeout =100;
  do
    delay_ms(10);
  }while(++i<timeout && !ATAPI_DRQ());
  if (i == timeout) return 0;
  return 1;
*** function     : void ATAPI_devhead(BYTE dev)
*** input data   : dev  (0=master, 1=slave)
*** description  : select device head
  BYTE DevHead = ATAPI_inputLSB(reg_devicehead);              //select master device
  if (dev == 0) bit_clear(DevHead, 4);                        //Bit4, This bit selects either Device 0 (DRV=0) or 1(DRV=1).
  else bit_set(DevHead, 4);
  ATAPI_output(reg_devicehead, DevHead, 0xFF);
*** function     : void ATAPI_PacketCmd(BYTE *PktCmd, BYTE Count)
*** input data   : PktCmd data pointer, data Count (normal = 12)
*** description  : send packet command
  BYTE i=0;
  //Select master device
  ATAPI_devhead(0);
  //Set packet size
  ATAPI_output(reg_cylow, PktCmdSize, 0xFF);
  ATAPI_output(reg_cyhigh, 0x00, 0xFF);
  //Packetsize command
  ATAPI_output(reg_cmd, 0xA0, 0xFF);
  //wait when DRQ = 1
  while(!ATAPI_DRQ());
  for (i=0; i<Count; i+=2)
    ATAPI_output(reg_data, PktCmd[i], PktCmd[i+1]);
*** function     : BYTE ATAPI_inputLSB(BYTE reg)
*** output data  : BYTE (LSB data)
*** description  : reg:define register ; LSB read from ATAPI device data
  BYTE LSB, MSB;
  ATAPI_input(reg, LSB, MSB);
  return LSB;
*** function     : void ATAPI_ReadPacketData(BYTE Count)
*** input data   : read count
*** output data  : public data array
*** description  : assign read out count
  BYTE LSB, MSB, i;
    ATAPI_waitDRQ();
    ATAPI_input(reg_data, LSB, MSB);
    tempPktData[i]   = LSB;
    tempPktData[i+1] = MSB;
*** function     : void ATAPI_Test()
*** input data   : NA
*** description  : test ATAPI device
void ATAPI_Test()
  BYTE PktCmd[12] = {0};
  ATAPI_PacketCmd(&PktCmd[0], 12);
*** function     : void ATAPI_Eject(TEJECT MODE)
*** input data   : MODE
*** description  : STOP=0, START=1, EJECT=2, LOAD=3
  PktCmd[0] = 0x1B;
  PktCmd[4] = MODE;
*** function     : void ATAPI_PlayMSF()
*** input data   : NA
*** description  : play music
  PktCmd[0] = 0x47;
  PktCmd[3] = StartM;
  PktCmd[4] = StartS;
  PktCmd[5] = StartF;
  PktCmd[6] = EndM;
  PktCmd[7] = EndS;
  PktCmd[8] = EndF;
*** function     : void ATAPI_Stop()
*** input data   : NA
*** description  : stop play music
void ATAPI_Stop()
  PktCmd[0] = 0x4E;     //STOP/SCAN Command
*** function     : void ATAPI_Pause(BOOLEAN flag)
*** input data   : flag
*** description  : flag = 1 as true
  PktCmd[0] = 0x4B;     //PAUSE/RESUME Command
  PktCmd[8] = flag;     //1:PAUSE
*** function     : void ATAPI_Next(BYTE NP)
*** input data   : NA
*** description  : play next music
void ATAPI_Next()
    ATAPI_ReadSub(); //Read current MSF?
    if (++CurrentTrackNum > EndTrackNum) CurrentTrackNum = EndTrackNum;
    ATAPI_ReadTOC(CurrentTrackNum);
    ATAPI_PlayMSF();   //play MSF
*** function     : void ATAPI_Prevous()
*** input data   : NA
*** description  : play prev music
    if (--CurrentTrackNum < StartTrackNum) CurrentTrackNum = StartTrackNum;
*** function     : void ATAPI_ReadTOC(BYTE Track)
*** input data   : Track
*** description  : Read MSF; Track = 0xAA, read end track number
  BYTE Count = 12;
  PktCmd[0] = 0x43;           //  Bit 7   6   5   4   3   2   1   0
  PktCmd[1] = 0x02;           //      R   R   R   R   R   R   MSF R
  PktCmd[6] = Track;          // Starting Track / Session Number
  PktCmd[8] = Count;          //  Allocation Length  (LSB)
  if (!ATAPI_waitDRQ()) return;
  ATAPI_ReadPacketData(Count);
  StartTrackNum = tempPktData[2];
  EndTrackNum   = tempPktData[3];
  if (Track == 0xAA)
    EndM = tempPktData[9];
    EndS = tempPktData[10];
    EndF = tempPktData[11];
  }else
    StartM = tempPktData[9];
    StartS = tempPktData[10];
    StartF = tempPktData[11];
*** function     : void ATAPI_ReadSub()
*** input data   : NA
*** description  : Read current MSF
  BYTE Count = 16;
  PktCmd[0] = 0x42;             //  Bit 7   6   5   4   3   2   1   0
  PktCmd[2] = 0x40;             //      R  SubQ R   R   R   R   R   R
  PktCmd[3] = 0x01;             //  Sub-channel Data Format
  AudioStatus     = tempPktData[1];
  CurrentTrackNum = tempPktData[6];
  CurrentM        = tempPktData[9];
  CurrentS        = tempPktData[10];
  CurrentF        = tempPktData[11];
*** function     : void ATAPI_Inquiry()
*** input data   : NA
*** description  : Inquiry device function, Vendor[8];Product[16];Revision[4];
  BYTE i =0 ;
  BYTE Count = 36;
  PktCmd[0]  = 0x12;
  PktCmd[4]  = Count;
  //while(!ATAPI_DRQ());
  for (i=8; i<16; i++)     Vendor[i-8]    = tempPktData[i];
  for (i=16; i<32; i++)    Product[i-16]  = tempPktData[i];
  for (i=32; i<Count; i++) Revision[i-32] = tempPktData[i];
  while(ATAPI_DRQ()) ATAPI_inputLSB(reg_data);  //Readout all data from CD-ROM buffer.
*** function     : BOOLEAN ATAPI_ReadCDInfo()
*** input data   : 1 = OK; 0= fail
*** description  : read infomation
  BYTE i = 0, timeout = 10;
  do
    ATAPI_ReadSub();
    delay_ms(10);
    ATAPI_ReadTOC(0xAA);
  }while((++i<timeout) && (CurrentTrackNum != 1));
  ATAPI_ReadTOC(0);
  return 1;
*** function     : BOOLEAN ATAPI_initCDROM()
*** input data   : NA
*** output data  : 0: no error
*** description  : init ATAPI device
int ATAPI_initCDROM()
  delay_ms(50);
  output_drive(ATA_DA0_PIN);
  output_drive(ATA_DA1_PIN);
  output_drive(ATA_DA2_PIN);
  output_drive(ATA_DIOW_PIN);
  output_drive(ATA_DIOR_PIN);
  output_drive(ATA_CS0_PIN);
  output_drive(ATA_CS1_PIN);
  output_drive(ATA_RST_PIN);
  ATAPI_Reg(reg_data);
  output_low(ATA_RST_PIN);
  delay_ms(10);
  output_high(ATA_RST_PIN);
  delay_ms(50);
  while (ATAPI_BSY());
  delay_ms(300);   //for some CD-ROM response slower, ex:TEAC CD-W552E
  //sdelect master device
  ATAPI_devhead(0);
  //Check device as ATAPI CD-ROM
  if((ATAPI_inputLSB(reg_cylow)) != 0x14 || (ATAPI_inputLSB(reg_cyhigh) != 0xEB))
    return ATA_notATAPI_Error;
  //Self test
  ATAPI_output(reg_cmd, 0x90, 0xFF);
  while(ATAPI_BSY());
  BYTE RetCode = ATAPI_ReadError();
  if ((RetCode != 0x01) && (RetCode != 0x81))       //01h  device0 passed, Device 1 passed or not present ;dev=1, device 1 passed
    return ATA_SelfTest_Error;    //81h  device0 passed, Device 1 fail ; dev=1, 00h, 02h-7Fh device 1 failed
  //Identify packet device
  ATAPI_output(reg_cmd, 0xA1, 0xFF);
  while(!ATAPI_DRQ());    //DRQ=1 data ready read.
  BYTE Byte0 = ATAPI_inputLSB(reg_data)<<6;  //Byte0-> bit0-1  00:12 byte command packet; 01:16 byte command packet
  if (Byte0 == 0) PktCmdSize = 12;          //12byte 6word
  else if (Byte0 == 0x40) PktCmdSize = 16; //16byte 6word
  else return ATA_PacketSize_Error;
  //Test device as ready
  while(ATAPI_CHECK()) ATAPI_Test();
  ATAPI_Inquiry();
  return 0;
