| View previous topic :: View next topic   |
			monkeytennis
				| Can only use one .c file in MPLAB IDE |
				 Posted: Tue Nov 15, 2011 8:14 am     |
I have just got the latest release (4.126) of the PCH command line compiler and have run the CCS setup program to use it with MPLAB IDE.
However, when I try and build a project containing more than a single .c file it says:
 	  | Code: | 	 		  Executing: "C:\Program files\Picc\CCSC.exe" +FH "main.c" +EXPORT  #__DEBUG=1 +ICD +DF +LN  +T +A +M -Z +Y=9 +EA #__18F4550=TRUE
*** Error 7 "C:\Program Files\PICC\devices\18F4550.h" Line 204(2,6): Invalid Pre-Processor directive  Export requires IDE
      1 Errors,  0 Warnings.
BUILD FAILED: Tue Nov 15 14:09:00 2011
But when I remove the other .c files (except the one containing main()) the project compiles successfully.
What am I doing wrong?
Thanks, Simon |
			monkeytennis
				 Posted: Tue Nov 15, 2011 12:22 pm     |
				Okay, so it looks like I needed an IDE edition.
I'll stick to doing it using a single .c file.
Thanks for your help.     |
				 Posted: Tue Nov 15, 2011 1:18 pm     |
				Well, you can use multiple files, you just have to #include them in the
main C source file, as shown in the linked examples in that thread. |
