#PIN_SELECT changed in V4.125
bilko
PostPosted: Sat Oct 08, 2011 1:36 am     Reply with quote
I used to be able to use #defines in #PIN_SELECT:
ie:
#define P_ChargePWM PIN_G6
#PIN_SELECT OC1=P_ChargePWM
but now in V4.125 I have to say:
#PIN_SELECT OC1=PIN_G6
This is PCD, I have not yet tried the other compilers.
This seems to be a backward step
Bill
orangeshasta
PostPosted: Sun Oct 23, 2011 12:12 pm     Reply with quote
Hi there,
Late response I know, but I just saw your post. I was having the same problem, and got in touch with CCS support. What they said:
Make sure there is not a tab on the #define line. 4.125 seems to have a problem with tabs in the #pin_select. This will be fixed in the next release.
That seemed to work for me. I needed to remove ALL TABS from all lines of code which had a #define statement to rename a pin, and from all of my #pin_select lines. This INCLUDES tabs after the command - i.e., between your #define and a comment on the same line.
Hope that helps, I'm looking forward to a compiler update. There seem to be a couple problems with 4.125.
-Bob
bkamen
PostPosted: Sun Oct 23, 2011 1:47 pm     Reply with quote
orangeshasta wrote:
Hi there,
Ooo, this is an old bug that seems to have crept back in.
For Shame.
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 4:18 pm     Reply with quote
Thank you, I was about to pull my hair out.
Now I'm just cursing as I remove all tabs everywhere... it's slightly less stressful.
bkamen
PostPosted: Mon Nov 07, 2011 4:25 pm     Reply with quote
And I'm not a fan of spaces -- I like tabs.. but I can see their downfall.
Yay Python. (grrrr)
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 5:16 pm     Reply with quote
I take it back. I am pulling my hair out.
Even with the spaces change, there seems to be something wrong with the PIN_SELECTs. I reverted to an older PCD version, and my I/O works -- with the newest compiler (4.125), it doesn't.
Does anyone have a link to version 4.124? Unfortunately, the last one I saved off was 4.112...
PostPosted: Mon Nov 07, 2011 5:20 pm     Reply with quote
If you are registered user of 4.125 report the problem to CCS and they will likely send you the previous version.
bkamen
PostPosted: Mon Nov 07, 2011 5:54 pm     Reply with quote
And probably the next... They usually send you a free update when you report a bug like this..
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 7:49 pm     Reply with quote
I wanna know who you guys are talking to, cause I've never received good customer service from them, and I've been a licensed customer (reporting a multitude of bugs) for years.
I actually keep a separate project on MPLAB with a bunch of regression tests to try against each new upgrade... and I have yet to see any of the bugs I've reported be fixed. :-/
PostPosted: Tue Nov 08, 2011 5:49 am     Reply with quote
I always reported my bugs to the support email at the top of this page, never by phone. Often I got a response that the bug would be fixed in the next release and as mentioned by others, sometimes got a free update for the next release.
Some of the lesser important bugs were not fixed, too bad, but I do understand that a commercial company has to make choices.
